drivers for Linksys WMP54 G wireless NIC ????????? HeLp
RE: Re: RE: drivers for Linksys WMP54 G wireless NIC ???????
Postby K4EEZ » Mon May 01, 2006 12:03 am
GERRRRRRRRRRRR
ok i spent the weekend Hardwirning the Lan cable
no i have wirless and a fixed Lan cat6 cable gerrrrrr
anyhow, guess i doing this the hardway or I am just to Stupid to know what this is all about
ok bought a NEW nic it says it supports Linux 2.0 and above
no on the darm cd it points to a web page, copyed and pasted the url in to firefox
click on GO and the url is not there, dead, broken or other whize UNAVAILABLE!
heres the link,, better still here the list on the frigging cd:
/* rtl8139.c: A RealTek RTL8129/8139 Fast Ethernet driver for Linux. */
Written 1997-1999 by Donald Becker.
This software may be used and distributed according to the terms
of the GNU Public License, incorporated herein by reference.
All other rights reserved.
This driver is for boards based on the RTL8129 and RTL8139 PCI ethernet
chips.
The author may be reached as becker@CESDIS.gsfc.nasa.gov, or C/O
Center of Excellence in Space Data and Information Sciences
Code 930.5, Goddard Space Flight Center, Greenbelt MD 20771
Support and updates available at
http://cesdis.gsfc.nasa.gov/linux/drivers/rtl8139.html
Twister-tuning table provided by Kinston <shangh@realtek.com.tw>.
/* This version has CardBus support added. */
static const char *version =
"rtl8139.c:v1.08 6/25/99 Donald Becker http://cesdis.gsfc.nasa.gov/linux/drivers/rtl8139.html\n";
/* A few user-configurable values. */
/* Maximum events (Rx packets, etc.) to handle at each interrupt. */
static int max_interrupt_work = 20;
#define rtl8129_debug debug
static int rtl8129_debug = 1;
/* Maximum number of multicast addresses to filter (vs. Rx-all-multicast).
The RTL chips use a 64 element hash table based on the Ethernet CRC. */
static int multicast_filter_limit = 32;
/* Used to pass the full-duplex flag, etc. */
#define MAX_UNITS 8 /* More are supported, limit only on options */
static int options[MAX_UNITS] = {-1, -1, -1, -1, -1, -1, -1, -1};
static int full_duplex[MAX_UNITS] = {-1, -1, -1, -1, -1, -1, -1, -1};
/* Size of the in-memory receive ring. */
#define RX_BUF_LEN_IDX 3 /* 0==8K, 1==16K, 2==32K, 3==64K */
#define RX_BUF_LEN (8192 << RX_BUF_LEN_IDX)
/* Size of the Tx bounce buffers -- must be at least (dev->mtu+14+4). */
#define TX_BUF_SIZE 1536
/* PCI Tuning Parameters
Threshold is bytes transferred to chip before transmission starts. */
#define TX_FIFO_THRESH 256 /* In bytes, rounded down to 32 byte units. */
/* The following settings are log_2(bytes)-4: 0 == 16 bytes .. 6==1024. */
#define RX_FIFO_THRESH 4 /* Rx buffer level before first PCI xfer. */
#define RX_DMA_BURST 4 /* Maximum PCI burst, '4' is 256 bytes */
#define TX_DMA_BURST 4 /* Calculate as 16<<val. */
/* Operational parameters that usually are not changed. */
/* Time in jiffies before concluding the transmitter is hung. */
#define TX_TIMEOUT (4*HZ)
#if !defined(__OPTIMIZE__) || !defined(__KERNEL__)
#warning You must compile this file with the correct options!
#warning See the last lines of the source file.
#error You must compile this driver with "-O".
#endif
#include <linux/config.h>
#include <linux/version.h>
#ifdef MODULE
#ifdef MODVERSIONS
#include <linux/modversions.h>
#endif
#include <linux/module.h>
#else
#define MOD_INC_USE_COUNT
#define MOD_DEC_USE_COUNT
#endif
#include <linux/kernel.h>
#include <linux/sched.h>
#include <linux/string.h>
#include <linux/timer.h>
#include <linux/errno.h>
#include <linux/ioport.h>
#include <linux/malloc.h>
#include <linux/interrupt.h>
#include <linux/pci.h>
#include <linux/netdevice.h>
#include <linux/etherdevice.h>
#include <linux/skbuff.h>
#include <asm/processor.h> /* Processor type for cache alignment. */
#include <asm/bitops.h>
#include <asm/io.h>
/* Kernel compatibility defines, some common to David Hind's PCMCIA package.
This is only in the support-all-kernels source code. */
#define RUN_AT(x) (jiffies + (x))
#if LINUX_VERSION_CODE < 0x20123
#define test_and_set_bit(val, addr) set_bit(val, addr)
#endif
#if LINUX_VERSION_CODE <= 0x20139
#define net_device_stats enet_statistics
#else
#define NETSTATS_VER2
#endif
#if LINUX_VERSION_CODE < 0x20155 || defined(CARDBUS)
/* Grrrr, the PCI code changed, but did not consider CardBus... */
#include <linux/bios32.h>
#define PCI_SUPPORT_VER1
#else
#define PCI_SUPPORT_VER2
#endif
#if LINUX_VERSION_CODE < 0x20159
#define dev_free_skb(skb) dev_kfree_skb(skb, FREE_WRITE);
#else
#define dev_free_skb(skb) dev_kfree_skb(skb);
#endif
#if ! defined(CAP_NET_ADMIN)
#define capable(CAP_XXX) (suser())
#endif
/* The I/O extent. */
#define RTL8129_TOTAL_SIZE 0x80
Theory of Operation
I. Board Compatibility
This device driver is designed for the RealTek RTL8129, the RealTek Fast
Ethernet controllers for PCI. This chip is used on a few clone boards.
II. Board-specific settings
PCI bus devices are configured by the system at boot time, so no jumpers
need to be set on the board. The system BIOS will assign the
PCI INTA signal to a (preferably otherwise unused) system IRQ line.
Note: Kernel versions earlier than 1.3.73 do not support shared PCI
interrupt lines.
III. Driver operation
IIIa. Rx Ring buffers
The receive unit uses a single linear ring buffer rather than the more
common (and more efficient) descriptor-based architecture. Incoming frames
are sequentially stored into the Rx region, and the host copies them into
skbuffs.
Comment: While it is theoretically possible to process many frames in place,
any delay in Rx processing would cause us to drop frames. More importantly,
the Linux protocol stack is not designed to operate in this manner.
IIIb. Tx operation
The RTL8129 uses a fixed set of four Tx descriptors in register space.
In a stunningly bad design choice, Tx frames must be 32 bit aligned. Linux
aligns the IP header on word boundaries, and 14 byte ethernet header means
that almost all frames will need to be copied to an alignment buffer.
IVb. References
http://www.realtek.com.tw/cn/cn.html
http://cesdis.gsfc.nasa.gov/linux/misc/NWay.html
IVc. Errata
/* This table drives the PCI probe routines. It's mostly boilerplate in all
of the drivers, and will likely be provided by some future kernel.
Note the matching code -- the first table entry matchs all 56** cards but
second only the 1234 card.
enum pci_flags_bit {
PCI_USES_IO=1, PCI_USES_MEM=2, PCI_USES_MASTER=4,
PCI_ADDR0=0x10<<0, PCI_ADDR1=0x10<<1, PCI_ADDR2=0x10<<2, PCI_ADDR3=0x10<<3,
struct pci_id_info {
const char *name;
u16 vendor_id, device_id, subvendor_id, subdevice_id, device_id_mask, flags;
int io_size;
struct device *(*probe1)(int pci_bus, int pci_devfn, struct device *dev,
long ioaddr, int irq, int chip_idx, int fnd_cnt);
static struct device * rtl8129_probe1(int pci_bus, int pci_devfn,
struct device *dev, long ioaddr,
int irq, int chp_idx, int fnd_cnt);
/* Note: change the marked constant in _attach() if the RTL8139B entry moves.*/
static struct pci_id_info pci_tbl[] =
{{ "RealTek RTL8129 Fast Ethernet",
0x10ec, 0x8129, 0x10ec, 0x8129, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "RealTek RTL8139 Fast Ethernet",
0x10ec, 0x8139, 0x10ec, 0x8139, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "D-Link DFE-538TX 10/100 Adpater",
0x1186, 0x1300, 0x1186, 0x1300, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "D-Link DFE-530TX+ PCI Adpater",
0x1186, 0x1300, 0x1186, 0x1301, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "RealTek RTL8139B PCI/CardBus",
0x10ec, 0x8138, 0x10ec, 0x8138, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "SMC1211TX EZCard 10/100 (RealTek RTL8139)",
0x1113, 0x1211, 0x1113, 0x1211, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "Accton MPX5030 (RealTek RTL8139)",
{ "AF-280 10/100Mbps Fast Ethernet CardBus PC Card",
0x10ec, 0x8138, 0x0246, 0x0003, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x0246, 0x0003, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "Addtron AF-260 10/100Mbps Fast Ethernet CardBus PC Card",
0x10ec, 0x8138, 0x0246, 0x0004, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x0246, 0x0005, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "32-bit CardBus 10/100 Ethernet(R5)",
0x10ec, 0x8138, 0x13e6, 0x0235, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x13e6, 0x0235, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "Billionton 10/100 Base-TX CardBus Ethernet",
0x10ec, 0x8138, 0x14cb, 0x0200, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x14cb, 0x0200, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "Edimax 10/100Mbps Fast Ethernet CardBus Adapter",
0x10ec, 0x8138, 0x1432, 0x4103, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x1432, 0x4103, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "CardBus 10/100Mbps Ethernet Card",
0x10ec, 0x8138, 0x142a, 0x0106, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x142a, 0x0107, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "RubyTech/Danpex FE-6439TX CardBus 10/100 Fast Ethernet Adapter",
0x10ec, 0x8138, 0x146c, 0x6439, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
0x10ec, 0x8139, 0x146c, 0x6439, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "SURECOM EP-428X 32-bit 100/10M CardBus PC Card",
0x10ec, 0x8138, 0x10bd, 0x0428, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{ "SURECOM EP-428X 32-bit 100/10M CArdBus PC Card",
0x10ec, 0x8139, 0x10bd, 0x0428, 0xffff, PCI_USES_IO|PCI_USES_MASTER, 0x80, rtl8129_probe1},
{0,}, /* 0 terminated list. */
/* The capability table matches the chip table above. */
enum {HAS_MII_XCVR=0x01, HAS_CHIP_XCVR=0x02, HAS_LNK_CHNG=0x04};
static int rtl_cap_tbl[] = {
HAS_MII_XCVR,
HAS_CHIP_XCVR|HAS_LNK_CHNG, HAS_CHIP_XCVR|HAS_LNK_CHNG,
/* The rest of these values should never change. */
#define NUM_TX_DESC 4 /* Number of Tx descriptor registers. */
/* Symbolic offsets to registers. */
enum RTL8129_registers {
MAC0=0, /* Ethernet hardware address. */
MAR0=8, /* Multicast filter. */
TxStatus0=0x10, /* Transmit status (Four 32bit registers). */
TxAddr0=0x20, /* Tx descriptors (also four 32bit). */
RxBuf=0x30, RxEarlyCnt=0x34, RxEarlyStatus=0x36,
ChipCmd=0x37, RxBufPtr=0x38, RxBufAddr=0x3A,
IntrMask=0x3C, IntrStatus=0x3E,
TxConfig=0x40, RxConfig=0x44,
Timer=0x48, /* A general-purpose counter. */
RxMissed=0x4C, /* 24 bits valid, write clears. */
Cfg9346=0x50, Config0=0x51, Config1=0x52,
FlashReg=0x54, GPPinData=0x58, GPPinDir=0x59, MII_SMI=0x5A, HltClk=0x5B,
MultiIntr=0x5C, TxSummary=0x60,
MII_BMCR=0x62, MII_BMSR=0x64, NWayAdvert=0x66, NWayLPAR=0x68,
NWayExpansion=0x6A,
/* Undocumented registers, but required for proper operation. */
FIFOTMS=0x70, /* FIFO Test Mode Select */
CSCR=0x74, /* Chip Status and Configuration Register. */
PARA78=0x78, PARA7c=0x7c, /* Magic transceiver parameter register. */
enum ChipCmdBits {
CmdReset=0x10, CmdRxEnb=0x08, CmdTxEnb=0x04, RxBufEmpty=0x01, };
/* Interrupt register bits, using my own meaningful names. */
enum IntrStatusBits {
PCIErr=0x8000, PCSTimeout=0x4000,
RxFIFOOver=0x40, RxUnderrun=0x20, RxOverflow=0x10,
TxErr=0x08, TxOK=0x04, RxErr=0x02, RxOK=0x01,
enum TxStatusBits {
TxHostOwns=0x2000, TxUnderrun=0x4000, TxStatOK=0x8000,
TxOutOfWindow=0x20000000, TxAborted=0x40000000, TxCarrierLost=0x80000000,
enum RxStatusBits {
RxMulticast=0x8000, RxPhysical=0x4000, RxBroadcast=0x2000,
RxBadSymbol=0x0020, RxRunt=0x0010, RxTooLong=0x0008, RxCRCErr=0x0004,
RxBadAlign=0x0002, RxStatusOK=0x0001,
/* Twister tuning parameters from RealTek.
Completely undocumented, but required to tune bad links. */
enum CSCRBits {
CSCR_LinkOKBit=0x0400, CSCR_LinkChangeBit=0x0800,
CSCR_LinkStatusBits=0x0f000, CSCR_LinkDownOffCmd=0x003c0,
CSCR_LinkDownCmd=0x0f3c0,
unsigned long param[4][4]={
{0x0cb39de43,0x0cb39ce43,0x0fb38de03,0x0cb38de43},
{0x0cb39de43,0x0cb39ce43,0x0cb39ce83,0x0cb39ce83},
{0x0bb39de43,0x0bb39ce43,0x0bb39ce83,0x0bb39ce83}
struct rtl8129_private {
char devname[8]; /* Used only for kernel debugging. */
const char *product_name;
struct device *next_module;
int chip_id;
int chip_revision;
unsigned char pci_bus, pci_devfn;
struct net_device_stats stats;
struct timer_list timer; /* Media selection timer. */
unsigned int cur_rx; /* Index into the Rx buffer of next Rx pkt. */
unsigned int cur_tx, dirty_tx, tx_flag;
unsigned long tx_full; /* The Tx queue is full. */
/* The saved address of a sent-in-place packet/buffer, for skfree(). */
struct sk_buff* tx_skbuff[NUM_TX_DESC];
unsigned char *tx_buf[NUM_TX_DESC]; /* Tx bounce buffers */
unsigned char *rx_ring;
unsigned char *tx_bufs; /* Tx bounce buffer region. */
char phys[4]; /* MII device addresses. */
char twistie, twist_cnt; /* Twister tune state. */
unsigned int full_duplex:1; /* Full-duplex operation requested. */
unsigned int duplex_lock:1;
unsigned int default_port:4; /* Last dev->if_port value. */
unsigned int media2:4; /* Secondary monitored media port. */
unsigned int medialock:1; /* Don't sense media type. */
unsigned int mediasense:1; /* Media sensing in progress. */
#ifdef MODULE
#if LINUX_VERSION_CODE > 0x20115
MODULE_AUTHOR("Donald Becker <becker@cesdis.gsfc.nasa.gov>");
MODULE_DESCRIPTION("RealTek RTL8129/8139 Fast Ethernet driver");
MODULE_PARM(options, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM(full_duplex, "1-" __MODULE_STRING(MAX_UNITS) "i");
MODULE_PARM(multicast_filter_limit, "i");
MODULE_PARM(max_interrupt_work, "i");
MODULE_PARM(debug, "i");
#endif
#endif
static int rtl8129_open(struct device *dev);
static int read_eeprom(long ioaddr, int location, int addr_len);
static int mdio_read(struct device *dev, int phy_id, int location);
static void mdio_write(struct device *dev, int phy_id, int location, int val);
static void rtl8129_timer(unsigned long data);
static void rtl8129_tx_timeout(struct device *dev);
static void rtl8129_init_ring(struct device *dev);
static int rtl8129_start_xmit(struct sk_buff *skb, struct device *dev);
static int rtl8129_rx(struct device *dev);
static void rtl8129_interrupt(int irq, void *dev_instance, struct pt_regs *regs);
static int rtl8129_close(struct device *dev);
static int mii_ioctl(struct device *dev, struct ifreq *rq, int cmd);
static struct enet_statistics *rtl8129_get_stats(struct device *dev);
static inline u32 ether_crc(int length, unsigned char *data);
static void set_rx_mode(struct device *dev);
/* A list of all installed RTL8129 devices, for removing the driver module. */
static struct device *root_rtl8129_dev = NULL;
/* Ideally we would detect all network cards in slot order. That would
be best done a central PCI probe dispatch, which wouldn't work
well when dynamically adding drivers. So instead we detect just the
Rtl81*9 cards in slot order. */
int rtl8139_probe(struct device *dev)
int cards_found = 0;
int pci_index = 0;
unsigned char pci_bus, pci_device_fn;
if ( ! pcibios_present())
return -ENODEV;
for (; pci_index < 0xff; pci_index++) {
u16 vendor, device, pci_command, new_command;
int chip_idx, irq;
long ioaddr;
if (pcibios_find_class (PCI_CLASS_NETWORK_ETHERNET << 8, pci_index,
&pci_bus, &pci_device_fn)
!= PCIBIOS_SUCCESSFUL)
break;
pcibios_read_config_word(pci_bus, pci_device_fn,
PCI_VENDOR_ID, &vendor);
PCI_DEVICE_ID, &device);
for (chip_idx = 0; pci_tbl[chip_idx].vendor_id; chip_idx++)
if (vendor == pci_tbl[chip_idx].vendor_id
&& (device & pci_tbl[chip_idx].device_id_mask) ==
pci_tbl[chip_idx].device_id)
break;
if (pci_tbl[chip_idx].vendor_id == 0) /* Compiled out! */
continue;
#if defined(PCI_SUPPORT_VER2)
struct pci_dev *pdev = pci_find_slot(pci_bus, pci_device_fn);
ioaddr = pdev->base_address[0] & ~3;
irq = pdev->irq;
#else
u32 pci_ioaddr;
u8 pci_irq_line;
pcibios_read_config_byte(pci_bus, pci_device_fn,
PCI_INTERRUPT_LINE, &pci_irq_line);
pcibios_read_config_dword(pci_bus, pci_device_fn,
PCI_BASE_ADDRESS_0, &pci_ioaddr);
ioaddr = pci_ioaddr & ~3;
irq = pci_irq_line;
#endif
if ((pci_tbl[chip_idx].flags & PCI_USES_IO) &&
check_region(ioaddr, pci_tbl[chip_idx].io_size))
continue;
/* Activate the card: fix for brain-damaged Win98 BIOSes. */
PCI_COMMAND, &pci_command);
new_command = pci_command | (pci_tbl[chip_idx].flags & 7);
if (pci_command != new_command) {
printk(KERN_INFO " The PCI BIOS has not enabled the"
" device at %d/%d! Updating PCI command %4.4x->%4.4x.\n",
pci_bus, pci_device_fn, pci_command, new_command);
pcibios_write_config_word(pci_bus, pci_device_fn,
PCI_COMMAND, new_command);
dev = pci_tbl[chip_idx].probe1(pci_bus, pci_device_fn, dev, ioaddr,
irq, chip_idx, cards_found);
if (dev && (pci_tbl[chip_idx].flags & PCI_COMMAND_MASTER)) {
u8 pci_latency;
PCI_LATENCY_TIMER, &pci_latency);
if (pci_latency < 32) {
printk(KERN_NOTICE " PCI latency timer (CFLT) is "
"unreasonably low at %d. Setting to 64 clocks.\n",
pci_latency);
pcibios_write_config_byte(pci_bus, pci_device_fn,
PCI_LATENCY_TIMER, 64);
dev = 0;
cards_found++;
return cards_found ? 0 : -ENODEV;
static struct device *rtl8129_probe1(int pci_bus, int pci_devfn,
int irq, int chip_idx, int found_cnt)
static int did_version = 0; /* Already printed version info. */
struct rtl8129_private *tp;
int i, option = found_cnt < MAX_UNITS ? options[found_cnt] : 0;
if (rtl8129_debug > 0 && did_version++ == 0)
printk(KERN_INFO "%s", version);
dev = init_etherdev(dev, 0);
printk(KERN_INFO "%s: %s at %#lx, IRQ %d, ",
dev->name, pci_tbl[chip_idx].name, ioaddr, irq);
/* Bring the chip out of low-power mode. */
outb(0x00, ioaddr + Config1);
int addr_len = read_eeprom(ioaddr, 0, 8) == 0x8129 ? 8 : 6;
for (i = 0; i < 3; i++)
((u16 *)(dev->dev_addr))[i] = read_eeprom(ioaddr, i+7, addr_len);
for (i = 0; i < 5; i++)
printk("%2.2x:", dev->dev_addr[i]);
printk("%2.2x.\n", dev->dev_addr[i]);
/* We do a request_region() to register /proc/ioports info. */
request_region(ioaddr, pci_tbl[chip_idx].io_size, dev->name);
dev->base_addr = ioaddr;
dev->irq = irq;
/* Some data structures must be quadword aligned. */
tp = kmalloc(sizeof(*tp), GFP_KERNEL | GFP_DMA);
memset(tp, 0, sizeof(*tp));
dev->priv = tp;
tp->next_module = root_rtl8129_dev;
root_rtl8129_dev = dev;
tp->chip_id = chip_idx;
tp->pci_bus = pci_bus;
tp->pci_devfn = pci_devfn;
/* Find the connected MII xcvrs.
Doing this in open() would allow detecting external xcvrs later, but
takes too much time. */
if (rtl_cap_tbl[chip_idx] & HAS_MII_XCVR) {
int phy, phy_idx;
for (phy = 0, phy_idx = 0; phy < 32 && phy_idx < sizeof(tp->phys);
phy++) {
int mii_status = mdio_read(dev, phy, 1);
if (mii_status != 0xffff && mii_status != 0x0000) {
tp->phys[phy_idx++] = phy;
printk(KERN_INFO "%s: MII transceiver found at address %d.\n",
dev->name, phy);
if (phy_idx == 0) {
printk(KERN_INFO "%s: No MII transceivers found! Assuming SYM "
"transceiver.\n",
dev->name);
tp->phys[0] = -1;
} else
tp->phys[0] = 32;
/* Put the chip into low-power mode. */
outb(0xC0, ioaddr + Cfg9346);
outb(0x03, ioaddr + Config1);
outb('H', ioaddr + HltClk); /* 'R' would leave the clock running. */
/* The lower four bits are the media type. */
if (option > 0) {
tp->full_duplex = (option & 0x200) ? 1 : 0;
tp->default_port = option & 15;
if (tp->default_port)
tp->medialock = 1;
if (found_cnt < MAX_UNITS && full_duplex[found_cnt] > 0)
tp->full_duplex = full_duplex[found_cnt];
if (tp->full_duplex) {
printk(KERN_INFO "%s: Media type forced to Full Duplex.\n", dev->name);
mdio_write(dev, tp->phys[0], 4, 0x141);
tp->duplex_lock = 1;
/* The Rtl8129-specific entries in the device structure. */
dev->open = &rtl8129_open;
dev->hard_start_xmit = &rtl8129_start_xmit;
dev->stop = &rtl8129_close;
dev->get_stats = &rtl8129_get_stats;
dev->set_multicast_list = &set_rx_mode;
dev->do_ioctl = &mii_ioctl;
return dev;
/* Serial EEPROM section. */
/* EEPROM_Ctrl bits. */
#define EE_SHIFT_CLK 0x04 /* EEPROM shift clock. */
#define EE_CS 0x08 /* EEPROM chip select. */
#define EE_DATA_WRITE 0x02 /* EEPROM chip data in. */
#define EE_WRITE_0 0x00
#define EE_WRITE_1 0x02
#define EE_DATA_READ 0x01 /* EEPROM chip data out. */
#define EE_ENB (0x80 | EE_CS)
/* Delay between EEPROM clock transitions.
No extra delay is needed with 33Mhz PCI, but 66Mhz may change this.
#define eeprom_delay() inl(ee_addr)
/* The EEPROM commands include the alway-set leading bit. */
#define EE_WRITE_CMD (5)
#define EE_READ_CMD (6)
#define EE_ERASE_CMD (7)
int i;
unsigned retval = 0;
long ee_addr = ioaddr + Cfg9346;
int read_cmd = location | (EE_READ_CMD << addr_len);
outb(EE_ENB & ~EE_CS, ee_addr);
outb(EE_ENB, ee_addr);
/* Shift the read command bits out. */
for (i = 4 + addr_len; i >= 0; i--) {
int dataval = (read_cmd & (1 << i)) ? EE_DATA_WRITE : 0;
outb(EE_ENB | dataval, ee_addr);
eeprom_delay();
outb(EE_ENB | dataval | EE_SHIFT_CLK, ee_addr);
eeprom_delay();
eeprom_delay();
for (i = 16; i > 0; i--) {
outb(EE_ENB | EE_SHIFT_CLK, ee_addr);
eeprom_delay();
retval = (retval << 1) | ((inb(ee_addr) & EE_DATA_READ) ? 1 : 0);
eeprom_delay();
/* Terminate the EEPROM access. */
outb(~EE_CS, ee_addr);
return retval;
/* MII serial management: mostly bogus for now. */
/* Read and write the MII management registers using software-generated
serial MDIO protocol.
The maximum data clock rate is 2.5 Mhz. The minimum timing is usually
met by back-to-back PCI I/O cycles, but we insert a delay to avoid
"overclocking" issues. */
#define MDIO_DIR 0x80
#define MDIO_DATA_OUT 0x04
#define MDIO_DATA_IN 0x02
#define MDIO_CLK 0x01
#define MDIO_WRITE0 (MDIO_DIR)
#define MDIO_WRITE1 (MDIO_DIR | MDIO_DATA_OUT)
#define mdio_delay() inb(mdio_addr)
static char mii_2_8139_map[8] = {MII_BMCR, MII_BMSR, 0, 0, NWayAdvert,
NWayLPAR, NWayExpansion, 0 };
/* Syncronize the MII management interface by shifting 32 one bits out. */
static void mdio_sync(long mdio_addr)
int i;
for (i = 32; i >= 0; i--) {
outb(MDIO_WRITE1, mdio_addr);
mdio_delay();
outb(MDIO_WRITE1 | MDIO_CLK, mdio_addr);
mdio_delay();
return;
long mdio_addr = dev->base_addr + MII_SMI;
int mii_cmd = (0xf6 << 10) | (phy_id << 5) | location;
int retval = 0;
int i;
if (phy_id > 31) { /* Really a 8139. Use internal registers. */
return location < 8 && mii_2_8139_map[location] ?
inw(dev->base_addr + mii_2_8139_map[location]) : 0;
mdio_sync(mdio_addr);
for (i = 15; i >= 0; i--) {
int dataval = (mii_cmd & (1 << i)) ? MDIO_DATA_OUT : 0;
outb(MDIO_DIR | dataval, mdio_addr);
mdio_delay();
outb(MDIO_DIR | dataval | MDIO_CLK, mdio_addr);
mdio_delay();
/* Read the two transition, 16 data, and wire-idle bits. */
for (i = 19; i > 0; i--) {
outb(0, mdio_addr);
mdio_delay();
retval = (retval << 1) | ((inb(mdio_addr) & MDIO_DATA_IN) ? 1 : 0);
outb(MDIO_CLK, mdio_addr);
mdio_delay();
return (retval>>1) & 0xffff;
static void mdio_write(struct device *dev, int phy_id, int location, int value)
int mii_cmd = (0x5002 << 16) | (phy_id << 23) | (location<<18) | value;
int i;
if (location < 8 && mii_2_8139_map[location])
outw(value, dev->base_addr + mii_2_8139_map[location]);
return;
/* Shift the command bits out. */
for (i = 31; i >= 0; i--) {
int dataval = (mii_cmd & (1 << i)) ? MDIO_WRITE1 : MDIO_WRITE0;
outb(dataval, mdio_addr);
mdio_delay();
outb(dataval | MDIO_CLK, mdio_addr);
mdio_delay();
/* Clear out extra bits. */
for (i = 2; i > 0; i--) {
outb(0, mdio_addr);
mdio_delay();
mdio_delay();
return;
static int
struct rtl8129_private *tp = (struct rtl8129_private *)dev->priv;
long ioaddr = dev->base_addr;
int i;
/* Soft reset the chip. */
outb(CmdReset, ioaddr + ChipCmd);
if (request_irq(dev->irq, &rtl8129_interrupt, SA_SHIRQ, dev->name, dev)) {
return -EAGAIN;
MOD_INC_USE_COUNT;
tp->tx_bufs = kmalloc(TX_BUF_SIZE * NUM_TX_DESC, GFP_KERNEL);
tp->rx_ring = kmalloc(RX_BUF_LEN + 16, GFP_KERNEL);
if (tp->tx_bufs == NULL || tp->rx_ring == NULL) {
if (tp->tx_bufs)
kfree(tp->tx_bufs);
if (rtl8129_debug > 0)
printk(KERN_ERR "%s: Couldn't allocate a %d byte receive ring.\n",
dev->name, RX_BUF_LEN);
return -ENOMEM;
rtl8129_init_ring(dev);
/* Check that the chip has finished the reset. */
for (i = 1000; i > 0; i--)
if ((inb(ioaddr + ChipCmd) & CmdReset) == 0)
break;
for (i = 0; i < 6; i++)
outb(dev->dev_addr[i], ioaddr + MAC0 + i);
/* Must enable Tx/Rx before setting transfer thresholds! */
outb(CmdRxEnb | CmdTxEnb, ioaddr + ChipCmd);
outl((RX_FIFO_THRESH << 13) | (RX_BUF_LEN_IDX << 11) | (RX_DMA_BURST<<8),
ioaddr + RxConfig);
outl((TX_DMA_BURST<<8)|0x03000000, ioaddr + TxConfig);
tp->tx_flag = (TX_FIFO_THRESH<<11) & 0x003f0000;
tp->full_duplex = tp->duplex_lock;
if (tp->phys[0] >= 0 || (rtl_cap_tbl[tp->chip_id] & HAS_MII_XCVR)) {
u16 mii_reg5 = mdio_read(dev, tp->phys[0], 5);
if (mii_reg5 == 0xffff)
; /* Not there */
else if ((mii_reg5 & 0x0100) == 0x0100
|| (mii_reg5 & 0x00C0) == 0x0040)
tp->full_duplex = 1;
if (rtl8129_debug > 1)
printk(KERN_INFO"%s: Setting %s%s-duplex based on"
" auto-negotiated partner ability %4.4x.\n", dev->name,
mii_reg5 == 0 ? "" :
(mii_reg5 & 0x0180) ? "100mbps " : "10mbps ",
tp->full_duplex ? "full" : "half", mii_reg5);
outb(tp->full_duplex ? 0x60 : 0x20, ioaddr + Config1);
outb(0x00, ioaddr + Cfg9346);
outl(virt_to_bus(tp->rx_ring), ioaddr + RxBuf);
/* Start the chip's Tx and Rx process. */
outl(0, ioaddr + RxMissed);
set_rx_mode(dev);
dev->tbusy = 0;
dev->interrupt = 0;
dev->start = 1;
/* Enable all known interrupts by setting the interrupt mask. */
outw(PCIErr | PCSTimeout | RxUnderrun | RxOverflow | RxFIFOOver
| TxErr | TxOK | RxErr | RxOK, ioaddr + IntrMask);
printk(KERN_DEBUG"%s: rtl8129_open() ioaddr %#lx IRQ %d"
" GP Pins %2.2x %s-duplex.\n",
dev->name, ioaddr, dev->irq, inb(ioaddr + GPPinData),
tp->full_duplex ? "full" : "half");
/* Set the timer to switch to check for link beat and perhaps switch
to an alternate media type. */
init_timer(&tp->timer);
tp->timer.expires = RUN_AT((24*HZ)/10); /* 2.4 sec. */
tp->timer.data = (unsigned long)dev;
tp->timer.function = &rtl8129_timer;
add_timer(&tp->timer);
return 0;
struct device *dev = (struct device *)data;
int next_tick = 60*HZ;
int mii_reg5 = mdio_read(dev, tp->phys[0], 5);
if (! tp->duplex_lock && mii_reg5 != 0xffff) {
int duplex = (mii_reg5&0x0100) || (mii_reg5 & 0x01C0) == 0x0040;
if (tp->full_duplex != duplex) {
tp->full_duplex = duplex;
printk(KERN_INFO "%s: Setting %s-duplex based on MII #%d link"
" partner ability of %4.4x.\n", dev->name,
tp->full_duplex ? "full" : "half", tp->phys[0], mii_reg5);
/* Check for bogusness. */
if (inw(ioaddr + IntrStatus) & (TxOK | RxOK)) {
int status = inw(ioaddr + IntrStatus);
if (status & (TxOK | RxOK)) { /* Double check */
printk(KERN_ERR "%s: RTL8139 Interrupt line blocked, status %x.\n",
dev->name, status);
rtl8129_interrupt(dev->irq, dev, 0);
if (dev->tbusy && jiffies - dev->trans_start >= 2*TX_TIMEOUT)
rtl8129_tx_timeout(dev);
#if 0
if (tp->twistie) {
unsigned int CSCRval = inw(ioaddr + CSCR); /* Read link status. */
if (tp->twistie == 1) {
if (CSCRval & CSCR_LinkOKBit) {
outw(CSCR_LinkDownOffCmd, ioaddr + CSCR);
tp->twistie = 2;
next_tick = HZ/10;
} else {
outw(CSCR_LinkDownCmd, ioaddr + CSCR);
outl(FIFOTMS_default,ioaddr + FIFOTMS);
outl(PARA78_default ,ioaddr + PARA78);
outl(PARA7c_default ,ioaddr + PARA7c);
tp->twistie = 0;
} else if (tp->twistie == 2) {
int linkcase = (CSCRval & CSCR_LinkStatusBits) >> 12;
int row;
if (linkcase >= 0x7000) row = 3;
else if (linkcase >= 0x3000) row = 2;
else if (linkcase >= 0x1000) row = 1;
else row = 0;
tp->twistie == row + 3;
outw(0,ioaddr+FIFOTMS);
outl(param[row][0], ioaddr+PARA7c);
tp->twist_cnt = 1;
} else {
outl(param[tp->twistie-3][tp->twist_cnt], ioaddr+PARA7c);
if (++tp->twist_cnt < 4) {
next_tick = HZ/10;
} else if (tp->twistie-3 == 3) {
if ((CSCRval & CSCR_LinkStatusBits) != 0x7000) {
outl(PARA7c_xxx, ioaddr+PARA7c);
next_tick = HZ/10; /* 100ms. */
outl(FIFOTMS_default, ioaddr+FIFOTMS);
outl(PARA78_default, ioaddr+PARA78);
outl(PARA7c_default, ioaddr+PARA7c);
tp->twistie == 3 + 3;
outl(param[3][0], ioaddr+PARA7c);
tp->twist_cnt = 1;
#endif
if (rtl8129_debug > 2) {
if (rtl_cap_tbl[tp->chip_id] & HAS_MII_XCVR)
printk(KERN_DEBUG"%s: Media selection tick, GP pins %2.2x.\n",
dev->name, inb(ioaddr + GPPinData));
else
printk(KERN_DEBUG"%s: Media selection tick, Link partner %4.4x.\n",
dev->name, inw(ioaddr + NWayLPAR));
printk(KERN_DEBUG"%s: Other registers are IntMask %4.4x IntStatus %4.4x"
" RxStatus %4.4x.\n",
dev->name, inw(ioaddr + IntrMask), inw(ioaddr + IntrStatus),
inl(ioaddr + RxEarlyStatus));
printk(KERN_DEBUG"%s: Chip config %2.2x %2.2x.\n",
dev->name, inb(ioaddr + Config0), inb(ioaddr + Config1));
tp->timer.expires = RUN_AT(next_tick);
int mii_reg, i;
printk(KERN_WARNING "%s: Transmit timeout, status %2.2x %4.4x "
"media %2.2x.\n",
dev->name, inb(ioaddr + ChipCmd), inw(ioaddr + IntrStatus),
/* Disable interrupts by clearing the interrupt mask. */
outw(0x0000, ioaddr + IntrMask);
/* Emit info to figure out what went wrong. */
printk("%s: Tx queue start entry %d dirty entry %d%s.\n",
dev->name, tp->cur_tx, tp->dirty_tx, tp->tx_full ? ", full" : "");
for (i = 0; i < NUM_TX_DESC; i++)
printk(KERN_DEBUG"%s: Tx descriptor %d is %8.8x.%s\n",
dev->name, i, inl(ioaddr + TxStatus0 + i*4),
i == tp->dirty_tx % NUM_TX_DESC ? " (queue head)" : "");
printk(KERN_DEBUG"%s: MII #%d registers are:", dev->name, tp->phys[0]);
for (mii_reg = 0; mii_reg < 8; mii_reg++)
printk(" %4.4x", mdio_read(dev, tp->phys[0], mii_reg));
printk(".\n");
break;
tp->cur_rx = 0;
ioaddr + RxConfig);
outl((TX_DMA_BURST<<8), ioaddr + TxConfig);
set_rx_mode(dev);
{ /* Save the unsent Tx packets. */
struct sk_buff *saved_skb[NUM_TX_DESC], *skb;
int j;
for (j = 0; tp->cur_tx - tp->dirty_tx > 0 ; j++, tp->dirty_tx++)
saved_skb[j] = tp->tx_skbuff[tp->dirty_tx % NUM_TX_DESC];
tp->dirty_tx = tp->cur_tx = 0;
for (i = 0; i < j; i++) {
skb = tp->tx_skbuff[i] = saved_skb[i];
if ((long)skb->data & 3) { /* Must use alignment buffer. */
memcpy(tp->tx_buf[i], skb->data, skb->len);
outl(virt_to_bus(tp->tx_buf[i]), ioaddr + TxAddr0 + i*4);
} else
outl(virt_to_bus(skb->data), ioaddr + TxAddr0 + i*4);
/* Note: the chip doesn't have auto-pad! */
outl(tp->tx_flag | (skb->len >= ETH_ZLEN ? skb->len : ETH_ZLEN),
ioaddr + TxStatus0 + i*4);
tp->cur_tx = i;
while (i < NUM_TX_DESC)
tp->tx_skbuff[i++] = 0;
if (tp->cur_tx - tp->dirty_tx < NUM_TX_DESC) {/* Typical path */
dev->tbusy = 0;
tp->tx_full = 0;
} else {
tp->tx_full = 1;
dev->trans_start = jiffies;
tp->stats.tx_errors++;
return;
/* Initialize the Rx and Tx rings, along with various 'dev' bits. */
static void
int i;
tp->tx_full = 0;
tp->cur_rx = 0;
for (i = 0; i < NUM_TX_DESC; i++) {
tp->tx_skbuff[i] = 0;
tp->tx_buf[i] = &tp->tx_bufs[i*TX_BUF_SIZE];
static int
int entry;
/* Block a timer-based transmit from overlapping. This could better be
done with atomic_swap(1, dev->tbusy), but set_bit() works as well. */
if (test_and_set_bit(0, (void*)&dev->tbusy) != 0) {
if (jiffies - dev->trans_start >= TX_TIMEOUT)
return 1;
/* Calculate the next Tx descriptor entry. */
entry = tp->cur_tx % NUM_TX_DESC;
tp->tx_skbuff[entry] = skb;
memcpy(tp->tx_buf[entry], skb->data, skb->len);
outl(virt_to_bus(tp->tx_buf[entry]), ioaddr + TxAddr0 + entry*4);
} else
outl(virt_to_bus(skb->data), ioaddr + TxAddr0 + entry*4);
ioaddr + TxStatus0 + entry*4);
/* There is a race condition here -- we might read dirty_tx, take an
interrupt that clears the Tx queue, and only then set tx_full.
So we do this in two phases. */
if (++tp->cur_tx - tp->dirty_tx < NUM_TX_DESC) /* Typical path */
clear_bit(0, (void*)&dev->tbusy);
else {
set_bit(0, &tp->tx_full);
clear_bit(0, &tp->tx_full);
if (rtl8129_debug > 4)
printk(KERN_DEBUG"%s: Queued Tx packet at %p size %d to slot %d.\n",
dev->name, skb->data, (int)skb->len, entry);
return 0;
/* The interrupt handler does all of the Rx thread work and cleans up
after the Tx thread. */
struct device *dev = (struct device *)dev_instance;
int boguscnt = max_interrupt_work;
int status, link_changed = 0;
#if defined(__i386__)
/* A lock to prevent simultaneous entry bug on Intel SMP machines. */
if (test_and_set_bit(0, (void*)&dev->interrupt)) {
printk(KERN_ERR"%s: SMP simultaneous entry of an interrupt handler.\n",
dev->name);
dev->interrupt = 0; /* Avoid halting machine. */
return;
#else
if (dev->interrupt) {
printk(KERN_ERR "%s: Re-entering the interrupt handler.\n", dev->name);
return;
dev->interrupt = 1;
#endif
do {
/* Acknowledge all of the current interrupt sources ASAP, but
an first get an additional status bit from CSCR. */
if ((status & RxUnderrun) && inw(ioaddr+CSCR) & CSCR_LinkChangeBit)
link_changed = 1;
outw(status, ioaddr + IntrStatus);
printk(KERN_DEBUG"%s: interrupt status=%#4.4x new intstat=%#4.4x.\n",
dev->name, status, inw(ioaddr + IntrStatus));
if ((status & (PCIErr|PCSTimeout|RxUnderrun|RxOverflow|RxFIFOOver
|TxErr|TxOK|RxErr|RxOK)) == 0)
break;
if (status & (RxOK|RxUnderrun|RxOverflow|RxFIFOOver))/* Rx interrupt */
rtl8129_rx(dev);
if (status & (TxOK | TxErr)) {
unsigned int dirty_tx = tp->dirty_tx;
while (tp->cur_tx - dirty_tx > 0) {
int entry = dirty_tx % NUM_TX_DESC;
int txstatus = inl(ioaddr + TxStatus0 + entry*4);
if ( ! (txstatus & (TxStatOK | TxUnderrun | TxAborted)))
break; /* It still hasn't been Txed */
/* Note: TxCarrierLost is always asserted at 100mbps. */
if (txstatus & (TxOutOfWindow | TxAborted)) {
/* There was an major error, log it. */
printk(KERN_NOTICE"%s: Transmit error, Tx status %8.8x.\n",
dev->name, txstatus);
if (txstatus&TxAborted) {
tp->stats.tx_aborted_errors++;
outl((TX_DMA_BURST<<8)|0x03000001, ioaddr + TxConfig);
if (txstatus&TxCarrierLost) tp->stats.tx_carrier_errors++;
if (txstatus&TxOutOfWindow) tp->stats.tx_window_errors++;
#ifdef ETHER_STATS
if ((txstatus & 0x0f000000) == 0x0f000000)
tp->stats.collisions16++;
#endif
} else {
if (txstatus & TxUnderrun) {
/* Add 64 to the Tx FIFO threshold. */
if (tp->tx_flag < 0x00300000)
tp->tx_flag += 0x00020000;
tp->stats.tx_fifo_errors++;
tp->stats.collisions += (txstatus >> 24) & 15;
#if LINUX_VERSION_CODE > 0x20119
tp->stats.tx_bytes += txstatus & 0x7ff;
#endif
tp->stats.tx_packets++;
/* Free the original skb. */
dev_free_skb(tp->tx_skbuff[entry]);
tp->tx_skbuff[entry] = 0;
if (test_bit(0, &tp->tx_full)) {
/* The ring is no longer full, clear tbusy. */
mark_bh(NET_BH);
dirty_tx++;
#ifndef final_version
if (tp->cur_tx - dirty_tx > NUM_TX_DESC) {
printk(KERN_ERR"%s: Out-of-sync dirty pointer, %d vs. %d, full=%d.\n",
dev->name, dirty_tx, tp->cur_tx, (int)tp->tx_full);
dirty_tx += NUM_TX_DESC;
#endif
tp->dirty_tx = dirty_tx;
/* Check uncommon events with one test. */
if (status & (PCIErr|PCSTimeout |RxUnderrun|RxOverflow|RxFIFOOver
|TxErr|RxErr)) {
printk(KERN_NOTICE"%s: Abnormal interrupt, status %8.8x.\n",
dev->name, status);
if (status == 0xffffffff)
break;
/* Update the error count. */
tp->stats.rx_missed_errors += inl(ioaddr + RxMissed);
if ((status & RxUnderrun) && link_changed &&
(rtl_cap_tbl[tp->chip_id] & HAS_LNK_CHNG)) {
/* Really link-change on new chips. */
int lpar = inw(ioaddr + NWayLPAR);
int duplex = (lpar&0x0100)||(lpar & 0x01C0) == 0x0040;
status &= ~RxUnderrun;
if (status & (RxUnderrun | RxOverflow | RxErr | RxFIFOOver))
tp->stats.rx_errors++;
if (status & (PCSTimeout)) tp->stats.rx_length_errors++;
if (status & (RxUnderrun|RxFIFOOver)) tp->stats.rx_fifo_errors++;
if (status & RxOverflow) {
tp->stats.rx_over_errors++;
tp->cur_rx = inw(ioaddr + RxBufAddr) % RX_BUF_LEN;
outw(tp->cur_rx - 16, ioaddr + RxBufPtr);
if (status & PCIErr) {
u32 pci_cmd_status;
pcibios_read_config_dword(tp->pci_bus, tp->pci_devfn,
PCI_COMMAND, &pci_cmd_status);
printk(KERN_ERR "%s: PCI Bus error %4.4x.\n",
dev->name, pci_cmd_status);
if (--boguscnt < 0) {
printk(KERN_WARNING"%s: Too much work at interrupt, "
"IntrStatus=0x%4.4x.\n",
dev->name, status);
/* Clear all interrupt sources. */
outw(0xffff, ioaddr + IntrStatus);
break;
} while (1);
if (rtl8129_debug > 3)
printk(KERN_DEBUG"%s: exiting interrupt, intr_status=%#4.4x.\n",
dev->name, inl(ioaddr + IntrStatus));
clear_bit(0, (void*)&dev->interrupt);
#else
dev->interrupt = 0;
#endif
return;
/* The data sheet doesn't describe the Rx ring at all, so I'm guessing at the
field alignments and semantics. */
unsigned char *rx_ring = tp->rx_ring;
u16 cur_rx = tp->cur_rx;
printk(KERN_DEBUG"%s: In rtl8129_rx(), current %4.4x BufAddr %4.4x,"
" free to %4.4x, Cmd %2.2x.\n",
dev->name, cur_rx, inw(ioaddr + RxBufAddr),
inw(ioaddr + RxBufPtr), inb(ioaddr + ChipCmd));
while ((inb(ioaddr + ChipCmd) & 1) == 0) {
int ring_offset = cur_rx % RX_BUF_LEN;
u32 rx_status = *(u32*)(rx_ring + ring_offset);
int rx_size = rx_status >> 16;
if (rtl8129_debug > 4) {
int i;
printk(KERN_DEBUG"%s: rtl8129_rx() status %4.4x, size %4.4x,"
" cur %4.4x.\n",
dev->name, rx_status, rx_size, cur_rx);
printk(KERN_DEBUG"%s: Frame contents ", dev->name);
for (i = 0; i < 70; i++)
printk(" %2.2x", rx_ring[ring_offset + i]);
printk(".\n");
if (rx_status & RxTooLong) {
printk(KERN_NOTICE"%s: Oversized Ethernet frame, status %4.4x!\n",
dev->name, rx_status);
/* A.C.: The chip hangs here. */
} else if (rx_status &
(RxBadSymbol|RxRunt|RxTooLong|RxCRCErr|RxBadAlign)) {
printk(KERN_DEBUG"%s: Ethernet frame had errors,"
" status %4.4x.\n", dev->name, rx_status);
if (rx_status & (RxBadSymbol|RxBadAlign))
tp->stats.rx_frame_errors++;
if (rx_status & (RxRunt|RxTooLong)) tp->stats.rx_length_errors++;
if (rx_status & RxCRCErr) tp->stats.rx_crc_errors++;
/* Reset the receiver, based on RealTek recommendation. (Bug?) */
tp->cur_rx = 0;
outb(CmdTxEnb, ioaddr + ChipCmd);
(RX_DMA_BURST<<8), ioaddr + RxConfig);
/* A.C.: Reset the multicast list. */
set_rx_mode(dev);
} else {
/* Malloc up new buffer, compatible with net-2e. */
/* Omit the four octet CRC from the length. */
struct sk_buff *skb;
skb = dev_alloc_skb(rx_size + 2);
if (skb == NULL) {
printk(KERN_WARNING"%s: Memory squeeze, deferring packet.\n",
dev->name);
/* We should check that some rx space is free.
If not, free one and mark stats->rx_dropped++. */
tp->stats.rx_dropped++;
break;
skb->dev = dev;
skb_reserve(skb, 2); /* 16 byte align the IP fields. */
if (ring_offset+rx_size+4 > RX_BUF_LEN) {
int semi_count = RX_BUF_LEN - ring_offset - 4;
memcpy(skb_put(skb, semi_count), &rx_ring[ring_offset + 4],
semi_count);
memcpy(skb_put(skb, rx_size-semi_count), rx_ring,
rx_size-semi_count);
int i;
printk(KERN_DEBUG"%s: Frame wrap @%d",
dev->name, semi_count);
for (i = 0; i < 16; i++)
printk(" %2.2x", rx_ring[i]);
printk(".\n");
memset(rx_ring, 0xcc, 16);
} else {
#if 1 /* USE_IP_COPYSUM */
eth_copy_and_sum(skb, &rx_ring[ring_offset + 4],
rx_size, 0);
skb_put(skb, rx_size);
#else
memcpy(skb_put(skb, rx_size), &rx_ring[ring_offset + 4],
rx_size);
#endif
skb->protocol = eth_type_trans(skb, dev);
netif_rx(skb);
tp->stats.rx_bytes += rx_size;
#endif
tp->stats.rx_packets++;
cur_rx = (cur_rx + rx_size + 4 + 3) & ~3;
outw(cur_rx - 16, ioaddr + RxBufPtr);
printk(KERN_DEBUG"%s: Done rtl8129_rx(), current %4.4x BufAddr %4.4x,"
tp->cur_rx = cur_rx;
return 0;
static int
int i;
dev->start = 0;
dev->tbusy = 1;
printk(KERN_DEBUG"%s: Shutting down ethercard, status was 0x%4.4x.\n",
dev->name, inw(ioaddr + IntrStatus));
/* Stop the chip's Tx and Rx DMA processes. */
outb(0x00, ioaddr + ChipCmd);
/* Update the error counts. */
del_timer(&tp->timer);
free_irq(dev->irq, dev);
if (tp->tx_skbuff[i])
dev_free_skb(tp->tx_skbuff[i]);
kfree(tp->rx_ring);
kfree(tp->tx_bufs);
/* Green! Put the chip in low-power mode. */
MOD_DEC_USE_COUNT;
return 0;
u16 *data = (u16 *)&rq->ifr_data;
switch(cmd) {
case SIOCDEVPRIVATE: /* Get the address of the PHY in use. */
data[0] = tp->phys[0] & 0x3f;
/* Fall Through */
case SIOCDEVPRIVATE+1: /* Read the specified MII register. */
data[3] = mdio_read(dev, data[0], data[1] & 0x1f);
return 0;
case SIOCDEVPRIVATE+2: /* Write the specified MII register */
if (!capable(CAP_NET_ADMIN))
return -EPERM;
mdio_write(dev, data[0], data[1] & 0x1f, data[2]);
return 0;
default:
return -EOPNOTSUPP;
if (dev->start) {
return &tp->stats;
/* Set or clear the multicast filter for this adaptor.
This routine is not state sensitive and need not be SMP locked. */
static unsigned const ethernet_polynomial = 0x04c11db7U;
int crc = -1;
while (--length >= 0) {
unsigned char current_octet = *data++;
int bit;
for (bit = 0; bit < 8; bit++, current_octet >>= 1)
crc = (crc << 1) ^
((crc < 0) ^ (current_octet & 1) ? ethernet_polynomial : 0);
return crc;
/* Bits in RxConfig. */
enum rx_mode_bits {
AcceptErr=0x20, AcceptRunt=0x10, AcceptBroadcast=0x08,
AcceptMulticast=0x04, AcceptMyPhys=0x02, AcceptAllPhys=0x01,
u32 mc_filter[2]; /* Multicast hash filter */
int i, rx_mode;
printk(KERN_DEBUG"%s: set_rx_mode(%4.4x) done -- Rx config %8.8x.\n",
dev->name, dev->flags, inl(ioaddr + RxConfig));
/* Note: do not reorder, GCC is clever about common statements. */
if (dev->flags & IFF_PROMISC) {
/* Unconditionally log net taps. */
printk(KERN_NOTICE"%s: Promiscuous mode enabled.\n", dev->name);
rx_mode = AcceptBroadcast|AcceptMulticast|AcceptMyPhys|AcceptAllPhys;
mc_filter[1] = mc_filter[0] = 0xffffffff;
} else if ((dev->mc_count > multicast_filter_limit)
|| (dev->flags & IFF_ALLMULTI)) {
/* Too many to filter perfectly -- accept all multicasts. */
rx_mode = AcceptBroadcast | AcceptMulticast | AcceptMyPhys;
} else {
struct dev_mc_list *mclist;
mc_filter[1] = mc_filter[0] = 0;
for (i = 0, mclist = dev->mc_list; mclist && i < dev->mc_count;
i++, mclist = mclist->next)
set_bit(ether_crc(ETH_ALEN, mclist->dmi_addr) >> 26, mc_filter);
/* We can safely update without stopping the chip. */
outb(rx_mode, ioaddr + RxConfig);
outl(mc_filter[0], ioaddr + MAR0 + 0);
outl(mc_filter[1], ioaddr + MAR0 + 4);
return;
#ifdef CARDBUS
#include <pcmcia/driver_ops.h>
static dev_node_t *rtl8139_attach(dev_locator_t *loc)
struct device *dev;
u16 dev_id;
u32 io;
u8 bus, devfn, irq;
//========== Clifford Chiang Added
u8 bus_index, dev_index, chip_idx, brg_bus=0, brg_devfn = 0;
u16 brg_irq, brg_reg, ven_id, subven_id, subdev_id;
u32 brg_class;
if (loc->bus != LOC_PCI) return NULL;
bus = loc->b.pci.bus; devfn = loc->b.pci.devfn;
printk(KERN_INFO "rtl8139_attach(bus %d, function %d)\n", bus, devfn);
pcibios_read_config_dword(bus, devfn, PCI_BASE_ADDRESS_0, &io);
pcibios_read_config_word(bus, devfn, PCI_DEVICE_ID, &dev_id);
pcibios_read_config_byte(bus, devfn, PCI_INTERRUPT_LINE, &irq);
//======= The driver needs to solve interrupt problem befor it is loaded
//========================================== Clifford Chiang Feb/20/2000
for(bus_index=0; bus_index<0xF; bus_index++)
for(dev_index=0; dev_index<255; dev_index++)
pcibios_read_config_dword (
bus_index,
dev_index,
0x08,
&brg_class);
if((brg_class & 0xFFFFFF00) == 0x06070000)
pcibios_read_config_word(bus_index, dev_index, 0x18, &brg_reg);
brg_reg=brg_reg >> 8;
if(brg_reg==loc->b.pci.bus)
{ brg_devfn=dev_index;
brg_bus=bus_index;
break;
pcibios_read_config_word(brg_bus, brg_devfn, 0x3C, &brg_irq);
brg_irq=brg_irq & 0xFF;
if(brg_irq!=0x0 && brg_irq!=0xFF)
irq=brg_irq;
pcibios_write_config_byte(brg_bus, brg_devfn, 0x3E, 0x0);
pcibios_write_config_byte(brg_bus, brg_devfn, 0x3F, 0x05);
pcibios_write_config_dword(brg_bus, brg_devfn, 0x90, 0x006031C0);
/* Note: the chip index should match the 8139B pci_tbl[] entry. */
//============ Select an entry from pci_tbl[] ============================
pcibios_read_config_word(bus, devfn, PCI_VENDOR_ID, &ven_id);
pcibios_read_config_word(bus, devfn, PCI_SUBSYSTEM_VENDOR_ID, &subven_id);
pcibios_read_config_word(bus, devfn, PCI_SUBSYSTEM_ID, &subdev_id);
if ( (ven_id == pci_tbl[chip_idx].vendor_id)
&& (dev_id == pci_tbl[chip_idx].device_id)
&& (subven_id == pci_tbl[chip_idx].subvendor_id)
&& (subdev_id == pci_tbl[chip_idx].subdevice_id) )
break;
dev = rtl8129_probe1(bus, devfn, NULL, io & ~3, irq, chip_idx, 0);
if (dev) {
dev_node_t *node = kmalloc(sizeof(dev_node_t), GFP_KERNEL);
strcpy(node->dev_name, dev->name);
node->major = node->minor = 0;
node->next = NULL;
MOD_INC_USE_COUNT;
return node;
return NULL;
static void rtl8139_detach(dev_node_t *node)
struct device **devp, **next;
printk(KERN_INFO "rtl8139_detach(%s)\n", node->dev_name);
for (devp = &root_rtl8129_dev; *devp; devp = next) {
next = &((struct rtl8129_private *)(*devp)->priv)->next_module;
if (strcmp((*devp)->name, node->dev_name) == 0) break;
if (*devp) {
unregister_netdev(*devp);
kfree(*devp);
*devp = *next;
kfree(node);
MOD_DEC_USE_COUNT;
struct driver_operations realtek_ops = {
"realtek_cb",
rtl8139_attach, /*rtl8139_suspend*/0, /*rtl8139_resume*/0, rtl8139_detach
#endif /* Cardbus support */
#ifdef MODULE
int init_module(void)
if (debug) /* Emit version even if no cards detected. */
#ifdef CARDBUS
register_driver(&realtek_ops);
return 0;
#else
return rtl8139_probe(0);
#endif
void
cleanup_module(void)
struct device *next_dev;
#ifdef CARDBUS
unregister_driver(&realtek_ops);
#endif
/* No need to check MOD_IN_USE, as sys_delete_module() checks. */
while (root_rtl8129_dev) {
(struct rtl8129_private *)root_rtl8129_dev->priv;
next_dev = tp->next_module;
unregister_netdev(root_rtl8129_dev);
release_region(root_rtl8129_dev->base_addr,
pci_tbl[tp->chip_id].io_size);
kfree(tp);
kfree(root_rtl8129_dev);
root_rtl8129_dev = next_dev;
#endif /* MODULE */
* Local variables:
* compile-command: "gcc -DMODULE -D__KERNEL__ -Wall -Wstrict-prototypes -O6 -c rtl8139.c `[ -f /usr/include/linux/modversions.h ] && echo -DMODVERSIONS`"
* SMP-compile-command: "gcc -D__SMP__ -DMODULE -D__KERNEL__ -Wall -Wstrict-prototypes -O6 -c rtl8139.c `[ -f /usr/include/linux/modversions.h ] && echo -DMODVERSIONS`"
* cardbus-compile-command: "gcc -DCARDBUS -DMODULE -D__KERNEL__ -Wall -Wstrict-prototypes -O6 -c rtl8139.c -o realtek_cb.o -I/usr/src/linux/pcmcia-cs-3.0.9/include/"
* c-indent-level: 4
* c-basic-offset: 4
* tab-width: 4
* End:
NOW WHAT????????????
thank you
Mark
K4eeZ
K4EEZ
Postby shifty_ben » Mon May 01, 2006 12:16 am
Woah Long post ;) If this is an ordinary NIC (i.e. Not wireless) then it should be supported ootb. Its possible support is not compiled into your kernel. What you have posted looks very much like a kernel module to me (though i have to admit its late and I couldn't face reading through to make sure) if this is the case then it is probably the driver you have been looking for. There should be install instructions somewhere to tell you how to compile the thing. Once that is done you can (as root) modprobe the module and it should load. Best guess is Install instructions are on that site, but you would normally expect there to be some in a text file somewhere.
shifty_ben
Postby spottedcat » Mon May 01, 2006 8:47 am
If your ethernet card is not supported ootb then, after your wireless nic experience, you are being very unlucky. Linux is not usually like this - honestly. But before you start compiling modules and modprobing, there is one easy thing to try out in the GUI. Boot into Ubuntu and select the 'System' drop-down menu. Select 'Administration', then 'Networking'. If there is an 'Ethernet Connection' (usually labelled eth0) highlight it and click on 'Properties' to configure it (DHCP is probably preselected) and then click on 'Activate'. All being well you'll now have an active ethernet connection.
But if none of the above applies then Ubuntu is not recognising your ethernet card and I'll hand you back to shifty_ben. (Sorry, Ben. :wink:)
spottedcat
Postby shifty_ben » Mon May 01, 2006 10:58 am
But if none of the above applies then Ubuntu is not recognising your ethernet card and I'll hand you back to shifty_ben. (Sorry, Ben. ;))
Its him I feel sorry for if he ends up having to follow my somewhat vague instructions ;)
shifty_ben
Postby smiff » Sun May 21, 2006 6:42 pm
I have a Linksys WMP54g card as well and I went down the ndiswrapper route.
One thing to bear in mind is that it's worth keeping up to date with the latest releases, and making sure you recompile after any kernel upgrades.
Basically, here's how I keep my wireless card functioning. There's occasional hiccups, but I get them on using Windows XP on my work laptop too.
Install ndiswrapper as per instrctions.
Get hold of the correct windows drivers for your card. Mine was bcmwl5.inf. Copy this somewhere Linux will be able to find it.
Then I have a script I run whenever I boot up my machine. You could set it up so it connects up automatically during boot time, but I like it this way as I can inspect any errors as they happen.
My script looks like this:
cd /path/to/driver/inf/files
ndiswrapper -i bcmwl5.inf
ndiswrapper -l (just to check it installs)
depmod -a
modprobe ndiswrapper
iwconfig
iwlist wlan0 scan
iwconfig wlan0 key restricted xxxxx (I use WEP, i enter my key here)
iwconfig wlan0 essid xxx (name of the SSID I connect to)
iwconfig wlan0 nickname "smiff" (I just do this for no particular reason)
iwconfig wlan0 (check it's all been enetered ok)
dhcpcd -d wlan0 (fire up dhcp and wait for my IP address)
ndiswrapper -m (not really needed, but I just left it in my script)
That's worked for me through my list of distro's I've used, from FC3,4,5 onto SusE 10 that I'm using now (I fancied a bit of stability away from the bleeding edge for a while).
smiff
Postby shifty_ben » Sun May 21, 2006 10:14 pm
you should only need to use ndiswrapper -i bcmwl5.inf once, the first time. After that it remembers, all it does is install the drivers to ndiswrappers drivers directory.
shifty_ben
