asrock motherboards
hopelessrobbie
PostPosted: Sun Apr 16, 2006 12:43 am    Post subject: asrock motherboards Reply with quote
I recently bought myself a intel celeron 2.4G with an asrock motherboard,24bit sounblaster sound card and added my ati 9250 graphics adapter. the problem is that every linux distro only boots up to where it says hotpluging usb devices or boots up with a black-blank screen. please help
mugstar
PostPosted: Sun Apr 16, 2006 10:35 am    Post subject: Reply with quote
Which motherboard?
CuriousStranger
PostPosted: Fri Jun 23, 2006 7:56 pm    Post subject: Reply with quote
same problem here.
my motherboard is an asrock p4i45gv.
i can make it work if i plug my monitor into the onboard video, but i can't use my nvidia fx 5200 in the AGI port(the AGP with some changes, i think this is the problem).
i tried ubuntu and it crashes while loading hotplug subsystem(i don't know what this is), same for kubuntu.
is there any solution for this?
thanks in advance.
http://tpyba.ru/
Last edited by CuriousStranger on Mon Oct 15, 2007 5:36 pm; edited 3 times in total
nordle
PostPosted: Fri Jun 23, 2006 11:22 pm    Post subject: Reply with quote
ok, no help, but I had a problem with an older ECS board, checked the website and there was a bios release to specifically fix linux issues. This was caused by the hardware manufacturer not sticking to some acpi standard.
check the mobo website for any updated bios, if not log the problem with the hardware manufacturer.
I think, therefore I compile
hopelessrobbie
PostPosted: Sat Jun 24, 2006 9:38 am    Post subject: Reply with quote
yes, ive noticed that fif you use the onboard grafics that it work
and the bios update isnt working either
mugstar
PostPosted: Sat Jun 24, 2006 4:56 pm    Post subject: Reply with quote
There should be a BIOS setting which tells the machine which display to use - have you tried setting that to AGP?
hopelessrobbie
PostPosted: Mon Jun 26, 2006 9:15 pm    Post subject: Reply with quote
yes i have.
anyway,the asrock doesnt say agp it says agi
please refer to post made by curiousstranger as this is exactly the same problem and does exactly the same on the ubuntu distro with same (csashing on the hotplug system and loads if u use the onboard graphics.
beagle2
PostPosted: Tue Jun 27, 2006 11:11 pm    Post subject: Reply with quote
See this from last year - http://www.linuxquestions.org/questions/showthread.php?t=395857 , something to do with onboard graphics conflicting with your graphics card. Original poster solved it by recompiling his kernel without the onboard graphics module.
Elive
XP
cpx-mini
pclinuxos super gamer
