Belenix dvd boot problem
Postby wiz » Tue Apr 11, 2006 4:10 pm
The lxf dvd Belenix boot process stops after a few seconds with an error message
svc:/system/filesystem/root:default : Method"/lib/svc/method/fs-root" failed with exit status 95
I did a google search on this and it seems it is possibly caused by a problem with 'vfstab'
Has anybody got any info or ideas to try and resolve this?
wiz
Belenix boots but no X
Postby rvaneerd » Wed Apr 12, 2006 9:56 am
I seem to have different boot-problems using the Live-CD Version on the LXF-DVD.
Belenix starts properly but when it comes to starting X I get a message that the root-filesystem is full!
Cheers,
Rob.
rvaneerd
Postby wiz » Wed Apr 12, 2006 3:12 pm
Good, I was feeling a bit lonely out here on my own :-)
wiz
Postby wiz » Sat May 06, 2006 5:19 pm
If anybody is still interested in this,
I managed to get both problems listed above, by fiddling with the bios settings for the drive access modes,
and,
cure both problems by disabling UDMA mode for the DVD drive channel.
I have a relatively low spec machine 1.3 gig & 384 Mb ram and the distro runs at a (crippled) snails pace.
wiz
Postby Wonderfuel » Wed May 10, 2006 5:33 am
I had no problems booting Belenix on various systems if I chose the third option of the boot prompt then entered UN, PW, xinit, manually and stuck with startkde rather than Xfce4.
However, I have been unable to resolve the GRUB failure R4 Error after a successful 2hr install. Any help gratefully accepted.
Wonderfuel
Postby Wonderfuel » Mon May 15, 2006 10:51 am
Nil response! But I note that the new version has addressed some (unspecified) GRUB shortcomings:
http://distrowatch.com/
Wonderfuel
