Rhakios Moderator
Joined: Thu Apr 07, 2005 12:18 am Posts: 7484 Location: Midlands, UK
Posted: Tue Mar 28, 2006 6:26 pm Post subject: KDE 3.5.2 |
The next bug fix release is out, announcement is here.
I see that the main SuSE ftp site has new packages already, I assume that the mirrors will be synced by tomorrow, with minor package updates over the next few weeks (judging by past experience). _________________ Bye, Rhakios |
Nobber LXF regular
Joined: Mon Apr 11, 2005 4:24 pm Posts: 370 Location: Nova Scotia
Posted: Wed Mar 29, 2006 2:07 pm Post subject: RE: KDE 3.5.2 |
And presumably Konqueror's still only half-usable unless you have icon view on by default?  _________________ 800 LINES ERIC - GET BACK TO PYSKOOL |
nelz Moderator
Posted: Wed Mar 29, 2006 3:38 pm Post subject: RE: KDE 3.5.2 |
There does still seem to be a tendency for the filemanager view to revert to icons, but only on removable devices using a system:/ URI. Remove the system: part and it holds it's mode. This would appear to be a kioslave bug rather than a fault of Konqueror, and certainly removes a lot less than 50% of its usability  _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Rhakios Moderator
Posted: Wed Mar 29, 2006 7:30 pm Post subject: RE: KDE 3.5.2 |
I happen to like icon view  _________________ Bye, Rhakios |
nelz Moderator
Posted: Wed Mar 29, 2006 10:14 pm Post subject: RE: KDE 3.5.2 |
I've noticed another bug/feature with this. When viewing a directory of images in icon view via a system:/ URI, no image previews are shown. Delete the system: part and Konqueror starts showing previews. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
Hello LXF regular
Posted: Fri Mar 31, 2006 7:20 pm Post subject: |
| Will this update come through yast (Im still not sure quite how many packages it does update) |
Rhakios Moderator
Posted: Fri Mar 31, 2006 7:25 pm Post subject: |
Only if you add the correct repositories to your configuration.
I have it installed now, seems one fine, even one new feature, or at least one I have not seen before. _________________ Bye, Rhakios |
Hello LXF regular
Posted: Fri Mar 31, 2006 7:29 pm Post subject: |
| Rhakios wrote: | | Only if you add the correct repositories to your configuration. |
Sorry but what is one of them |
Rhakios Moderator
Posted: Fri Mar 31, 2006 8:01 pm Post subject: |
A repository is a location, usually on an ftp server, but it could be http, where software packages are stored along with files that enable you to integrate the repository as a software resource for downloading and installation, with automatic resolution of dependencies (where possible).
How do you do that? Would probably be your next question. This has been dealt with quite a number of times before on these forums and you could do a search, or just look here. _________________ Bye, Rhakios |
davecs LXF regular
Joined: Sun Apr 10, 2005 12:13 am Posts: 530 Location: Dagenham, Essex
Posted: Fri Mar 31, 2006 9:29 pm Post subject: |
Texstar had KDE3.5.2 in PCLinuxOS unstable before its official release, and moved the builds to the public servers on the day of the release.
KDE3.5.2 seems to have cured a bug in PCLOS re KDE Screensavers. The KDE Dictionary panel applet deals with narrow panels better, it seems a bit snappier. No complaints at all from me! _________________
Asus Asus M2N32 WS Pro+Athlon AM2/4200+ — GeForce 7600GT — 2Gb Cosair VS RAM — 500Gb WD5000AAKS SATA Drive — PCLinuxOS |
