Suse 9.3 update over suse 9.2
Postby brianread » Tue May 10, 2005 9:26 am
If I get Suse 9.3 update package, then do i have to install 9.2 before updating to 9.3? I have full 9.2, and would like to go to 9.3, but it needs to be installed on a new PC as I toasted the 9.2 system some time ago.
Brian j Read
brianread
Postby brian » Tue May 10, 2005 11:17 am
No, I purchased suse 9.3 update, and it a complete installation suite, it just lacks the main suse manual, as it assumes that you have it from your previous purchase.
So you will not require to install 9.2 and then update to 9.3
brian
Postby brianread » Tue May 10, 2005 12:04 pm
Hi Brian (good name)
Many thanks for that - i'll go and get it now!!
Brian j Read
brianread
