GMorgan LXF regular
Joined: Thu Jan 12, 2006 6:58 pm Posts: 684 Location: South Wales, UK
Posted: Mon Mar 13, 2006 8:12 pm Post subject: Using qt3 with Kdevelop. |
| I've been trying to get qt3 to work with Kdevelop in Kubuntu. I've downloaded and installed the qt-x11-free-3.3.5.tar.gz file from the trolltech site but Kdevelop still doesn't find the headers qapplication.h and qlabel.h. Anyone know how to get it running. |
wiz LXF regular
Joined: Thu Apr 07, 2005 7:20 pm Posts: 119 Location: In front of a computer
Posted: Mon Mar 13, 2006 10:17 pm Post subject: |
Try using Adept to download the matching kubuntu Qt & kdevelop packages.
Installing from a Qt tar.gz will put the header files & libraries in odd places and will require an enormous amount of faffing about symlinking everything here & there. I tried to do this myself (once). |
thoughtpolice
Joined: Thu Mar 16, 2006 7:49 pm Posts: 13 Location: Raleigh, North Carolina
Posted: Fri Mar 17, 2006 8:01 pm Post subject: |
I've also got something that may be similar to your issue
I'm coming from bloodshed's dev c++ and a bit confused here, when trying to run a hello world, I'm getting a message that there is no makefile and configure script - what is this?
and then after running ./configure I have this error message
checking for Qt... configure: error: Qt (>= Qt 3.2) (library qt-mt) not found. Please check your installation!
are these hand in hand? |
thoughtpolice
Posted: Fri Mar 17, 2006 8:02 pm Post subject: |
let me make sense of that,
I WAS on bloodshed and now I'm trying to work in kdevelop  |
GMorgan LXF regular
Posted: Fri Mar 17, 2006 9:09 pm Post subject: |
I've solved it now. You have to use the QMake command rather than standard c++ methods. When you create a KDevelop project select a QMake 'hello world' rather than a standard one. The will run the QMake command for you. The other posibility is to create a folder (say hello with main file hello.cpp) then cd to that
folder and run qmake -project
then qmake hello.pro
finally make.
Obviously this is dependant on the correct tools being installed.
My problem was I just assumed that Qt uses standard C++ headers and could compile directly on a normal compiler. You have to run QMake first.
How you get it working in Dev-CPP I don't know. |
thoughtpolice
Posted: Sat Mar 18, 2006 1:21 am Post subject: |
I'm still wrestling with my above problem, and when I run, I get a message that there is no makefile, but I've quadruple checked, there's 3 makefiles upon opening the directory.
GMorgan LXF regular
Posted: Sat Mar 18, 2006 9:29 pm Post subject: |
Three makefiles there should only be one at most. What happens when you try to run qmake -project. Remember that the folder the source is in should have the same name as the main source file. If you wrote the code using KDevelop there should be a src directory within the project folder. The source files would be in there. Copy them into a directory with the same name as the main source file then run qmake as I described above.
Make sure you run the qmake -main.pro step where main is the name of the folder the source is in. This will develop a Makefile you can then compile with make. |
thoughtpolice
Posted: Sun Mar 19, 2006 6:13 pm Post subject: |
| I'll give it a go. Thanks |
