KDE 3.3 Screensaver Not Working in FC3
Postby ferrari » Mon May 09, 2005 10:19 am
The KDE screensavers, while able to be previewed/tested, don't launch upon time out - the screen is blank. I know this is a problem for a large number of users running Fedora Core 3 and other distributions.
I have seen some solutions posted suggesting 'xscreensaver' instead, but was wondering if anyone knows the cause and solution to this problem?
Any ideas...? 8)
ferrari
RE: KDE 3.3 Screensaver Not Working in FC3
Postby Guest » Fri Jun 10, 2005 3:30 pm
As usual the problem is that when you do not know why it does not work... it is the file rights. I had the same problem as I changed profile for root to umas 077.
So make a rpm -qa |grep screensaver
then a rpm -ql ....sometghing screensaver packages...
look what directory are mentionned. for me on 2 direcotries the rights were 700 so KDE user could not enter to that directory and xscreensaver did not work...
Postby Guest » Fri Jun 10, 2005 3:32 pm
btw it was for me:
/usr/libexec/xscreensaver/
/usr/share/xscreensaver/
with the wrong rights make a chmod 755 on both directory
Users browsing this forum: guy and 1 guest
