editing text files from within the shell
Postby snuffsaid » Mon Feb 06, 2006 10:48 pm
evening all,
I have been trying to get a shell script working that will automatically edit a text file. The text file is set out using ':' as a delimiter between bits of info, a bit like the /etc/passwd file. I am trying to use only bash shell scripting for this, no PHP, Ruby, PERL, etc. for reasons of portability, not all the machines have such goodies.
I have managed to get the script to edit a line by using the output of sed and redirecting it to a new file, then copying the file back over the original. Though this seems to leave a blank line in place of the old line if I remove the files entry with the script, though editing the second field does work.
Does anyone know of a more elegant way of doing this? If not with sed then I think all of my machines do have awk if that is of any help to someone.
Cheers
Pete
snuffsaid
RE: editing text files from within the shell
Postby Nigel » Mon Feb 06, 2006 11:53 pm
What exactly are you trying to do to the file ? There's a good chance that both sed and awk can do what you want, but one may be easier than the other for the task you have in mind.
Postby nelz » Tue Feb 07, 2006 12:46 am
If using sed, the s command only replaces content within a line, you need d to delete a complete line or block of lines.
Also, use the -i option to modify a file in place instead of sending pout put to a temporary file, deleting and renaming.
As Nigel says, a clearer idea of what you are doing will result in a clearer recommendation.
Postby snuffsaid » Tue Feb 07, 2006 9:43 am
Sorry for not providing more info, I didn't want to waffle on too much. I have a thrid party application that limits the amount of logins using the application, but does not limit the number of times a user can log in. I have found a way of limiting the users to be only able to login a certain number of times by editing the apps startup script to refer to another file to see how many times that user is allowed to log in. Now I am trying to create a script that can be run from the command line so the person in charge doesn't have to use vi. All he would need to do is <command> -a (add), -r (remove) -m(modify) and so on. This would edit the file, whichis only about 20 lines long and is set out like "username:number of logins". The : can be replaced by anything really.
Hope I haven't waffled on too much and it's made things a little clearer
In the mean time I'll go and try the -i option
Many Thanks
Pete
Postby jjmac » Wed Feb 08, 2006 8:21 am
Information isn't waffle :).
Sounds like a job for "sed" though. A google on sed will come up with lots of diverse sources of information. Including histories, "examples" etc. Unfortuately the man page is quite lacking. I think that because sed has been around for such a long time, it isn't really centralised to the dgree where a single site will provide all the required documentation. So, as a result, it is scattered. Certainly, imo, one of the great unix tools.
Postby nelz » Wed Feb 08, 2006 9:33 am
The sed manpage is limited, but the last paragraph tells you all you need to know, full documentation is in the info page.
You can do what you want with
#add
echo "${NAME}:${LIMIT}" >>configfile
#remove
sed -i "/^${NAME}:/d" configfile
#modify
sed -i "s/^${NAME}:.*/${NAME}:${LIMIT}/" configfile
You'll have to add the usual checks, like making sure you don't add a user twice or try to modify a non-existent user.
Postby jjmac » Thu Feb 09, 2006 8:52 am
:roll: , wish i had looked at the info page at the time (good_grief.png) :roll:
http://counter.li.org
Re: RE: editing text files from within the shell
Postby alloydog » Thu Feb 09, 2006 1:03 pm
jjmac wrote::roll: , wish i had looked at the info page at the time (good_grief.png) :roll:
You mean:
alloydog
RE: Re: RE: editing text files from within the shell
Postby snuffsaid » Thu Feb 09, 2006 2:36 pm
a big thank you to you all. I was staring at the man page and even the "classic shell scripting" book late at night but just could not see for looking, as they say.
Cheers
Pete
Postby jjmac » Sun Feb 12, 2006 2:20 pm
alloydog wrote:
You mean:
In a nut shell :) (hehehe) (um ,,, that is a jpg you know ! :roll: )
Tell me about it (grin), mind you, some of the google feed back on sed is worth the squize :wink:
