Help Please
Help Please
Postby Dustin » Tue May 03, 2005 8:03 pm
I am a fairly new user of Linux. I installed SuSe 9.2 on my computer and I can't change my screen resolution the only option i have is 640x480 and its horrible. Can anyone please help?
Dustin
RE: Help Please
Postby Raymond » Tue May 03, 2005 9:00 pm
Find out what your monitor specs are and from the K menu select System-Configuration-Sax2. Enter root password and click "Monitor" and check its correct and click "Finish", Then click "Colour and Resolution" and click "Properties" then "Resolutions" and check the maximum resolution you want to use and any others(and your monitor can handle) are Ticked.
Then click "Finalize" then you must "Test" it, use on screen arrows to size and position screen then save it. If its not right use Ctrl-Alt-Backspace to abort.
Raymond
