Any Decent php editor
Postby comcamel » Thu Jan 19, 2006 7:41 pm
Recently i just got dreamweaver off ebay, it is very good for html, but for me doesn't seem good at all for php files. Mainly because it is hard to preview the output, in comparison with editing and uploading with notepad and viewing the changes.
Any recommendations, as the fact that dreamweaver is for windows even though is supported on wine and cross over office, but is there one for linux?
comcamel
Postby Cogar » Thu Jan 19, 2006 8:48 pm
If you use KDE, you might consider checking out Quanta Plus.
Cogar
Postby M0PHP » Fri Jan 20, 2006 9:30 am
You might like to have a look at PHP Designer 2006 which is for Windows and may work on WINE, not sure though. I use it at home & at work, very good editor :)
Image Image Image
M0PHP
Postby Lejon » Fri Jan 20, 2006 10:30 am
Have a look at: http://www.zend.com/
(OS support for: Windows, Linux and Mac platforms)
I am the one you thought I was! Just not the way, you expected...
Lejon
Postby M0PHP » Fri Jan 20, 2006 2:19 pm
Also, www.php-editors.com, filter by "Linux" platform using drop-down box on the right menu :)
Image Image Image
M0PHP
Postby comcamel » Sat Jan 21, 2006 2:38 pm
thanks for your suggestions, i shall look into them,
comcamel
Postby Ram » Mon May 15, 2006 12:42 pm
Will have a look at them tonight.
RE: :)
Postby M0PHP » Fri May 26, 2006 9:39 am
PSPad is a very good free editor, and includes inline ftp editing :)
Image Image Image
M0PHP
