Requirement for Opteron Rack Server
Postby mrphewit » Thu Jan 19, 2006 11:29 am
I have a requirement for a Dual Dual-Core Opteron Rack server 1 or 2 U that has 1TB of SATA storage that is Raid 5. Does anyone have any names of reputable suppliers in the UK for these. I want to run Suse 9.3 64 Bit on it.
mrphewit
RE: Requirement for Opteron Rack Server
Postby A-Wing » Thu Jan 26, 2006 2:57 pm
I don't know any that win't rip you off. You are better off buying the 2U case seperately and building it yourself.
I really wouldn't reccomend a 1U for that lot as it will burn itself out too quickly. I would even suggest 4U if you have the space and shove extra cooling in it, you would also have more spacing for the drives that way. I believe adaptec do a great SATA controller which takes RAM as cache and will provide superior performance.
Good Luck.
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
