MythTV is Evil !!!
MythTV is Evil !!!
Postby axelfoley » Tue Jan 10, 2006 6:48 pm
Agggggg, If only I would have been hit by a bus before reading the MythTV Artical ... it would have saved me soooo much pain.
Really my life has been miserabe for 2 months because of that feature ,,,, I do think it was irresponsible of Linux Format to post such an incomplete feature......It at the very least should have been a tutorial spread over 6 months !!!!
Word of advice for anybody trying MythTV ,,,,
1). If you are a Newbie DONT DO IT LIFE IS TOO IMPORTANT.
2). If it was not for legal reasons I am sure the author woul have said DO NOT BUY ANYTHING THAT HAS ANYTHING REMOTELY LIKE VIA printed on it !!!!
Warning about "potential" VIA Problems with a PVR that uses DMA is like saying that a hand granade could give you a bit of a rash if used incorrectly!!
3). Only try this if you are single ......or at least have a prenup.
4). Take a photo of your family before you start and put it by your desk.... otherwise you will forget what they look like.
5). Use Valium or loose your sanity
:-) on the plus side I have learned a hell of a lot......MythTV is Evil!
axelfoley
RE: MythTV is Evil !!!
Postby jdtate101 » Tue Jan 10, 2006 9:09 pm
I 2nd that assesment...pure evil.
Spend AGES trying to get the damn thing to work...so many pre-req's ...so many hidden hardware issues.
Gave up in the end ..I now use Kaffine with my PVR card to record TV. It even has a timer function and program guide.
My advise....either get hardware KNOWN TO WORK....or don't bother!
Ubuntu Edgy & Beryl on:
AMD X2 4800+
4GB Corsair TWINX RAM
2 x Seagate 400GB USB2
Dual Layer DVD-RW
Nvidia 7800GT
2 x Viewsonic VP201b TFT
Iomega Rev Internal
jdtate101
Postby shifty_ben » Tue Jan 10, 2006 11:03 pm
Oh I dunno it wasnt that bad to set up. Having said that I suppsoe there are definitely parts of it whihc could have been easier. I find its usually best to make sure the hardware works with Xawtv or similar first
shifty_ben
Postby firefox » Wed Jan 11, 2006 1:35 pm
You can't really blame MythTV for hardware compatibility though...
I had an old tv card that I knew worked with Linux and got MythTV working with it in an evening. Combined with the tutorial, I thought it was pretty easy!
firefox
