Manipulating dates in mysql
Postby baron » Fri Jan 06, 2006 1:28 pm
Hi
In mysql I have a table called DATES which is part of a seven table database.
The columns of DATES are id, Datejoined, Birthdate, Age and Duration. Information has been entered into the first three columns and I would like to be able to enter the information into the last two columns by calculation using the DATE_SUB and CURDATE() functions. Basically its a calculation of the current date minus birthdate to get Age and a similar calculation using Datejoined to get the Duration.
I wrote the following sql query: INSERT into Dates (Age) Values (DATE_SUB(CURDATE(), INTERVAL Birthdate) where id = 1.
This gave me an error near ') where id = 1. I have tried all sorst of combinations to try to get it to work without sucess.
Can anyone help?
Baron
baron
Postby firefox » Fri Jan 06, 2006 2:53 pm
Use UPDATE instead:
UPDATE Dates
SET Age=((DATEDIFF(CURDATE(), Birthdate))/365
WHERE id=1
However, unless this is a field that you will be using often, it goes against database design principles to store this field in the database, because you can calculate the value on-the-fly when you need it.
firefox
Postby nelz » Fri Jan 06, 2006 3:52 pm
You have one more ( than ).
