tip of the month in LXF66
Postby zsiga » Wed Dec 07, 2005 7:19 am
Hey all, I'm a bit of a linux newcomer as you'll soon learn and I was having trouble getting the command image=`gawk -F\"'/href="image/{print$2;exit;}'$PGE` to work in the nasa desktop-a-day tip....everything was fine until that point. Also, if I don't use KDE and don't have dcop is there away to get the same result in gnome?
-Thanks
zsiga
RE: tip of the month in LXF66
Postby graham » Thu Dec 08, 2005 9:06 am
Morning!
Here's the script that I use at the moment (for KDE):
#!/bin/bash
TMP="/tmp"
SRC="http://antwrp.gsfc.nasa.gov/apod/"
PGE="astropix.html"
cd ${TMP}
wget --quiet $SRC$PGE
image=`gawk -F \" '/href="image/ { print $2; exit; }' $PGE`
wget --quiet $SRC$image
filename="${image##*/}"
cp -rf $TMP/$filename $HOME/.kde/share/background
dcop kdesktop KBackgroundIface setBackgroundEnabled false
dcop kdesktop KBackgroundIface setWallpaper $HOME/.kde/share/background 6
dcop kdesktop KBackgroundIface setBackgroundEnabled true
rm -rf $TMP/$filename
rm -rf $TMP/$PGE
To get this functionality in Gnome, you need to use something like gconftool-2 to change the background. For example, the following will change the background to /home/graham/background.png :
gconftool-2 --type str ---set /desktop/gnome/background/picture_filename /home/graham/background.png
It should be quite straighforward to adapt the KDE script, and you'll need to use 'cron' to run the script at a certain time. Let us know if you have a problem - if you get it to work, it would be great if you could post your script here!
graham
Postby firefox » Fri Dec 09, 2005 4:12 pm
That's quite a scary avitar, graham. Is it from something in particular? :o
firefox
Postby zsiga » Sat Dec 10, 2005 10:41 am
Well, due to a bit of overlooking the obvious I just got it.
#!/bin/bash
TMP="/tmp"
PGE="astropix.html"
cd ${TMP}
cp -rf $TMP/$filename $HOME/.gnome2/share/background.png
gconftool-2 --set /desktop/gnome/background/image_filename $HOME/.gnome2/share/background.png  --type str
gconftool-2 --type str --set /desktop/gnome/background/picture_options "stretched"
rm -rf $TMP/$PGE
The picture_options had to be set as well.
Thanks Graham!
zsiga
