Looking for graphics card with DV out for SUSE 9.1
Postby nerd_biker » Tue Apr 26, 2005 3:21 pm
I know there are millions of graphics cards available but I was hoping for some suggestions as to which card to go for that has a DV output.
I'm not into gaming on my Linux box, so 3D graphics are not important. In fact, the cheaper the card, the better!
I just wondered what experience people have of this type of card and which makes are better supported than others.
If anyone can suggest a good place to find out more information, that would be great as so far I only seem to find Windows based reviews.
Thanks for any help you can give.
Tony
nerd_biker
RE: Looking for graphics card with DV out for SUSE 9.1
Postby towy71 » Tue Apr 26, 2005 3:28 pm
google is your friend ;-)
http://www.google.co.uk/search?hl=en&q= ... ty&spell=1
one of the listed 1,620,000:
http://www.linuxhardware.net/
Dick
Postby Guest » Tue Apr 26, 2005 3:52 pm
Thanks Dick, the linuxhardware.net link will be useful.
I was also hoping to get some feedback from people who have actually installed DV out cards to help me limit the search, do you own a card with a DV out?
Anyway, I'll get down to trawling through the web sites!
Thanks again,
Tony
Postby towy71 » Tue Apr 26, 2005 6:57 pm
I have to wind up the clockwork to get my box running and I have trouble with anything too technical but I hope to upgrade soon so that I can get to play Tuxracer ;-) :lol:
Seriously I do have G-force FX 5600 XT and it does have TV-out and DVI but I'm b***ered if I know what it does or what for. I only bought it cos it came with splinter cell and I wanted to play that but I haven't got round to that either doh!
Dick
ps using Kubuntu getting the Nvidia drivers to work was a doddle so I'm sure that the DV thing can't be too hard
Postby Guest » Tue Apr 26, 2005 9:17 pm
The DVI out is a digital signal output for monitors which require a digital input. VGA SVGA etc are analogue signals and usually sent via the 15 pin D connector on the graphics card. As I understand it DVI is used mainly by the more advanced TFT displays.
Postby Guest » Tue Apr 26, 2005 10:13 pm
PNY Nvidia geforce 5200 128Mb with vga,dvi and tv out all work with suse9.1, and now 9.2
use twin screens from this card with a dvi-vga adaptor
wyliecoyoteuk, unable login, or retreive password:(
