Wireless
Goto page 1, 2  Next
acraigon
PostPosted: Sat Dec 03, 2005 9:12 am    Post subject: Wireless Reply with quote
I am going to try wireless broadband. I have purchased a Netgear wireless modem router. I use zenwalk linux. Do I need drivers to get the router talking to my computer and the internet?
PostPosted: Sat Dec 03, 2005 7:38 pm    Post subject: RE: Wireless Reply with quote
You shouldn't need any drivers for the router itself, but you might need some for whatever wireless card you put in your PC.
RD
PostPosted: Mon Dec 05, 2005 10:34 pm    Post subject: RE: Wireless Reply with quote
Can some one recomend a wireless card that works with out much fuss in linux?
[url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url]
PostPosted: Mon Dec 05, 2005 11:09 pm    Post subject: RE: Wireless Reply with quote
Try the card recommended by Dave2 in this thread.
I used the USB adaptor from the same company, which worked fine for ten days, until my grandson snapped it off Sad
RD
PostPosted: Tue Dec 06, 2005 4:03 am    Post subject: RE: Wireless Reply with quote
Thanks nelz
but dont think im gonna bother as wireless really sucks i spent nearly all night getting wireless to work with linux mac os x and win xp in a room no bigger than a 5x6 to get wireless to fail or get a connection speed of 12mbps not good when all the hardware can do 54mbps at one point none of the above os's could get a connection i worked out that to get a half decent connection i would neep a wireless access point in nearly every room in the house so i think im gonna stick with wired network at least that works how its suppose to and with the correct speed too.
PostPosted: Tue Dec 06, 2005 11:14 am    Post subject: RE: Wireless Reply with quote
Good grief - what sort of a building do you live in ?
I have a 3Com router/access point/adsl modem/firewall box and use 3com cards in our laptops - I have no problems with connections or connection speeds anywhere in the house. One of the laptops is running SuSE 9.2, the other Windows XP.
We also have DECT phones, cordless headphones and, occasionally, a bluetooth connection to my mobile running, so it isn't a pristine environment radio-wise. The internal walls are mostly plasterboard, except for the room where the access point is and the room where I usually use my laptop, both of which have breeze-block walls all the way round.
I would suggest taking a good look at what else you have running within a couple of feet of your access point that might be generating interference !
MartyBartfast
PostPosted: Tue Dec 06, 2005 2:01 pm    Post subject: RE: Wireless Reply with quote
RD,
I'm with Nigel on this one. I've got a Netgear wireless router in an upstairs bedroom, a desktop in an adjacent room and a laptop wherever I happen to be sitting in the house. I get 54mbps on the laptop everywhere in the house, which also has several DECT phones, and a set of wireless headphones (often used by me while on the laptop).
One of these days I'm gonna take the laptop for a walk and see how far I can go and still get a signal Confused
PostPosted: Tue Dec 06, 2005 2:40 pm    Post subject: RE: Wireless Reply with quote
Turn your AP off and see if you can get a signal from a neighbour, it worked for me Smile
ladi
PostPosted: Tue Dec 06, 2005 2:56 pm    Post subject: RE: Wireless Reply with quote
Come on, nelzie!
You're supposed to be setting examples here! Very Happy
I bet Mr Saunders will have something to say about that!
View user's profile Send private message Yahoo Messenger
M-Saunders
PostPosted: Tue Dec 06, 2005 3:04 pm    Post subject: RE: Wireless Reply with quote
"I bet Mr Saunders will have something to say about that!"
Eh? I'm too busy checking Lik-Sang every 3 femtoseconds, to see if my copy of Animal Crossing: Wild World has been posted. Aaargh... need... more... patience...
*head explodes*
M
PostPosted: Tue Dec 06, 2005 3:45 pm    Post subject: Re: RE: Wireless Reply with quote
What is wrong with testing for a signal. i wasn't suggesting anyone try to crack into their neighbour's network.
You seem to have a thing about Mike and me being 'at each other's throats', I've no idea where you get that from.
ladi
PostPosted: Tue Dec 06, 2005 6:50 pm    Post subject: RE: Re: RE: Wireless Reply with quote
Oh, oh! Looks like I've upset the boss!
As you will notice from my expression, that was supposed to be a joke. I was not implying any such thing, and I'm sorry if it came across that way.
I was merely remembering a similar situation with neighbours in a previous thread
PostPosted: Tue Dec 06, 2005 7:06 pm    Post subject: RE: Re: RE: Wireless Reply with quote
Ah, but I wasn't trying to connect to their network then, it was just that my network was secure enough to keep me out Smile
PostPosted: Tue Dec 06, 2005 8:34 pm    Post subject: RE: Re: RE: Wireless Reply with quote
Wireless access points can be a bit odd. I bought an Airport Extreme base station (thought it would go nicely with the PowerBook) and when I first used it I was underwhelmed by its apparent range. I had to hold my PMA430 about 6" above it to get any signal when the base station was placed on the desk next to my computer and with the PowerBook I couldn't move from the same room.
Since then I have put the base station on top of a book case, quite high up. Now the PMA430 works from the other side of the room and the PowerBook can reach it from the other end of the flat.
acraigon
PostPosted: Wed Dec 07, 2005 8:34 pm    Post subject: Netgear wg111 usb Reply with quote
How do I get the above card working in Linux. I have rebuilt the kernel with wireless, downloaded ndiswrapper but I still cannot get my computer to talk to the card. Although ndiswrapper loads the driver it lists the card as invalid. I use this driver with windows! Anyone got any ideas!
Goto page 1, 2  Next
Page 1 of 2
