Nova T DVB TV Card
Nova T DVB TV Card
Postby jdtate101 » Thu Dec 01, 2005 10:39 pm
Installing in SuSE 9.3 as per instructions here:
The card will scan in channels via Kaffeine, but from that point onwards they channels are greyed out in the DVB tab so I cant select them, anyone come across this before.
Kaffeine version 0.71
Ubuntu Edgy & Beryl on:
AMD X2 4800+
2 x Seagate 400GB USB2
Dual Layer DVD-RW
Nvidia 7800GT
2 x Viewsonic VP201b TFT
Iomega Rev Internal
RE: Nova T DVB TV Card
Postby grege » Sat May 20, 2006 11:21 am
I am replying to a very old post, but for the benefit of others....
You just need to get appropriate codecs for decoding the stream, once installed the greyed out enti\ries turn black and away you go.
For Suse you need to add packman to your repositories and grab mpeg2 and win32 codecs.
Postby Diagmato » Sun May 21, 2006 11:24 am
wintv on Suse setup guide. I have had no problems with TV cards since following those steps. Just needed to install the un-tainted xine-lib.
My Blog
Micro$oft gives you Windows, Linux gives you the full house
