Openvpn client script
Postby pk_fox » Sun Jul 27, 2014 9:42 am
Title says it really, I have a script which mounts a share on my VPN server but I can't get it to fire when I connect using OpenVpn Connect , the lines I've added to my .ovpn file are shown below
Code:
script-security 2
up /system/xbin/mymount.sh
the script has executable permissions and works perfectly from a command prompt but its not being executed by OpenVpn
We can't stop here, this is bat country. Hunter S Thompson RIP.
pk_fox
Postby nelz » Sun Jul 27, 2014 10:34 am
What's in the script? OpenVPN will not be executing it from the same environment as your shell. It may be something as simple as a command not in OpenVPN's $PATH.
Postby pk_fox » Sun Jul 27, 2014 1:08 pm
nelz wrote:What's in the script? OpenVPN will not be executing it from the same environment as your shell. It may be something as simple as a command not in OpenVPN's $PATH.
The script contains a mount command ( full qualified path i.e. /system/bin/mount ) to mount the VPN on a local folder but I read somewhere that the up scripts run before the VPN is up so it's not going to work anyway - seems weird to me.
pk_fox
