World Of Goo - Wont even start - [Solved]
Postby GeordieJedi » Wed Jun 18, 2014 10:48 pm
Hi all.
I've recently tried to get World of Goo working on my laptop.
I'm getting no joy at all.
The frustrating thing is that it has worked before (on ubuntu 10.10 / Gnome 2.32.xx / IIRC)
I am currently using ubuntu 12.04 LTS on KDE 4.8.5
It won't even load/run the game at all.
I bought the game directly from 2D boy (as a .deb file - Version 1.41.deb) quite some time ago. I copied the file into my home directory and installed from there.
(I double clicked the file, an app offered to install the file there an then)
It now shows up in software centre as an installed app.
I'm getting the following error message -
Segmentation fault (core dumped)
It looks like World of Goo crashed! If you need support, please include the
contents of the log file in your problem report.
Here is the output of the logfile =
Libraries used:
   linux-gate.so.1 =>  (0xb7747000)
   librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xb7721000)
   libGL.so.1 => /usr/lib/i386-linux-gnu/mesa/libGL.so.1 (0xb76c8000)
   libGLU.so.1 => /usr/lib/i386-linux-gnu/libGLU.so.1 (0xb7652000)
   libSDL-1.2.so.0 => ./libs32/libSDL-1.2.so.0 (0xb75bb000)
   libSDL_mixer-1.2.so.0 => ./libs32/libSDL_mixer-1.2.so.0 (0xb7554000)
   libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xb746f000)
   libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xb7443000)
   libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xb7298000)
   /lib/ld-linux.so.2 (0xb7748000)
   libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xb727d000)
   libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xb7278000)
   libglapi.so.0 => /usr/lib/i386-linux-gnu/libglapi.so.0 (0xb7262000)
   libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xb7250000)
   libXdamage.so.1 => /usr/lib/i386-linux-gnu/libXdamage.so.1 (0xb724b000)
   libXfixes.so.3 => /usr/lib/i386-linux-gnu/libXfixes.so.3 (0xb7245000)
   libX11-xcb.so.1 => /usr/lib/i386-linux-gnu/libX11-xcb.so.1 (0xb7242000)
   libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xb710e000)
   libxcb-glx.so.0 => /usr/lib/i386-linux-gnu/libxcb-glx.so.0 (0xb70f6000)
   libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xb70d4000)
   libXxf86vm.so.1 => /usr/lib/i386-linux-gnu/libXxf86vm.so.1 (0xb70ce000)
   libdrm.so.2 => /usr/lib/i386-linux-gnu/libdrm.so.2 (0xb70c1000)
   libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xb70a3000)
   libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xb709e000)
   libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xb7097000)
Output of glxinfo:
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_create_context_es2_profile, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control,
    GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
    GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event
GLX version: 1.4
GLX extensions:
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) Ironlake Mobile x86/MMX/SSE2
OpenGL version string: 2.1 Mesa 8.0.4
OpenGL shading language version string: 1.20
OpenGL extensions:
    GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_copy_texture,
    GL_EXT_polygon_offset, GL_EXT_subtexture, GL_EXT_texture_object,
    GL_EXT_vertex_array, GL_EXT_compiled_vertex_array, GL_EXT_texture,
    GL_EXT_texture3D, GL_IBM_rasterpos_clip, GL_ARB_point_parameters,
    GL_EXT_draw_range_elements, GL_EXT_packed_pixels, GL_EXT_point_parameters,
    GL_EXT_rescale_normal, GL_EXT_separate_specular_color,
    GL_EXT_texture_edge_clamp, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB, GL_ARB_multitexture,
    GL_EXT_framebuffer_sRGB, GL_IBM_multimode_draw_arrays,
    GL_IBM_texture_mirrored_repeat, GL_3DFX_texture_compression_FXT1,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
    GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
    GL_EXT_secondary_color, GL_EXT_texture_env_add,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
    GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent,
    GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
    GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_EXT_framebuffer_object,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_MESA_window_pos,
    GL_NV_packed_depth_stencil, GL_NV_texture_rectangle, GL_NV_vertex_program,
    GL_ARB_depth_texture, GL_ARB_occlusion_query, GL_ARB_shadow,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
    GL_ARB_window_pos, GL_ATI_envmap_bumpmap, GL_EXT_stencil_two_side,
    GL_EXT_texture_cube_map, GL_NV_depth_clamp, GL_NV_vertex_program1_1,
    GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object, GL_ARB_draw_buffers,
    GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects,
    GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers,
    GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_EXT_shadow_funcs,
    GL_EXT_stencil_wrap, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
    GL_ARB_depth_clamp, GL_ARB_fragment_program_shadow,
    GL_ARB_half_float_pixel, GL_ARB_point_sprite, GL_ARB_shading_language_100,
    GL_ARB_sync, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,
    GL_ATI_blend_equation_separate, GL_EXT_blend_equation_separate,
    GL_OES_read_format, GL_ARB_color_buffer_float, GL_ARB_pixel_buffer_object,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_float,
    GL_ARB_texture_rectangle, GL_EXT_packed_float, GL_EXT_pixel_buffer_object,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_rectangle,
    GL_EXT_texture_sRGB, GL_EXT_texture_shared_exponent,
    GL_ARB_framebuffer_object, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_packed_depth_stencil,
    GL_APPLE_object_purgeable, GL_ARB_vertex_array_object,
    GL_ATI_separate_stencil, GL_EXT_draw_buffers2,
    GL_EXT_gpu_program_parameters, GL_EXT_texture_array,
    GL_EXT_texture_integer, GL_EXT_texture_sRGB_decode, GL_EXT_timer_query,
    GL_OES_EGL_image, GL_MESA_texture_array, GL_ARB_copy_buffer,
    GL_ARB_depth_buffer_float, GL_ARB_half_float_vertex,
    GL_ARB_map_buffer_range, GL_ARB_texture_rg, GL_ARB_texture_swizzle,
    GL_ARB_vertex_array_bgra, GL_EXT_separate_shader_objects,
    GL_EXT_texture_swizzle, GL_EXT_vertex_array_bgra,
    GL_NV_conditional_render, GL_ARB_ES2_compatibility,
    GL_ARB_draw_elements_base_vertex, GL_ARB_explicit_attrib_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_provoking_vertex,
    GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_shader_texture_lod, GL_EXT_provoking_vertex, GL_EXT_texture_snorm,
    GL_MESA_texture_signed_rgba, GL_ARB_robustness
32 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x022 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x094 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x095 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x096 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x097 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x098 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x099 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x09a 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x09b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x09c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x09d 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x09e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x09f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0a0 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0a1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0a2 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0a5 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a6 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0a8 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0a9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0aa 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0ab 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ac 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ad 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0ae 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0af 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0b0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x063 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
48 GLXFBConfigs:
0x064  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x065  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x066  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x067  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x068  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x069  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x06a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x06b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x06c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x06d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x06e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x06f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x070 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x071 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x072 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x073 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x074 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x075 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x076  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x077  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x078 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x079 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x07a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x07b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x07c  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x07d  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x07e  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x07f  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x080  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x081  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x082 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x083 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x084 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x085 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x086 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x087 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x088 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x089 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x08a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x08b 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x08c 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x08d 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x08e  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x08f  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x090 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x091 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x092 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x093 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
Thanks in advance for any help or advice.
Useful information
Ubuntu 12.04 - KDE
Laptop = Medion Akoya - E7214 (MD 98360)
17.3" Widescreen / Core i3 350M CPU / 3GB Ram / 320GB HDD /
Intel HD Graphics
GeordieJedi
Postby GeordieJedi » Thu Jun 19, 2014 9:25 pm
Hi again.
I followed the link below, copied/overwrote some files into the relevant dir and it worked like a charm.
http://goofans.com/forum/world-of-goo/support/4780
GeordieJedi
