postgres problem - I know its my fault but help
Postby pk_fox » Sat Jun 07, 2014 6:18 am
Hi all, i've just installed Postgres 9.3 on a Debian box running Wheezy and I naively thought the installer would remove 9.1 which is installed as standard, well it didn't and I ended up with two servers running on 5432 and 5433 which I don't won't. Anyway to cut it short I read on the web somewhere how to completely uninstall Postgresql which entailed deleting directories etc... And you guessed it Postgresql is now totally hosed, I've tried apt-get remove --purge postgres which claims to have removed it , I then installed 9.3 using apt-get which again claims to have installed it but postgres won't start and there is no script in /etc/init.d to start it, trying to start it manually gives an error of no clusters created and is postgres running on port 5432 etc... I really don't want to have to reinstall Debian as I have it pretty well setup as Ilike it. All suggestions welcomed.
We can't stop here, this is bat country. Hunter S Thompson RIP.
pk_fox
Postby wyliecoyoteuk » Sat Jun 07, 2014 9:47 am
Have you tried
dpkg --configure postgres
You might get better results using dpkg
http://www.tecmint.com/dpkg-command-examples/
Postby pk_fox » Sat Jun 07, 2014 12:43 pm
quote="wyliecoyoteuk"]Have you tried
http://www.tecmint.com/dpkg-command-examples/[/quote]
Tried that and got this
dpkg: error processing postgresql (--configure):
 package postgresql is already installed and configured
Errors were encountered while processing:
 postgresql
pk_fox
Postby wyliecoyoteuk » Sat Jun 07, 2014 2:49 pm
In thst case try using dpkg yo remove it and reinstall
Postby wyliecoyoteuk » Sat Jun 07, 2014 3:53 pm
wyliecoyoteuk wrote:In that case try using dpkg to remove it and reinstall
(i hate phone autocorrect)
Postby pk_fox » Sat Jun 07, 2014 5:25 pm
Know what you mean - thanks I'll try it when I get home
pk_fox
Postby pk_fox » Sun Jun 08, 2014 9:52 am
Hi there, I tried removing and reinstalling it using dpkg but still won't start and no postgresql script in /etc/init.d - surely there must be a way of forcing a complete reinstall which would recreate essential missing files and directories ? you know a repair botched by idiot user type thing !
EDIT
SUCCESS !!!
I ran this command and it worked
apt-get --purge remove postgresql\*
I received a warning that some folders couldn't be removed as they weren't empty - I then removed what was in the listed directories and ran it again and BINGO - I installed postgresql again using
apt-get autoremove -- just to be sure !
apt-get install postgresql
and it installed and started without a hitch - thanks very much for your help
pk_fox
