KDEDESKTOP - Task Manger Panel
Postby baron » Fri May 16, 2014 7:06 pm
Hi
On KDE on the desktop screen there is a panel with the start button and various other icons for applications. Now this panel is usually on the bottom of the screen with the start button at the immediate left.
However mine has for some reason moved to the top of the screen. I have tried all sorts of ideas "Task Manager Settings" " Panel Settings" and none of these help to relocate it back to the bottom of the screen.
Is there a configuration file for this? Any help would be appreciated
I'm sure it should be quite simple but I'm stuck
Baron
baron
Postby nelz » Fri May 16, 2014 8:10 pm
Right-click a blank area of the panel and select Panel options->Panel settings. Then drag the Screen Edge button to wherever you want the panel.
Users browsing this forum: Marrea and 4 guests
