[solved] Is dist-upgrade safe to use on Jessie
Postby purplepenguin » Thu May 08, 2014 10:21 am
Hi all
I've installed Debian Jesssie with KDE and I'm very happy with it so far.
I keep getting a popup that tells me there are 29 upgrades available. When I run
apt-get upgrade
the output tells me:
The following packages have been kept back:
  akregator kaddressbook kmail knotes kopete korganizer libcalendarsupport4 libeventviews4 libincidenceeditorsng4 libkdepim4 libkdepimdbusinterfaces4 libkdgantt2-0 libkleo4
  libkmanagesieve4 libkopete4 libkpgp4 libksieve4 libksieveui4 libmailcommon4 libmailimporter4 libmessagecomposer4 libmessagecore4 libmessagelist4 libmessageviewer4 libokularcore3
  libpimcommon4 libsendlater4 libtemplateparser4 okular
0 upgraded, 0 newly installed, 0 to remove and 29 not upgraded.
Now. I've been reading the Debian forums and there seems to be two ways to go.
1 use
apt-get dist-upgrade
Which will apparently install the packages.
2 install the packages manually.
From what I understand the dist-upgrade route will remove some packages and install the others that have been held back. Is this a safe approach to use on Debian Testing? I remember running dist-upgrade on a Mint (Ubuntu base) system and it caused no end of headaches. So I'm a little hesitant to use it on my freshly installed Debian system.
Here's the output of /etc/apt/sources.list
lee@mainpc:~$ sudo cat /etc/apt/sources.list
[sudo] password for lee:
# deb cdrom:[Debian GNU/Linux testing _Jessie_ - Official Snapshot amd64 kde-CD Binary-1 20140428-07:25]/ jessie main
deb http://ftp.uk.debian.org/debian/ jessie main contrib non-free
deb-src http://ftp.uk.debian.org/debian/ jessie main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb-src http://security.debian.org/ jessie/updates main contrib non-free
# jessie-updates, previously known as 'volatile'
deb http://ftp.uk.debian.org/debian/ jessie-updates main contrib non-free
deb-src http://ftp.uk.debian.org/debian/ jessie-updates main contrib non-free
# jessie-backports, previously on backports.debian.org
deb http://ftp.uk.debian.org/debian/ jessie-backports main
deb-src http://ftp.uk.debian.org/debian/ jessie-backports main
# Mint Debian repo for firefox
# deb http://packages.linuxmint.com debian import
I added the contrib and non-free parts to the repos and the Mint Debain repo which is commented out. I don't think this will cause any problems.
I'm not sure which way is the best approach. use dist-upgrade, install manually or do I need to change the sources.list back to it's default?
TIA
PP
purplepenguin
Postby arochester » Thu May 08, 2014 10:33 am
I run Debian Jessie and I have had no problems from apt-get upgrade and apt-get dist-upgrade.
Unless you are a total geek you don't need source code. In your sources list you should put # at the beginning of every line that starts deb-src.
arochester
Postby roseway » Thu May 08, 2014 11:39 am
There's no such thing as jessie-backports (backports only applies to the stable distro, currently Wheezy).
I do aptitude full-upgrade every day, but I always read carefully what it says it's going to do before OKing it.
Eric
roseway
Postby purplepenguin » Thu May 08, 2014 12:10 pm
roseway wrote:There's no such thing as jessie-backports (backports only applies to the stable distro, currently Wheezy).
I was unsure about that one too. I don't remember adding the Jessie backports. I assumed it was there from the start. Guess I must have put it in. I did use debgen web site to try and add multimedia repos. I must have ticked the backports box too.
deb-src commented out and Jessie backports removed. Thanks.
purplepenguin
