File count incorrect
Postby pk_fox » Fri Apr 25, 2014 8:35 am
Hi all, I just rsynced two folders on two different drives and all appeared to be fine ( no error messages ) , I then did a file count on both using this method
find /folder1 -name *.flac|wc -l
find /folder2 -name *.flac|wc -l
This returned 5240 on folder1 and 5239 on folder2, how can I identify the missing file ?
Edit
I just ran rsync again and received an error "file has vanished" followed by the path to the file, I checked and the file is indeed in folder1 but not in folder2, the file looks to be OK but it does have a very long path and some unusual characters in its name e.g [ and _ , could this cause the problem ?
More output from rsync
Total size is 148046291131  speedup is 507820.01
rsync warning: some files vanished before they could be transferred (code 24) at main.c(1070) [sender=3.0.9]
We can't stop here, this is bat country. Hunter S Thompson RIP.
pk_fox
Postby nelz » Fri Apr 25, 2014 9:14 am
find /folder1 -name *.flac | sort >folder1.list
find /folder2 -name *.flac | sort >folder2.list
diff folder[12].list
The shell "special characters" like [ may be causing problems for rsync. What is the rsync command you are using?
Postby pk_fox » Fri Apr 25, 2014 9:48 am
nelz wrote:
rsync -av /mnt/folder1 /mnt/folder2
Folder names are fictitious but folder1 is a Linux Nas box and folder2 a USB drive , I renamed the rogue file and all is OK so it must have been those characters, but I've notice some other files have these and they copied OK, maybe it was a combination of the length and the special characters ? Any ideas on my other question why my USB drive wasn't mountable ? - bloody weird one that !
pk_fox
Postby nelz » Fri Apr 25, 2014 9:50 am
It is more likely to be the particular combination of special characters.
Users browsing this forum: Yahoo [Bot] and 6 guests
