Codecs prob
Codecs prob
Postby DavidMcCrossan » Tue Apr 01, 2014 4:14 pm
I use Mint15 64 with i5, 8GB of fast RAM, 500Gb HDD.
Originally I tried Mint 16 32 but Cinnamon would not load and my new nVidia card was not recognised, so I reverted to Mint 15 64 - because it worked before.
The new nVidia card was also not recognised so I put back my older card and the nVidia drivers hardware card was swiftly and properly installed.
OK, so I have a working system, but I cannot play sound. I get messages such as "you have a corrupted codec and this cannot be repaired".
The question for today is - how can I uninstall the codecs and do a new install to get sound?
I am happy to use the cmd line. (Much new practice gives me confidence)...
Best regards
David
Semper in Excretam
DavidMcCrossan
codecs
Postby twager » Thu Apr 03, 2014 8:36 am
If you goto the software centre you should be able to see which
codecs are installed and have a chance to delete them then reinstall ?
twager
Codecs prob
Postby DavidMcCrossan » Fri Apr 04, 2014 2:02 pm
Thanx Ted, but I was able to find the codecs package.
However, I pressed the "install codecs" button on the desktop and got the dumped onto the cmd line. After entering my password I got the following info.
Pack with unmet dependencies:
mint-meta-codecs: depends :libdvdss2 not installable
                                      :w64 codecs not installable
                                      :mint-flashplugin not going to be installed
Might this be a good time to try apt-get upgrade?
Best
David
Semper in Excretam
DavidMcCrossan
