Reinstallation of applications after upgrade
Postby fede » Sat Mar 29, 2014 11:07 pm
I am sure this has been addressed a zillion times before, but I could not find a post on this (not that good at setting up queries).
The temptation to update to a new version (e.g. Ubuntu 13.10 to 14.04) rather than going through a fresh install comes form the drudgery of reinstalling all the packages that one has added in the previous iteration. It used to be that dpkg --get-selections/--set-selections would do the job of reinstlling what you had in the previous iteration on Debian/Ubuntu, but it hasn't worked for me in over a year (on trying --set-selections I get all error messages stating that the item is not in the database, and nothing gets installed (yes, I had updated sources.list).
Is there another way, or am I missing something that is easily fixed?
Thank you!
fede
Postby Dutch_Master » Sun Mar 30, 2014 12:43 am
You need something else to get the required packages.
The full procedure:
Before the upgrade:
sudo dpkg --get-selections > /home/<user>/selections.txt
Make sure you copy the file selections.txt to a backup medium, with the rest of your data!
After the upgrade:
Copy the file selections.txt back to your drive and navigate to it with the cd command, then:
sudo apt-get install dselect
sudo dpkg --set-selections < selections.txt
sudo dselect install
This'll take some time, so get a cuppa of sorts ;)
Done :)
Postby towy71 » Sun Mar 30, 2014 1:07 am
That's all very well but what if you don't do the first part :roll: :roll: :roll:
Postby nelz » Sun Mar 30, 2014 7:10 am
apt-get dist-upgrade
saves the hassle and avoids the drudgery of reconfiguring things after each new release.
Postby towy71 » Sun Mar 30, 2014 10:22 am
I have bitter personal experience of the dist-upgrade thing, luckily I had backed everything up :oops: :roll:
Postby fede » Wed Apr 02, 2014 2:52 am
Dutch_Master wrote:You need something else to get the required packages.
The full procedure:
Before the upgrade:
After the upgrade:
Done :)
Thanks. What I notice I haven't been doing (it was not mentioned in old Debian-related info) is the step
I suppose I have to assume that this is where I tripped. But what does this instruction actually do? And, assuming I will soon lose my job and have some time to play around, is there a source to learn how this works? Just joking, but not as much as I'd like ;-)
Anyway, thanks - I'll try that (I keep my /home/ partition no matter what anyway)
fede
Postby Dutch_Master » Wed Apr 02, 2014 4:09 am
Well, it does really what it says: instruct apt-get (the package management tool) to install the package dselect, with sudo rights. If you want to know more, type the following in a terminal and hit enter:
man man
Use the up/down arrows to read more and press the q key to quit. Linux can be so easy, if you know where to look :P ;)
Postby fede » Thu Apr 10, 2014 8:48 pm
Dutch_Master wrote:Well, it does really what it says: instruct apt-get (the package management tool) to install the package dselect, with sudo rights. If you want to know more, type the following in a terminal and hit enter:
man man
So right! And, I must have been very tired when I asked that last question... :x Unconsciously, I just assumed that dselect was built in or installed by default. Oh, well... Thanks and thanks to you and the forum for being there even for dumb questions!
fede
