Repeated Backup
Repeated Backup
Postby steve-r » Thu Mar 27, 2014 2:00 pm
In issue 182, Answers section, it was suggested to use the rsync daemon on a server to send backups to.
I currently use "normal" rsync for this. If I try using rsync as a daemon I can't find the options to keep the ownership of the original files - surely a MUST for any form of backup.
Any files I transfer this way end up owned by nobody:nogroup.
Are there options to rsync daemon that WILL retain ownership?
Steve
steve-r
Postby nelz » Thu Mar 27, 2014 2:23 pm
When you define the tartet in /etc/rsyncd.conf, use the uid parameter to specify the user to create the file as. You can either use a specific user name or
uid = %RSYNC_USER_NAME%
gid = *
This uses the same user ID that was used to authenticate the connection.
Postby steve-r » Thu Mar 27, 2014 3:16 pm
Hi nelz,
Thanks for the reply.
My rsyncd.conf has (with your suggestion);
max connections = 4
log file = /var/log/rsync.log
timeout = 300
dont compress = *.gz *.tgz *.zip *.z *.rpm *.deb *.iso *.bz2 *.tbz *.Z
[test]
   path = /data/test
   comment = test
   read only = no
   list = yes
   gid = *
The command on the remote host is
rsync -avP --numeric-ids --delete --stats --inplace /home/steve/ rsync://test@IPADDRESS/test/home/steve/
Without the uid and gid lines this works but everything ends up owned by nobody:nogroup.
If I add the uid and gid lines I get;
@ERROR: invalid uid %RSYNC_USER_NAME%
Steve
steve-r
Postby nelz » Thu Mar 27, 2014 7:08 pm
Does it work with
uid = steve
gid = *
Assuming your username is steve.
Postby steve-r » Fri Mar 28, 2014 9:33 am
If I set;
uid = steve
gid = steve
it does "work" but the received files are then owned by steve:steve rather than the original owner.
gid = * was not liked. I get an Invalid gid message
steve-r
Postby nelz » Fri Mar 28, 2014 9:55 am
Which version of rsync are you using. gid = * works with 3.1.0 here. It seems you need to set u user authentication, with auth users, for the username to be passed through. The man pages explain how to do this, start with man rsyncd.conf.
Postby steve-r » Fri Mar 28, 2014 10:36 am
The server (Debian Stable) is 3.0.9, the client (Ubuntu 10.04 LTS) is 3.0.7
steve-r
Postby steve-r » Fri Mar 28, 2014 11:25 am
What I have found to work is if I;
uid = root
gid = root
and if I change the remote host command to read;
rsync -avP --numeric-ids --delete --stats --inplace /home/steve/ rsync://IPADDRESS/test/home/steve/
Thanks for your help!
steve-r
Postby nelz » Fri Mar 28, 2014 1:22 pm
This entails running the server as root, which is a security risk. It's not too bad if it is only on your local network, but do not expose this to the Wild West Web.
