Installing wallpaper on KDE 4.5.1.
Postby baron » Mon Mar 17, 2014 5:24 pm
This used to be really easy under KDE 3.5 but now it appears to be a lot more complicated under the new EASIER!!! KDE 4.
Can anyone tell me how to do this please?
baron
baron
Postby roseway » Mon Mar 17, 2014 6:48 pm
For as long as I can remember, the easiest method has always been to right-click on the desktop and choose the appropriate item from the popup menu. I put it that way because the wording has changed several times over the years - currently on KDE 4.11.5 it's "Default desktop settings".
Eric
roseway
Postby nelz » Mon Mar 17, 2014 10:40 pm
If you want the wallpapers to show up as thumbnails in the Default Desktop Settings window, copy them to ~/.kde4/share/wallpapers. Otherwise, you will have to hit the Open button and browse for the correct file.
This is, of course, far more complicated than KDE3.x where you simply put them in ~/.kde/share/wallpapers :D
Postby johnhudson » Tue Mar 18, 2014 9:45 pm
Default Desktop Settings actually shows the wallpapers in /usr/share/wallpapers/ along with any in .kde4/share/apps/wallpapers/
The ones in .kde4/share/apps/wallpapers/ are ones a user has downloaded. If you put them in /usr/share/wallpapers/ they become available for all users.
Postby roseway » Wed Mar 19, 2014 7:05 am
Just another little wrinkle here is that the use of ~/.kde4 isn't universal - some distros retain ~/.kde for the user's personal KDE settings. Debian is one of these.
Eric
roseway
Postby johnhudson » Wed Mar 19, 2014 9:14 pm
Sorry forgot that ~/.kde4 was adopted by openSUSE so that it could let people try out KDE4 alongside KDE3 before it was usable. It means that I can run KDE3 and KDE4 apps alongside each other without any conflict.
