Printer probs....
Printer probs....
Postby DavidMcCrossan » Wed Mar 12, 2014 3:27 pm
I am trying to add my Samsung ML-1670 laser to my system and have installed the relevant Samsung drivers. In on order to effect the addition I have had to specify the ppd file and this I have done. I got an error message from the printer management screen to the effect that I must first add
rastertosplc
to [/code] /usr/lib/cups/filter/[code] and that is what I am trying to do.
The file resides in [code]/home/david/uld/.386/rastertosplc[/code].
Using Gnome Commander with both directories open to me I can copy the file but am unable to paste it into /usr, even as root.
Can anyone please advise me - I am willing to use the command line but I need a steer, please.
Best regards
David
Semper in Excretam
DavidMcCrossan
Postby Dutch_Master » Wed Mar 12, 2014 3:54 pm
The general command structure is:
cp [options] <source> <destination>
So in your case:
cp /home/david/uld/.386/rastertosplc /usr/lib/cups/filter/
If your system uses sudo, precede the previous command accordingly :)
Bookmark this: http://ss64.com/bash/ :!:
Printer probs....
Postby DavidMcCrossan » Wed Mar 12, 2014 6:05 pm
Thanx DM for your prompt reply.
cp: cannot stat '/home/david/uld/.386/rasterostplc': No such file or directory
is the reply.
I have wrestled with this all afternoon.
Can you see if I have made any mistake, please?
Best regards
David
Semper in Excretam
DavidMcCrossan
Postby Dutch_Master » Wed Mar 12, 2014 7:36 pm
This command
updatedb && locate rasterostplc | grep /home/
will give you the exact location of the rasterostplc file in the /home directory. Note very carefully where it is, then navigate to it via the cd command:
cd /home/<path/to/file>
The ls command shows you the contents of that directory. Check the file is there. Then, re-issue the cp command I gave earlier.
You can use the ls command to check contents of another directory, if you provide a path to it:
ls /usr/lib/cups/filter/
This should now show the rasterostplc file inside it.
Postby nelz » Wed Mar 12, 2014 7:45 pm
You have spelled the name differently, rastertosplc vs rasterostplc. Use tab completion instead of typing the paths in full, that way you know it is correct.
Or you can use find
find ~/uld -name 'raster*'
to find the file.
Printer probs....
Postby DavidMcCrossan » Thu Mar 13, 2014 3:27 pm
DM and NELZ, wot a pair of stars you are!
I am pretty confident I can do the rest now. I will let you know how I get on.
Best
David
Semper in Excretam
DavidMcCrossan
Printer probs....
Postby DavidMcCrossan » Thu Mar 13, 2014 6:32 pm
DM and Nelz, Thank you so much for your expert guidance.
I have copied the file to the right place and verified it.
I still do not have a working printer, but I think I know why.
I now know how to install it correctly and I shall uninstall (having taken good copies of the relevant locations and file names and addresses) so I can easily specify them again.
Altho´ I did go to Specsavers I am now 72 and the 7 strokes and one episode of Thrombosis have left their mark...
Many thanx
David
Semper in Excretam
DavidMcCrossan
Printer probs....
Postby DavidMcCrossan » Sat Mar 15, 2014 12:10 pm
Hi Guys!
Sadly there is still work to do.
I managed to copy the file rastertosplc to /usr/lib/cups/filter and verified that it was there as root owner.
The problem is that I could not print any thing. Digging around I found under print queue attributes the statement that ¨filter failed¨.
In case the installation had become corrupted I moved all my various downloads to trash and went to the Samsung site for a fresh (untainted) download. This is a new type, only issued yesterday But I managed to install it. I still get the same filter failed message and I have run out of grunt.
Any ideas anyone, please?
Best regards
David
Semper in Excretam
DavidMcCrossan
Postby Dutch_Master » Sat Mar 15, 2014 2:44 pm
Are the permissions correct? Set to
chmod 644 /usr/lib/cups/filter/rastertosplc
Are you installing the drivers according to the Samsung instructions? Reboot the PC to make sure all relevant services (Cups, lpr) are started correctly.
Printer probs....
Postby DavidMcCrossan » Sun Mar 16, 2014 2:53 pm
DM thank you for your continuing support.
Overnight I had a Eureka moment, reasoning that filter was part of the CUPS kit I might as well re-install it. So I did, but it still fails. I have just applied your chmod change and it is still the same.
IT seems to me that there are 2 paths: I should reassess my installation procedure, or I could reinstall Mint 15, which worked perfectly after a bit of tinkering.
It has now been 2 weeks and I am exhausted.....
Best regards
David
Semper in Excretam
DavidMcCrossan
Postby wyliecoyoteuk » Sun Mar 16, 2014 10:14 pm
How are you installing?
I have a Samsung printer, and the only filters I can find are rastertosamsungpl and rastertosamsungplc.
try entering http://localhost:631 in a web browser, and adding the printer that way.
On my ubuntu syatem the driver is already available.
Printer probs....
Postby DavidMcCrossan » Mon Mar 17, 2014 9:56 am
Thanks Wylie, I have installing using localhost:631 and it still does not print. The message I get is ¨filter failed¨
I have looked at
and it is set as root.
I have just noticed DM´s instructions to chmod to 644 so I will try that and see if it works.
Best regards
David
Semper in Excretam
DavidMcCrossan
Printer probs....
Postby DavidMcCrossan » Mon Mar 17, 2014 10:19 am
Further to my last I have chmod 644 to rastertosplc and I get the message from job-printer-state-reasons-
[u´cups-insecure-filter-warning´]
I shall change back to root and do some more head-scratching.
Incidentally, I have also tried
/home/david/downloads/uld/ and installed [.sh] and then [install.sh] and the same result occurs.
I can´t think of anything else I can do.
I think I will go for a walk to clear me bonce...
Best
David
Semper in Excretam
DavidMcCrossan
Printer probs....
Postby DavidMcCrossan » Mon Mar 17, 2014 2:31 pm
I carried a clearout in which I deleted the printer and deleted rastertospic and installed the printer from the archive as:
cd /home/david/Downloads/uld
then
sudo  /home/david/Downloads/uld/.install.sh
At the printers setup box in sys settings the dialog allowed me to specify the Samsung printer after I pointed it to the location of the .ppd file and informed me that file rastertosplc need to be installed in :
and I duly copied the file from:
~/uld/i386/rastertosplc
to
~/cups//filter/
I then checked the file had root owner permission
I still get the same ¨filter failed¨ message and I wonder if the raster file has been properly installed in the /filter dir.
Can anyone shine a light into my gloom, please?
Best
David
Semper in Excretam
DavidMcCrossan
Printer probs....
Postby DavidMcCrossan » Tue Mar 18, 2014 3:15 pm
I may be on to something here.
http://localhost:631/admn/printers[code] gets me the CUPS website.
pointing to my printer and then I see, on the top of the page [code]Idle, accepting jobs,stopped, server default[/code]
I can´t help thinking that I must be able to register my printer to Cups, and this might be the reason behind the ¨filter failure¨ message.
Any thoughts?
Best
David
Semper in Excretam
DavidMcCrossan
