Shutdown and bootup woes
Postby heiowge » Tue Mar 04, 2014 10:50 pm
The old Dell pc I got given has a flaw. Every 3rd or 4th shutdown fails to do so. Even alt+sysrq+REISUB fails to work. I have to do a hard shutdown.
The next bootup usually fails. It takes longer than normal to boot and fails to allow access to the keyboard and mouse. I have to pull out the power cable and wait for 30 seconds. Any idea why?
Postby purplepenguin » Wed Mar 05, 2014 12:56 pm
As a wild stab in the dark. I'd say hardware issues. Although I suspect we will need a little more info.
what do you mean by " fails to shutdown"? is it simply not powering off or is it locking up in some way?
purplepenguin
Postby heiowge » Wed Mar 05, 2014 7:47 pm
I'll take a picture next time it fails and post it.
Postby Dutch_Master » Thu Mar 06, 2014 1:00 am
Has it been overclocked? Go into the BIOS and reset it to safe values, then work from there.
Postby lok1950 » Thu Mar 06, 2014 4:23 am
There should be a boot log left over from the last boot check the logs directory under /var.
Enjoy the Choice :)
lok1950
Postby heiowge » Thu Mar 06, 2014 12:24 pm
The last shutdown was successful and the boot record shows all OK. I'm guessing it overwrites it each time? If so, I'll have to wait for the next crappy shutdown. :?
Users browsing this forum: huwgreen and 4 guests
