Boot Pause/Delay 7~8 seconds - "Updated"
Postby wirezfree » Wed Feb 26, 2014 12:30 am
Hello,
I'm a very late comer to Linux, a Windows user since 2.11
I have tried both Linux Mint 16 Cinnamon and Zorin8
Very early in the boot process on both there is 7~8 sec pause/delay
It makes me think I may not be getting the best from my set-up.?
Is this pause something that can be investigated to see why the pause,
I did try bootchart on LM16, but I did not know where to start looking.
dmesg snip from Linux Mint
[    0.271533] ACPI: Dynamic OEM Table Load:
[    0.271539] ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20121220)
[    8.837916] ACPI: Interpreter enabled
dmesg snip from Zorin
[    0.195436] ACPI: Dynamic OEM Table Load:
[    0.195438] ACPI: SSDT           (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20121220)
[    7.282171] ACPI: Interpreter enabled
Any advice on how to look at this would be appreciated.
Thanks... David
(edit... missed the examples)
wirezfree
Postby lok1950 » Wed Feb 26, 2014 4:15 am
Welcome wirezfree A bit more info on your kit would be useful as otherwise we a just stabbing in the dark ;) that snippet you posted concerns some component that it does not recognize and with no background as I said we'er stabbing in the dark.
Enjoy the Choice :)
lok1950
Updated information
Postby wirezfree » Wed Feb 26, 2014 10:13 am
lok1950 wrote:Welcome wirezfree A bit more info on your kit would be useful as otherwise we a just stabbing in the dark ;)
Enjoy the Choice :)
Many thanks for the quick response.
I'm new, I'm starting to get familiar with terminal commands and utilities.
What would be the most useful.?
Here are some setup related items:
wirezfree@hp-zorin:~$ sudo inxi -F
System:    Host: hp-zorin Kernel: 3.11.0-18-generic x86_64 (64 bit) Desktop: N/A Distro: Zorin OS 8
Machine:   System: Hewlett-Packard product: HP Pavilion TS 14 Notebook PC version: 0881100000305E00000620100 serial: 5CD3394BSQ
           Mobo: Hewlett-Packard model: 2161 version: 29.34 serial: PDVUC018J5I01W
           Bios: Insyde version: F.34 date: 10/31/2013
CPU:       Dual core Intel Core i5-4200U CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 759.00 MHz 2: 759.00 MHz 3: 759.00 MHz 4: 759.00 MHz
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller
           X.org: 1.14.5 drivers: intel (unloaded: fbdev,vesa) tty size: 80x24 Advanced Data: N/A for root
Audio:     Card-1: Intel Lynx Point-LP HD Audio Controller driver: snd_hda_intel Sound: ALSA ver: k3.11.0-18-generic
           Card-2: Intel Device 0a0c driver: snd_hda_intel
Network:   Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller driver: r8169
           IF: eth0 state: down mac: a0:48:1c:20:8a:81
           Card-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
           IF: wlan0 state: up mac: 70:18:8b:c9:63:ad
Drives:    HDD Total Size: 256.1GB (3.4% used) 1: id: /dev/sda model: Samsung_SSD_840 size: 256.1GB
Partition: ID: / size: 37G used: 7.1G (21%) fs: ext4 ID: /home size: 170G used: 1.2G (1%) fs: ext4
           ID: swap-1 size: 16.10GB used: 0.00GB (0%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   System Temperatures: cpu: 34.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 214 Uptime: 2 min Memory: 579.9/15825.8MB Client: Shell (sudo) inxi: 1.9.12
and
wirezfree@hp-zorin:~$ sudo inxi -SGx
System:    Host: hp-zorin Kernel: 3.11.0-18-generic x86_64 (64 bit, gcc: 4.8.1) Desktop: N/A Distro: Zorin OS 8
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0
Please let me know what else you need.?
I did try bootchart when trying Linux Mint, I can do that for Zorin if it helps.?
Edit...
Not sure how to share, other than using my sugarsync.?
Here is
Full dmesg: https://www.sugarsync.com/pf/D714267_77617033_6910591
Bootchart: https://www.sugarsync.com/pf/D714267_77617033_6918517
Thanks - David
wirezfree
Any AdviceGuidance..??
Postby wirezfree » Sat Mar 15, 2014 12:45 am
Hello,
I wonder if anybody can assist with this,
Is there more information required.?
Many Thanks
David
wirezfree
Postby lok1950 » Sat Mar 15, 2014 3:35 am
Do you have a boot log in /var/logs if so please post it no need to use the cmd line ;) it should have the name boot.log or something similar,dmesg did not have anything I recognize it may be related to ACPI which is used to identify various components on the M/B and all the custom keys and switches which lap-tops are famous for.
Enjoy the Choice :)
lok1950
Postby nelz » Sat Mar 15, 2014 9:04 am
It looks like ACPI may be the culprit. You can test this by booting with ACPI disabled. At the boo menu, press E to edit the boot options and add
 acpi=off
to the end of the line starting with "linux". Press F10 to boot.
This is a one-off change, you probably don't want to disable ACPI completely, but if it gets rid of the delay you can look at other ACPI settings.
Some ACPI implementations are notoriously indifferent to the standards, "it works with Windows, that'll do" but a BIOS update can often help.
Responses to Questions
Postby wirezfree » Sat Mar 15, 2014 2:22 pm
Hello lok1950 & nelz,
lok1950,
Here is the link to boot.log
https://www.sugarsync.com/pf/D714267_77617033_6923578
nelz,
You will have to bear with me..
I did the E at boot, I got a black GRUB box, I could see references to LINUX,
but the text was all wrapped, I didn't want to put it in the wrong place..
Could I add it temporarily into GRUB, and do update-grub, then put it back to normal after next boot.?
This is what I currently have in GRUB now:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX""
Would I put it in the:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=off"
or in
GRUB_CMDLINE_LINUX"acpi=off"
I have also been doing other research and found a lot of references to adding
acpi_osi=linux
after the existing "quiet splash" to make it:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=linux
Is this something I should be doing.?
"EDIT"
Forgot, I checked on the HP website, I do have most current BIOS = F.38
Many Thanks for your help, much appreciated
Regards - David
wirezfree
Postby lok1950 » Sat Mar 15, 2014 4:33 pm
Nothing of any use in the boot log just a bunch of ok's at the end of each line. Nelz strategy looks like the way to go.Have a look at the GRUB web site on editing it's files.The use of acpi_osi=linux does look interesting and worth a try.
Enjoy the Choice :)
lok1950
Postby nelz » Sat Mar 15, 2014 8:12 pm
I'd disable acpi entirely. If that helps, you can look at less extreme options, such as the one you quoted, but turn it off completely for now. You could edit a GRUB confg file, but you have already identified where the option goes, after the word splash.
In fact, I would press E and remove splash and quiet, replacing them with acpi=off. Then, if it does still pause, you can see exactly where.
I always disable splash screens, I prefer to see what is going on.
Postby lok1950 » Sat Mar 15, 2014 10:39 pm
nelz wrote:I always disable splash screens, I prefer to see what is going on
Using fedora I just hit the "Esc" key and watch closely as the boot process unfolds :D hoping nothing goes wrong.
Enjoy the Choice :D
lok1950
Boot Pause - "Update"
Postby wirezfree » Sun Mar 16, 2014 6:13 pm
I added the
acpi=off
to the GRUB line, the laptop hung on the Zorin Splash Screen.
I needed to re-boot, tapped the E, I could see the acpi=off
edited it out, and F10 to re-boot.
I removed it from the GRUB line, and updated GRUB.
I tried adding the:
acpi_osi=linux
Interesting, it did not affect the boot time, and it maybe to early to confirm,
But up to now, only been through 1 charge/dis-charge cycle on the laptop.
I used to get @ 3h 50mins of use, the last cycle I ran to @ 4h 35mins..??
So I still have the ~7 sec boot pause/delay, which I would really like to figure out.
But I may have increased the battery life..??, Will report on this separately.
Any other ideas welcome.
Regards - David
wirezfree
Postby nelz » Sun Mar 16, 2014 6:28 pm
When you add acpi=off, remove the quiet and splash options - they only stop you seeing what is happening.
Updated information - BUG Loop & lshw listing
Postby wirezfree » Sun Mar 16, 2014 8:26 pm
nelz wrote:When you add acpi=off, remove the quiet and splash options - they only stop you seeing what is happening.
Hi nelz,
I repeated with only acpi=off
It gets stuck in some kind of "BUG" loop.
I took a picture of the screen, it's on my public SugarSync at:
https://www.sugarsync.com/pf/D714267_77617033_6936577
Below is a complete listing of my system, if that helps.?
Thanks - David
wirezfree@zorin-hp:~$ sudo lshw
[sudo] password for wirezfree:
zorin-hp
    description: Notebook
    product: HP Pavilion TS 14 Notebook PC (F0G56EA#ABU)
    vendor: Hewlett-Packard
    serial: 5CD3394BSQ
    width: 64 bits
    capabilities: smbios-2.7 dmi-2.7 vsyscall32
    configuration: administrator_password=disabled boot=normal chassis=notebook family=103C_5335KV G=N L=CON B=HP S=PAV X=Null frontpanel_password=disabled keyboard_password=disabled power-on_password=disabled sku=F0G56EA#ABU uuid=35434433-3339-3442-5351-A0481C208A81
  *-core
       description: Motherboard
       product: 2161
       physical id: 0
       version: 29.34
       slot: Type2 - Board Chassis Location
     *-memory
          description: System Memory
          physical id: 2
          slot: System board or motherboard
        *-bank:0
             description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
             product: CT102464BF160B.C16
             vendor: Unknown
             physical id: 0
             serial: 60100000
             slot: Bottom-Slot 1(top)
             width: 64 bits
             clock: 1600MHz (0.6ns)
        *-bank:1
             vendor: Unknown
             physical id: 1
             serial: 35100000
             slot: Bottom-Slot 2(under)
             width: 64 bits
     *-firmware
          description: BIOS
          vendor: Insyde
          physical id: e
          version: F.34
          date: 10/31/2013
          capacity: 4032KiB
          capabilities: pci upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb biosbootspecification uefi
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
          vendor: Intel Corp.
          physical id: 2d
          bus info: cpu@0
          version: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
          serial: To Be Filled By O.E.M.
          slot: U3E1
          capacity: 759MHz
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm ida arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cpufreq
          configuration: cores=2 enabledcores=2 threads=4
        *-cache:0
             description: L1 cache
             physical id: 2f
             slot: L1 Cache
             capacity: 32KiB
             capabilities: synchronous internal write-back instruction
        *-cache:1
             description: L2 cache
             physical id: 30
             slot: L2 Cache
             capacity: 256KiB
             capabilities: synchronous internal write-back unified
        *-cache:2
             description: L3 cache
             physical id: 31
             slot: L3 Cache
             capacity: 3MiB
     *-cache
          physical id: 2e
          slot: L1 Cache
          capacity: 32KiB
          capabilities: synchronous internal write-back data
     *-pci
          description: Host bridge
          product: Haswell-ULT DRAM Controller
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 09
          width: 32 bits
          clock: 33MHz
        *-display
             description: VGA compatible controller
             product: Haswell-ULT Integrated Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 09
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:58 memory:b2000000-b23fffff memory:a0000000-afffffff ioport:6000(size=64)
        *-multimedia:0
             description: Audio device
             product: Intel Corporation
             physical id: 3
             bus info: pci@0000:00:03.0
             version: 09
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi pciexpress bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:61 memory:b2610000-b2613fff
        *-usb:0
             description: USB controller
             product: Lynx Point-LP USB xHCI HC
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:56 memory:b2600000-b260ffff
        *-communication
             description: Communication controller
             product: Lynx Point-LP HECI #0
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:60 memory:b2618000-b261801f
        *-multimedia:1
             product: Lynx Point-LP HD Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 04
             width: 64 bits
             clock: 33MHz
             resources: irq:62 memory:b2614000-b2617fff
        *-pci:0
             description: PCI bridge
             product: Lynx Point-LP PCI Express Root Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: e4
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16 ioport:2000(size=4096) memory:9fb00000-9fcfffff ioport:9fd00000(size=2097152)
        *-pci:1
             product: Lynx Point-LP PCI Express Root Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: e4
             width: 32 bits
             clock: 33MHz
             resources: irq:17 ioport:5000(size=4096) memory:b1000000-b1ffffff ioport:b0000000(size=16777216)
        *-pci:2
             product: Lynx Point-LP PCI Express Root Port 3
             physical id: 1c.2
             bus info: pci@0000:00:1c.2
             version: e4
             width: 32 bits
             clock: 33MHz
             resources: irq:18 ioport:4000(size=4096) memory:b2500000-b25fffff
           *-network
                description: Wireless interface
                product: RTL8188EE Wireless Network Adapter
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:08:00.0
                logical name: wlan0
                version: 01
                serial: 70:18:8b:c9:63:ad
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=rtl8188ee driverversion=3.11.0-18-generic firmware=N/A ip=10.10.10.101 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
                resources: irq:18 ioport:4000(size=256) memory:b2500000-b2503fff
        *-pci:3
             product: Lynx Point-LP PCI Express Root Port 4
             physical id: 1c.3
             bus info: pci@0000:00:1c.3
             version: e4
             width: 32 bits
             clock: 33MHz
             resources: irq:19 ioport:3000(size=4096) memory:b2400000-b24fffff
           *-network
                description: Ethernet interface
                product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
                physical id: 0
                bus info: pci@0000:09:00.0
                logical name: eth0
                version: 08
                serial: a0:48:1c:20:8a:81
                capacity: 100Mbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-2_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                resources: irq:57 ioport:3000(size=256) memory:b2404000-b2404fff memory:b2400000-b2403fff
        *-usb:1
             product: Lynx Point-LP USB EHCI #1
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=0
             resources: irq:23 memory:b261c000-b261c3ff
        *-isa
             description: ISA bridge
             product: Lynx Point-LP LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
        *-storage
             description: SATA controller
             product: Lynx Point-LP SATA Controller 1 [AHCI mode]
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 04
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:59 ioport:6088(size=8) ioport:6094(size=4) ioport:6080(size=8) ioport:6090(size=4) ioport:6060(size=32) memory:b261b000-b261b7ff
        *-serial UNCLAIMED
             description: SMBus
             product: Lynx Point-LP SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 04
             width: 64 bits
             clock: 33MHz
             configuration: latency=0
             resources: memory:b2619000-b26190ff ioport:6040(size=32)
     *-scsi:0
          physical id: 0
          logical name: scsi0
          capabilities: emulated
        *-disk
             description: ATA Disk
             product: Samsung SSD 840
             physical id: 0.0.0
             bus info: scsi@0:0.0.0
             logical name: /dev/sda
             version: DXM0
             serial: S1ATNSADB07491P
             capabilities: partitioned partitioned:dos
             configuration: ansiversion=5 sectorsize=512 signature=0002f651
           *-volume:0
                description: EXT4 volume
                vendor: Linux
                physical id: 1
                bus info: scsi@0:0.0.0,1
                logical name: /dev/sda1
                logical name: /
                version: 1.0
                serial: a179c840-1bde-48c9-b11e-11a080929c55
                capacity: 46GiB
                capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2014-02-26 21:27:42 filesystem=ext4 lastmountpoint=/ modified=2014-03-16 19:57:42 mount.fstype=ext4 mount.options=rw,noatime,errors=remount-ro,data=ordered mounted=2014-03-16 19:57:42 state=mounted
           *-volume:1
                description: Linux swap volume
                physical id: 2
                bus info: scsi@0:0.0.0,2
                logical name: /dev/sda2
                version: 1
                serial: 76478879-9d5e-4194-999b-4f3162cd4a5d
                capacity: 14GiB
                capabilities: primary nofs swap initialized
                configuration: filesystem=swap pagesize=4096
           *-volume:2
                vendor: Linux
                physical id: 3
                bus info: scsi@0:0.0.0,3
                logical name: /dev/sda3
                logical name: /home
                version: 1.0
                serial: 5e5fc6c6-fd93-4aa9-9f13-3ad2986bd892
                capacity: 172GiB
                capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
                configuration: created=2014-02-26 21:27:44 filesystem=ext4 lastmountpoint=/home modified=2014-03-16 19:57:43 mount.fstype=ext4 mount.options=rw,noatime,data=ordered mounted=2014-03-16 19:57:43 state=mounted
     *-scsi:1
          physical id: 1
          logical name: scsi1
        *-cdrom
             description: DVD-RAM writer
             product: DVD RAM UJ8C2
             vendor: hp
             physical id: 0.0.0
             bus info: scsi@1:0.0.0
             logical name: /dev/cdrom
             logical name: /dev/sr0
             version: 1.00
             capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
             configuration: ansiversion=5 status=nodisc
  *-battery
       description: Lithium-Ion Battery
       product: LA04041
       vendor: 11-85
       physical id: 1
       version: 01/01/2013
       serial: SERIAL
       slot: Primary
       capacity: 41440mWh
       configuration: voltage=14.8V
  *-power UNCLAIMED
       description: OEM_Define1
       product: OEM_Define5
       vendor: OEM_Define2
       physical id: 2
       version: OEM_Define6
       serial: OEM_Define3
       capacity: 75mWh
wirezfree
Postby lok1950 » Mon Mar 17, 2014 1:04 am
From your screen shot it looks indeed like a bug in either apparmor or netmanager so a check of the Zorin forums for this issue seems in order,if you find nothing there a post on that forum may reveal more info.Have you been updating as there may a bug fix in the repos.
Enjoy the Choice :)
lok1950
Postby nelz » Mon Mar 17, 2014 7:33 am
This looks like a bug in the CPU, which is reportedly fixed by installing the packages intel-microcode and microcode.ctl and rebooting.
