Change to Caja
Change to Caja
Postby heiowge » Tue Feb 18, 2014 10:28 pm
How can I make Caja the default file manager in Mint 16 MATE 32bit?
I don't mind Nemo, but find Caja works just the way I like. Problem is that I have both, and the system seems to prefer Nemo. I don't want to get rid of Nemo, just change the system priorities.
Postby lok1950 » Wed Feb 19, 2014 4:18 am
Had a similar issue with MATE on fedora 20 only Nautilus was the default have a look at preferred apps in the System menu IIRC set it to Caja BTW I really like it's embedded terminal plug-in quite handy :D
Enjoy the Choice :)
lok1950
Postby heiowge » Thu Feb 20, 2014 12:26 am
Thanks Lok1950. Done it. :D
