GCC 4 and Linux Kernel 2.11.7 issue
Postby complication » Sun Apr 24, 2005 12:00 am
I have recently successfully installed GCC 4.
After I do that I continue my script to install my kernel, which I know works,
#! /bin/sh
tar -xvjf gcc-4.0.0.tar.bz2
rm gcc-4.0.0.tar.bz2
cd gcc-4.0.0
mkdir obj
cd obj
../configure
make
make install
cd
rm -rf gcc-4.0.0
cp linux-2.6.11.7.tar.bz2 /usr/src/
rm linux-2.6.11.7.tar.bz2
cp vesafb-tng-0.9-rc6-2.6.11-rc1.patch /usr/src/
rm vesafb-tng-0.9-rc6-2.6.11-rc1.patch
cp grsecurity-2.1.5-2.6.11.7-200504111924.patch /usr/src/
rm grsecurity-2.1.5-2.6.11.7-200504111924.patch
cp configx /usr/src/
rm configx
cd /usr/src/
rm linux
ln -s linux-2.6.11.7 linux
#rm -rf linux ?
tar -xvjf linux-2.6.11.7.tar.bz2
cp vesafb-tng-0.9-rc6-2.6.11-rc1.patch linux
cp grsecurity-2.1.5-2.6.11.7-200504111924.patch linux
cd linux
patch -p1 < vesafb-tng-0.9-rc6-2.6.11-rc1.patch
patch -p1 < grsecurity-2.1.5-2.6.11.7-200504111924.patch
make mrproper
cp ../configx ./.config
make
make install
make modules
make modules_install
However after GCC is installed I now get this error in the step make (kernel make)
(lots more above here)
CC drivers/i2c/i2c-core.o
In file included from drivers/i2c/i2c-core.c:29:
include/linux/i2c.h:58: error: array type has incomplete element type
include/linux/i2c.h:197: error: array type has incomplete element type
drivers/i2c/i2c-core.c: In function 'i2c_transfer':
drivers/i2c/i2c-core.c:594: error: type of formal parameter 2 is incomplete
drivers/i2c/i2c-core.c: In function 'i2c_master_send':
drivers/i2c/i2c-core.c:620: error: type of formal parameter 2 is incomplete
drivers/i2c/i2c-core.c: In function 'i2c_master_recv':
drivers/i2c/i2c-core.c:649: error: type of formal parameter 2 is incomplete
make[2]: *** [drivers/i2c/i2c-core.o] Error 1
make[1]: *** [drivers/i2c] Error 2
make: *** [drivers] Error 2
here is my .config
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.11.7-grsec
# Thu Apr 21 23:25:28 2005
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_UID16=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_CLEAN_COMPILE=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
# General setup
CONFIG_LOCALVERSION=".psyche"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_SYSCTL=y
CONFIG_AUDIT=y
CONFIG_AUDITSYSCALL=y
CONFIG_LOG_BUF_SHIFT=14
CONFIG_HOTPLUG=y
CONFIG_KOBJECT_UEVENT=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
# CONFIG_EMBEDDED is not set
CONFIG_FUTEX=y
CONFIG_EPOLL=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SHMEM=y
CONFIG_CC_ALIGN_FUNCTIONS=0
CONFIG_CC_ALIGN_LABELS=0
CONFIG_CC_ALIGN_LOOPS=0
CONFIG_CC_ALIGN_JUMPS=0
# CONFIG_TINY_SHMEM is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_OBSOLETE_MODPARM=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_KMOD=y
# Processor type and features
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
# CONFIG_M686 is not set
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
CONFIG_MPENTIUMM=y
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MEFFICEON is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
# CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_HPET_TIMER=y
# CONFIG_HPET_EMULATE_RTC is not set
# CONFIG_SMP is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_BKL=y
CONFIG_X86_UP_APIC=y
CONFIG_X86_UP_IOAPIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_TSC=y
CONFIG_X86_MCE=y
CONFIG_X86_MCE_NONFATAL=y
CONFIG_X86_MCE_P4THERMAL=y
# CONFIG_TOSHIBA is not set
# CONFIG_I8K is not set
# CONFIG_MICROCODE is not set
# CONFIG_X86_MSR is not set
CONFIG_X86_CPUID=m
# Firmware Drivers
# CONFIG_EDD is not set
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM4G is not set
# CONFIG_HIGHMEM64G is not set
# CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
# CONFIG_EFI is not set
CONFIG_HAVE_DEC_LOCK=y
# CONFIG_REGPARM is not set
# Power management options (ACPI, APM)
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
CONFIG_SOFTWARE_SUSPEND=y
CONFIG_PM_STD_PARTITION=""
# ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI=y
CONFIG_ACPI_BOOT=y
CONFIG_ACPI_INTERPRETER=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SLEEP_PROC_FS=y
CONFIG_ACPI_AC=y
CONFIG_ACPI_BATTERY=y
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_VIDEO=y
CONFIG_ACPI_FAN=y
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_THERMAL=y
# CONFIG_ACPI_ASUS is not set
CONFIG_ACPI_IBM=y
# CONFIG_ACPI_TOSHIBA is not set
CONFIG_ACPI_BLACKLIST_YEAR=0
# CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_BUS=y
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_PCI=y
CONFIG_ACPI_SYSTEM=y
# CONFIG_X86_PM_TIMER is not set
# CONFIG_ACPI_CONTAINER is not set
# APM (Advanced Power Management) BIOS Support
# CONFIG_APM is not set
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_DEBUG is not set
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_STAT_DETAILS is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_TABLE=y
# CPUFreq processor drivers
CONFIG_X86_ACPI_CPUFREQ=y
# CONFIG_X86_POWERNOW_K6 is not set
# CONFIG_X86_POWERNOW_K7 is not set
# CONFIG_X86_POWERNOW_K8 is not set
# CONFIG_X86_GX_SUSPMOD is not set
CONFIG_X86_SPEEDSTEP_CENTRINO=y
CONFIG_X86_SPEEDSTEP_CENTRINO_ACPI=y
CONFIG_X86_SPEEDSTEP_CENTRINO_TABLE=y
# CONFIG_X86_SPEEDSTEP_ICH is not set
# CONFIG_X86_SPEEDSTEP_SMI is not set
# CONFIG_X86_P4_CLOCKMOD is not set
# CONFIG_X86_CPUFREQ_NFORCE2 is not set
# CONFIG_X86_LONGRUN is not set
# CONFIG_X86_LONGHAUL is not set
# shared options
# CONFIG_X86_ACPI_CPUFREQ_PROC_INTF is not set
# Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GOMMCONFIG is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
# CONFIG_PCIEPORTBUS is not set
CONFIG_PCI_MSI=y
CONFIG_PCI_LEGACY_PROC=y
CONFIG_PCI_NAMES=y
# CONFIG_ISA is not set
# CONFIG_MCA is not set
# CONFIG_SCx200 is not set
# PCCARD (PCMCIA/CardBus) support
CONFIG_PCCARD=y
# CONFIG_PCMCIA_DEBUG is not set
CONFIG_PCMCIA=y
CONFIG_CARDBUS=y
# PC-card bridges
CONFIG_YENTA=y
# CONFIG_PD6729 is not set
# CONFIG_I82092 is not set
# CONFIG_TCIC is not set
CONFIG_PCCARD_NONSTATIC=y
# PCI Hotplug Support
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_MISC=y
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
# Memory Technology Devices (MTD)
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
CONFIG_MTD_PARTITIONS=y
CONFIG_MTD_CONCAT=y
CONFIG_MTD_REDBOOT_PARTS=y
CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED=y
# CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
CONFIG_MTD_CMDLINE_PARTS=y
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLOCK=y
CONFIG_FTL=y
CONFIG_NFTL=y
CONFIG_NFTL_RW=y
CONFIG_INFTL=y
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
CONFIG_MTD_JEDECPROBE=y
CONFIG_MTD_GEN_PROBE=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_NOSWAP=y
# CONFIG_MTD_CFI_BE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_LE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_GEOMETRY is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_AMDSTD_RETRY=0
CONFIG_MTD_CFI_STAA=y
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_RAM=y
CONFIG_MTD_ROM=y
CONFIG_MTD_ABSENT=y
# CONFIG_MTD_XIP is not set
# Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
# CONFIG_MTD_PHYSMAP is not set
# CONFIG_MTD_PNC2000 is not set
# CONFIG_MTD_SC520CDP is not set
# CONFIG_MTD_NETSC520 is not set
# CONFIG_MTD_TS5500 is not set
# CONFIG_MTD_SBC_GXX is not set
# CONFIG_MTD_ELAN_104NC is not set
# CONFIG_MTD_SCx200_DOCFLASH is not set
# CONFIG_MTD_AMD76XROM is not set
# CONFIG_MTD_ICHXROM is not set
# CONFIG_MTD_SCB2_FLASH is not set
# CONFIG_MTD_NETtel is not set
# CONFIG_MTD_DILNETPC is not set
# CONFIG_MTD_L440GX is not set
# CONFIG_MTD_PCI is not set
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
# CONFIG_MTD_SLRAM is not set
CONFIG_MTD_PHRAM=y
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLKMTD is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
# NAND Flash Device Drivers
CONFIG_MTD_NAND=y
CONFIG_MTD_NAND_VERIFY_WRITE=y
CONFIG_MTD_NAND_IDS=y
CONFIG_MTD_NAND_DISKONCHIP=y
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED=y
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
CONFIG_MTD_NAND_DISKONCHIP_PROBE_HIGH=y
CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE=y
# CONFIG_MTD_NAND_NANDSIM is not set
# Parallel port support
CONFIG_PARPORT=y
CONFIG_PARPORT_PC=y
CONFIG_PARPORT_PC_CML1=y
CONFIG_PARPORT_SERIAL=y
CONFIG_PARPORT_PC_FIFO=y
CONFIG_PARPORT_PC_SUPERIO=y
# CONFIG_PARPORT_PC_PCMCIA is not set
# CONFIG_PARPORT_OTHER is not set
CONFIG_PARPORT_1284=y
# Plug and Play support
CONFIG_PNP=y
# CONFIG_PNP_DEBUG is not set
# Protocols
CONFIG_PNPACPI=y
# Block devices
# CONFIG_BLK_DEV_FD is not set
# CONFIG_PARIDE is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_CRYPTOLOOP=y
CONFIG_BLK_DEV_NBD=y
# CONFIG_BLK_DEV_SX8 is not set
# CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_LBD=y
CONFIG_CDROM_PKTCDVD=y
CONFIG_CDROM_PKTCDVD_BUFFERS=8
# CONFIG_CDROM_PKTCDVD_WCACHE is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_ATA_OVER_ETH is not set
# ATA/ATAPI/MFM/RLL support
CONFIG_IDE=y
CONFIG_BLK_DEV_IDE=y
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_IDE_SATA is not set
# CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
# CONFIG_BLK_DEV_IDECS is not set
CONFIG_BLK_DEV_IDECD=y
# CONFIG_BLK_DEV_IDETAPE is not set
# CONFIG_BLK_DEV_IDEFLOPPY is not set
CONFIG_BLK_DEV_IDESCSI=y
CONFIG_IDE_TASK_IOCTL=y
# IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=y
# CONFIG_BLK_DEV_CMD640 is not set
# CONFIG_BLK_DEV_IDEPNP is not set
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
# CONFIG_BLK_DEV_OFFBOARD is not set
CONFIG_BLK_DEV_GENERIC=y
# CONFIG_BLK_DEV_OPTI621 is not set
# CONFIG_BLK_DEV_RZ1000 is not set
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
# CONFIG_BLK_DEV_AEC62XX is not set
# CONFIG_BLK_DEV_ALI15X3 is not set
# CONFIG_BLK_DEV_AMD74XX is not set
# CONFIG_BLK_DEV_ATIIXP is not set
# CONFIG_BLK_DEV_CMD64X is not set
# CONFIG_BLK_DEV_TRIFLEX is not set
# CONFIG_BLK_DEV_CY82C693 is not set
# CONFIG_BLK_DEV_CS5520 is not set
# CONFIG_BLK_DEV_CS5530 is not set
# CONFIG_BLK_DEV_HPT34X is not set
# CONFIG_BLK_DEV_HPT366 is not set
# CONFIG_BLK_DEV_SC1200 is not set
CONFIG_BLK_DEV_PIIX=y
# CONFIG_BLK_DEV_NS87415 is not set
# CONFIG_BLK_DEV_PDC202XX_OLD is not set
# CONFIG_BLK_DEV_PDC202XX_NEW is not set
# CONFIG_BLK_DEV_SVWKS is not set
# CONFIG_BLK_DEV_SIIMAGE is not set
# CONFIG_BLK_DEV_SIS5513 is not set
# CONFIG_BLK_DEV_SLC90E66 is not set
# CONFIG_BLK_DEV_TRM290 is not set
# CONFIG_BLK_DEV_VIA82CXXX is not set
# CONFIG_IDE_ARM is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_IVB is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
CONFIG_SCSI=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
# CONFIG_SCSI_MULTI_LUN is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# SCSI Transport Attributes
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# SCSI low-level drivers
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC7XXX_OLD is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_DPT_I2O is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_SCSI_SATA is not set
# CONFIG_SCSI_BUSLOGIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_EATA is not set
# CONFIG_SCSI_EATA_PIO is not set
# CONFIG_SCSI_FUTURE_DOMAIN is not set
# CONFIG_SCSI_GDTH is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_PPA is not set
# CONFIG_SCSI_IMM is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_IPR is not set
# CONFIG_SCSI_QLOGIC_ISP is not set
# CONFIG_SCSI_QLOGIC_FC is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
CONFIG_SCSI_QLA2XXX=y
# CONFIG_SCSI_QLA21XX is not set
# CONFIG_SCSI_QLA22XX is not set
# CONFIG_SCSI_QLA2300 is not set
# CONFIG_SCSI_QLA2322 is not set
# CONFIG_SCSI_QLA6312 is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_DC390T is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_DEBUG is not set
# PCMCIA SCSI adapter support
# CONFIG_PCMCIA_AHA152X is not set
# CONFIG_PCMCIA_FDOMAIN is not set
# CONFIG_PCMCIA_NINJA_SCSI is not set
# CONFIG_PCMCIA_QLOGIC is not set
# CONFIG_PCMCIA_SYM53C500 is not set
# Multi-device support (RAID and LVM)
CONFIG_MD=y
CONFIG_BLK_DEV_MD=y
CONFIG_MD_LINEAR=y
CONFIG_MD_RAID0=y
CONFIG_MD_RAID1=y
CONFIG_MD_RAID10=y
CONFIG_MD_RAID5=y
CONFIG_MD_RAID6=y
CONFIG_MD_MULTIPATH=y
# CONFIG_MD_FAULTY is not set
CONFIG_BLK_DEV_DM=y
CONFIG_DM_CRYPT=y
CONFIG_DM_SNAPSHOT=y
CONFIG_DM_MIRROR=y
CONFIG_DM_ZERO=y
# Fusion MPT device support
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_IEEE1394 is not set
# I2O device support
CONFIG_I2O=m
CONFIG_I2O_CONFIG=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_SCSI=m
CONFIG_I2O_PROC=m
# Networking support
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_NETLINK_DEV=y
CONFIG_UNIX=y
CONFIG_NET_KEY=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=y
CONFIG_NET_IPGRE=y
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
# CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=y
CONFIG_INET_ESP=y
CONFIG_INET_IPCOMP=y
CONFIG_INET_TUNNEL=y
CONFIG_IP_TCPDIAG=y
CONFIG_IP_TCPDIAG_IPV6=y
# IP: Virtual Server Configuration
# CONFIG_IP_VS is not set
CONFIG_IPV6=y
CONFIG_IPV6_PRIVACY=y
CONFIG_INET6_AH=y
CONFIG_INET6_ESP=y
CONFIG_INET6_IPCOMP=y
CONFIG_INET6_TUNNEL=y
CONFIG_IPV6_TUNNEL=y
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_BRIDGE_NETFILTER=y
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=y
CONFIG_IP_NF_CT_ACCT=y
CONFIG_IP_NF_CONNTRACK_MARK=y
CONFIG_IP_NF_CT_PROTO_SCTP=y
CONFIG_IP_NF_FTP=y
CONFIG_IP_NF_IRC=y
CONFIG_IP_NF_TFTP=y
# CONFIG_IP_NF_AMANDA is not set
CONFIG_IP_NF_QUEUE=y
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_LIMIT=y
CONFIG_IP_NF_MATCH_IPRANGE=y
CONFIG_IP_NF_MATCH_MAC=y
CONFIG_IP_NF_MATCH_PKTTYPE=y
CONFIG_IP_NF_MATCH_MARK=y
CONFIG_IP_NF_MATCH_MULTIPORT=y
CONFIG_IP_NF_MATCH_TOS=y
CONFIG_IP_NF_MATCH_RECENT=y
CONFIG_IP_NF_MATCH_ECN=y
CONFIG_IP_NF_MATCH_DSCP=y
CONFIG_IP_NF_MATCH_AH_ESP=y
CONFIG_IP_NF_MATCH_LENGTH=y
CONFIG_IP_NF_MATCH_TTL=y
CONFIG_IP_NF_MATCH_TCPMSS=y
# CONFIG_IP_NF_MATCH_STEALTH is not set
CONFIG_IP_NF_MATCH_HELPER=y
CONFIG_IP_NF_MATCH_STATE=y
CONFIG_IP_NF_MATCH_CONNTRACK=y
CONFIG_IP_NF_MATCH_OWNER=y
# CONFIG_IP_NF_MATCH_PHYSDEV is not set
CONFIG_IP_NF_MATCH_ADDRTYPE=y
CONFIG_IP_NF_MATCH_REALM=y
CONFIG_IP_NF_MATCH_SCTP=y
CONFIG_IP_NF_MATCH_COMMENT=y
CONFIG_IP_NF_MATCH_CONNMARK=y
CONFIG_IP_NF_MATCH_HASHLIMIT=y
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_TARGET_LOG=y
CONFIG_IP_NF_TARGET_ULOG=y
CONFIG_IP_NF_TARGET_TCPMSS=y
CONFIG_IP_NF_NAT=y
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=y
CONFIG_IP_NF_TARGET_REDIRECT=y
CONFIG_IP_NF_TARGET_NETMAP=y
CONFIG_IP_NF_TARGET_SAME=y
CONFIG_IP_NF_NAT_SNMP_BASIC=y
CONFIG_IP_NF_NAT_IRC=y
CONFIG_IP_NF_NAT_FTP=y
CONFIG_IP_NF_NAT_TFTP=y
CONFIG_IP_NF_MANGLE=y
CONFIG_IP_NF_TARGET_TOS=y
CONFIG_IP_NF_TARGET_ECN=y
CONFIG_IP_NF_TARGET_DSCP=y
CONFIG_IP_NF_TARGET_MARK=y
CONFIG_IP_NF_TARGET_CLASSIFY=y
CONFIG_IP_NF_TARGET_CONNMARK=y
CONFIG_IP_NF_TARGET_CLUSTERIP=y
CONFIG_IP_NF_RAW=y
CONFIG_IP_NF_TARGET_NOTRACK=y
CONFIG_IP_NF_ARPTABLES=y
CONFIG_IP_NF_ARPFILTER=y
CONFIG_IP_NF_ARP_MANGLE=y
# IPv6: Netfilter Configuration
CONFIG_IP6_NF_QUEUE=y
CONFIG_IP6_NF_IPTABLES=y
CONFIG_IP6_NF_MATCH_LIMIT=y
CONFIG_IP6_NF_MATCH_MAC=y
CONFIG_IP6_NF_MATCH_RT=y
CONFIG_IP6_NF_MATCH_OPTS=y
CONFIG_IP6_NF_MATCH_FRAG=y
CONFIG_IP6_NF_MATCH_HL=y
CONFIG_IP6_NF_MATCH_MULTIPORT=y
CONFIG_IP6_NF_MATCH_OWNER=y
CONFIG_IP6_NF_MATCH_MARK=y
CONFIG_IP6_NF_MATCH_IPV6HEADER=y
CONFIG_IP6_NF_MATCH_AHESP=y
CONFIG_IP6_NF_MATCH_LENGTH=y
CONFIG_IP6_NF_MATCH_EUI64=y
CONFIG_IP6_NF_MATCH_PHYSDEV=y
CONFIG_IP6_NF_FILTER=y
CONFIG_IP6_NF_TARGET_LOG=y
CONFIG_IP6_NF_MANGLE=y
CONFIG_IP6_NF_TARGET_MARK=y
CONFIG_IP6_NF_RAW=y
# DECnet: Netfilter Configuration
# CONFIG_DECNET_NF_GRABULATOR is not set
# Bridge: Netfilter Configuration
CONFIG_BRIDGE_NF_EBTABLES=y
CONFIG_BRIDGE_EBT_BROUTE=y
CONFIG_BRIDGE_EBT_T_FILTER=y
CONFIG_BRIDGE_EBT_T_NAT=y
CONFIG_BRIDGE_EBT_802_3=y
CONFIG_BRIDGE_EBT_AMONG=y
CONFIG_BRIDGE_EBT_ARP=y
CONFIG_BRIDGE_EBT_IP=y
CONFIG_BRIDGE_EBT_LIMIT=y
CONFIG_BRIDGE_EBT_MARK=y
CONFIG_BRIDGE_EBT_PKTTYPE=y
CONFIG_BRIDGE_EBT_STP=y
CONFIG_BRIDGE_EBT_VLAN=y
CONFIG_BRIDGE_EBT_ARPREPLY=y
CONFIG_BRIDGE_EBT_DNAT=y
CONFIG_BRIDGE_EBT_MARK_T=y
CONFIG_BRIDGE_EBT_REDIRECT=y
CONFIG_BRIDGE_EBT_SNAT=y
CONFIG_BRIDGE_EBT_LOG=y
# CONFIG_BRIDGE_EBT_ULOG is not set
CONFIG_XFRM=y
CONFIG_XFRM_USER=y
# SCTP Configuration (EXPERIMENTAL)
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_MSG is not set
# CONFIG_SCTP_DBG_OBJCNT is not set
# CONFIG_SCTP_HMAC_NONE is not set
# CONFIG_SCTP_HMAC_SHA1 is not set
CONFIG_SCTP_HMAC_MD5=y
# CONFIG_ATM is not set
CONFIG_BRIDGE=y
CONFIG_VLAN_8021Q=y
CONFIG_DECNET=y
# CONFIG_DECNET_ROUTER is not set
CONFIG_LLC=y
CONFIG_LLC2=y
CONFIG_IPX=y
CONFIG_IPX_INTERN=y
CONFIG_ATALK=y
CONFIG_DEV_APPLETALK=y
CONFIG_IPDDP=y
CONFIG_IPDDP_ENCAP=y
CONFIG_IPDDP_DECAP=y
CONFIG_X25=y
CONFIG_LAPB=y
CONFIG_NET_DIVERT=y
# CONFIG_ECONET is not set
CONFIG_WAN_ROUTER=y
# QoS and/or fair queueing
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CLK_JIFFIES=y
# CONFIG_NET_SCH_CLK_GETTIMEOFDAY is not set
# CONFIG_NET_SCH_CLK_CPU is not set
CONFIG_NET_SCH_CBQ=y
CONFIG_NET_SCH_HTB=y
CONFIG_NET_SCH_HFSC=y
CONFIG_NET_SCH_PRIO=y
CONFIG_NET_SCH_RED=y
CONFIG_NET_SCH_SFQ=y
CONFIG_NET_SCH_TEQL=y
CONFIG_NET_SCH_TBF=y
CONFIG_NET_SCH_GRED=y
CONFIG_NET_SCH_DSMARK=y
CONFIG_NET_SCH_NETEM=y
CONFIG_NET_SCH_INGRESS=y
CONFIG_NET_QOS=y
CONFIG_NET_ESTIMATOR=y
CONFIG_NET_CLS=y
CONFIG_NET_CLS_TCINDEX=y
CONFIG_NET_CLS_ROUTE4=y
CONFIG_NET_CLS_ROUTE=y
CONFIG_NET_CLS_FW=y
CONFIG_NET_CLS_U32=y
CONFIG_CLS_U32_PERF=y
CONFIG_NET_CLS_IND=y
# CONFIG_CLS_U32_MARK is not set
CONFIG_NET_CLS_RSVP=y
CONFIG_NET_CLS_RSVP6=y
# CONFIG_NET_CLS_ACT is not set
CONFIG_NET_CLS_POLICE=y
# Network testing
CONFIG_NET_PKTGEN=y
CONFIG_NETPOLL=y
# CONFIG_NETPOLL_RX is not set
# CONFIG_NETPOLL_TRAP is not set
CONFIG_NET_POLL_CONTROLLER=y
# CONFIG_HAMRADIO is not set
CONFIG_IRDA=y
# IrDA protocols
CONFIG_IRLAN=y
# CONFIG_IRNET is not set
CONFIG_IRCOMM=y
CONFIG_IRDA_ULTRA=y
# IrDA options
CONFIG_IRDA_CACHE_LAST_LSAP=y
CONFIG_IRDA_FAST_RR=y
# CONFIG_IRDA_DEBUG is not set
# Infrared-port device drivers
# SIR device drivers
CONFIG_IRTTY_SIR=y
# Dongle support
# CONFIG_DONGLE is not set
# Old SIR device drivers
CONFIG_IRPORT_SIR=y
# Old Serial dongle support
# CONFIG_DONGLE_OLD is not set
# FIR device drivers
# CONFIG_USB_IRDA is not set
# CONFIG_SIGMATEL_FIR is not set
# CONFIG_TOSHIBA_FIR is not set
# CONFIG_VLSI_FIR is not set
CONFIG_BT=y
CONFIG_BT_L2CAP=y
CONFIG_BT_SCO=y
CONFIG_BT_RFCOMM=y
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=y
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=y
# Bluetooth device drivers
CONFIG_BT_HCIUSB=y
CONFIG_BT_HCIUSB_SCO=y
# CONFIG_BT_HCIUART is not set
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
# CONFIG_BT_HCIBFUSB is not set
# CONFIG_BT_HCIDTL1 is not set
# CONFIG_BT_HCIBT3C is not set
# CONFIG_BT_HCIBLUECARD is not set
# CONFIG_BT_HCIBTUART is not set
# CONFIG_BT_HCIVHCI is not set
CONFIG_NETDEVICES=y
CONFIG_DUMMY=y
CONFIG_BONDING=y
CONFIG_EQUALIZER=y
CONFIG_TUN=y
CONFIG_ETHERTAP=y
# CONFIG_NET_SB1000 is not set
# ARCnet devices
# CONFIG_ARCNET is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_NET_VENDOR_3COM is not set
# Tulip family network device support
# CONFIG_NET_TULIP is not set
# CONFIG_HP100 is not set
# CONFIG_NET_PCI is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
CONFIG_E1000=y
CONFIG_E1000_NAPI=y
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_R8169 is not set
# CONFIG_SK98LIN is not set
# CONFIG_TIGON3 is not set
# Ethernet (10000 Mbit)
# CONFIG_IXGB is not set
# CONFIG_S2IO is not set
# Token Ring devices
# CONFIG_TR is not set
# Wireless LAN (non-hamradio)
CONFIG_NET_RADIO=y
# Obsolete Wireless cards support (pre-802.11)
# CONFIG_STRIP is not set
# CONFIG_PCMCIA_WAVELAN is not set
# CONFIG_PCMCIA_NETWAVE is not set
# Wireless 802.11 Frequency Hopping cards support
# CONFIG_PCMCIA_RAYCS is not set
# Wireless 802.11b ISA/PCI cards support
# CONFIG_HERMES is not set
# CONFIG_ATMEL is not set
# Wireless 802.11b Pcmcia/Cardbus cards support
CONFIG_AIRO_CS=y
# CONFIG_PCMCIA_WL3501 is not set
# Prism GT/Duette 802.11(a/b/g) PCI/Cardbus support
CONFIG_PRISM54=y
CONFIG_NET_WIRELESS=y
# PCMCIA network device support
# CONFIG_NET_PCMCIA is not set
# Wan interfaces
# CONFIG_WAN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_PLIP=y
CONFIG_PPP=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPPOE=y
CONFIG_SLIP=y
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
# CONFIG_NET_FC is not set
CONFIG_SHAPER=y
CONFIG_NETCONSOLE=y
# ISDN subsystem
# CONFIG_ISDN is not set
# Telephony Support
CONFIG_PHONE=y
# CONFIG_PHONE_IXJ is not set
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_TSDEV is not set
# CONFIG_INPUT_EVDEV is not set
# CONFIG_INPUT_EVBUG is not set
# Input I/O drivers
# CONFIG_GAMEPORT is not set
CONFIG_SOUND_GAMEPORT=y
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
# CONFIG_SERIO_SERPORT is not set
# CONFIG_SERIO_CT82C710 is not set
# CONFIG_SERIO_PARKBD is not set
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=y
# CONFIG_INPUT_UINPUT is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_CONSOLE is not set
# CONFIG_SERIAL_8250_CS is not set
# CONFIG_SERIAL_8250_ACPI is not set
CONFIG_SERIAL_8250_NR_UARTS=4
# CONFIG_SERIAL_8250_EXTENDED is not set
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_PRINTER=y
# CONFIG_LP_CONSOLE is not set
# CONFIG_PPDEV is not set
# CONFIG_TIPAR is not set
# IPMI
CONFIG_IPMI_HANDLER=y
CONFIG_IPMI_PANIC_EVENT=y
CONFIG_IPMI_PANIC_STRING=y
CONFIG_IPMI_DEVICE_INTERFACE=y
CONFIG_IPMI_SI=y
CONFIG_IPMI_WATCHDOG=y
CONFIG_IPMI_POWEROFF=y
# Watchdog Cards
# CONFIG_WATCHDOG is not set
CONFIG_HW_RANDOM=y
CONFIG_NVRAM=y
CONFIG_RTC=y
# CONFIG_DTLK is not set
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_SONYPI is not set
# Ftape, the floppy tape device driver
# CONFIG_FTAPE is not set
CONFIG_AGP=y
# CONFIG_AGP_ALI is not set
CONFIG_AGP_ATI=y
# CONFIG_AGP_AMD is not set
# CONFIG_AGP_AMD64 is not set
# CONFIG_AGP_INTEL is not set
# CONFIG_AGP_INTEL_MCH is not set
# CONFIG_AGP_NVIDIA is not set
# CONFIG_AGP_SIS is not set
# CONFIG_AGP_SWORKS is not set
# CONFIG_AGP_VIA is not set
# CONFIG_AGP_EFFICEON is not set
CONFIG_DRM=y
# CONFIG_DRM_TDFX is not set
# CONFIG_DRM_R128 is not set
CONFIG_DRM_RADEON=y
# CONFIG_DRM_I830 is not set
# CONFIG_DRM_I915 is not set
# CONFIG_DRM_MGA is not set
# CONFIG_DRM_SIS is not set
# PCMCIA character devices
# CONFIG_SYNCLINK_CS is not set
CONFIG_MWAVE=y
# CONFIG_RAW_DRIVER is not set
CONFIG_HPET=y
CONFIG_HPET_RTC_IRQ=y
CONFIG_HPET_MMAP=y
# CONFIG_HANGCHECK_TIMER is not set
# I2C support
CONFIG_I2C=y
# CONFIG_I2C_CHARDEV is not set
# I2C Algorithms
CONFIG_I2C_ALGOBIT=y
# CONFIG_I2C_ALGOPCF is not set
# CONFIG_I2C_ALGOPCA is not set
# I2C Hardware Bus support
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_I810 is not set
# CONFIG_I2C_ISA is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_PARPORT is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_PROSAVAGE is not set
# CONFIG_I2C_SAVAGE4 is not set
# CONFIG_SCx200_ACB is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# CONFIG_I2C_VOODOO3 is not set
# CONFIG_I2C_PCA_ISA is not set
# Hardware Sensors Chip support
# CONFIG_I2C_SENSOR is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ASB100 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_FSCHER is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_VIA686A is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83627HF is not set
# Other I2C Chip support
# CONFIG_SENSORS_EEPROM is not set
# CONFIG_SENSORS_PCF8574 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_SENSORS_RTC8564 is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# Dallas's 1-wire bus
# CONFIG_W1 is not set
# Misc devices
# CONFIG_IBM_ASM is not set
# Multimedia devices
# CONFIG_VIDEO_DEV is not set
# Digital Video Broadcasting Devices
# CONFIG_DVB is not set
# Graphics support
CONFIG_FB=y
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_VGA16 is not set
CONFIG_FB_VESA=y
# CONFIG_FB_VESA_STD is not set
CONFIG_FB_VESA_TNG=y
CONFIG_FB_VESA_DEFAULT_MODE="1400x1050@50"
CONFIG_VIDEO_SELECT=y
# CONFIG_FB_HGA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I810 is not set
# CONFIG_FB_INTEL is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON_OLD is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_VIRTUAL is not set
# Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FONTS=y
# CONFIG_FONT_8x8 is not set
# CONFIG_FONT_8x16 is not set
# CONFIG_FONT_6x11 is not set
# CONFIG_FONT_PEARL_8x8 is not set
# CONFIG_FONT_ACORN_8x8 is not set
# CONFIG_FONT_MINI_4x6 is not set
CONFIG_FONT_SUN8x16=y
# CONFIG_FONT_SUN12x22 is not set
# Logo configuration
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Sound
CONFIG_SOUND=y
# Advanced Linux Sound Architecture
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_RAWMIDI=y
CONFIG_SND_SEQUENCER=y
# CONFIG_SND_SEQ_DUMMY is not set
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=y
CONFIG_SND_PCM_OSS=y
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_RTCTIMER=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# Generic devices
CONFIG_SND_MPU401_UART=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_VIRMIDI is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
CONFIG_SND_MPU401=y
# PCI devices
CONFIG_SND_AC97_CODEC=y
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_YMFPCI is not set
# CONFIG_SND_ALS4000 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_FM801 is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
CONFIG_SND_INTEL8X0=y
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VX222 is not set
# USB devices
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_USX2Y is not set
# PCMCIA devices
# Open Sound System
# CONFIG_SOUND_PRIME is not set
# USB support
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_BANDWIDTH=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_SUSPEND is not set
# CONFIG_USB_OTG is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
# USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_SPLIT_ISO is not set
CONFIG_USB_EHCI_ROOT_HUB_TT=y
# CONFIG_USB_OHCI_HCD is not set
CONFIG_USB_UHCI_HCD=y
# CONFIG_USB_SL811_HCD is not set
# USB Device Class drivers
# CONFIG_USB_AUDIO is not set
# USB Bluetooth TTY can only be used with disabled Bluetooth subsystem
# CONFIG_USB_MIDI is not set
# CONFIG_USB_ACM is not set
CONFIG_USB_PRINTER=y
# NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support' may also be needed; see USB_STORAGE Help for more information
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_RW_DETECT=y
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_HP8200e is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# USB Input Devices
CONFIG_USB_HID=y
CONFIG_USB_HIDINPUT=y
# CONFIG_HID_FF is not set
# CONFIG_USB_HIDDEV is not set
# CONFIG_USB_AIPTEK is not set
# CONFIG_USB_WACOM is not set
# CONFIG_USB_KBTAB is not set
# CONFIG_USB_POWERMATE is not set
# CONFIG_USB_MTOUCH is not set
# CONFIG_USB_EGALAX is not set
# CONFIG_USB_XPAD is not set
# CONFIG_USB_ATI_REMOTE is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB Multimedia devices
# CONFIG_USB_DABUSB is not set
# Video4Linux support is needed for USB Multimedia device support
# USB Network Adapters
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_USBNET=m
# USB Host-to-Host Cables
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_GENESYS=y
CONFIG_USB_NET1080=y
CONFIG_USB_PL2301=y
CONFIG_USB_KC2190=y
# Intelligent USB Devices/Gadgets
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_ZAURUS=y
CONFIG_USB_CDCETHER=y
CONFIG_USB_AX8817X=y
# USB port drivers
# CONFIG_USB_USS720 is not set
# USB Serial Converter support
CONFIG_USB_SERIAL=y
# CONFIG_USB_SERIAL_CONSOLE is not set
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
# CONFIG_USB_SERIAL_FTDI_SIO is not set
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_PL2303 is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
# CONFIG_USB_SERIAL_OMNINET is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_AUERSWALD is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_PHIDGETKIT is not set
# CONFIG_USB_PHIDGETSERVO is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_TEST is not set
# USB ATM/DSL drivers
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# MMC/SD Card support
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_BLOCK=y
# InfiniBand support
# CONFIG_INFINIBAND is not set
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=y
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
CONFIG_REISERFS_FS_SECURITY=y
CONFIG_JFS_FS=y
CONFIG_JFS_POSIX_ACL=y
# CONFIG_JFS_SECURITY is not set
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_FS_POSIX_ACL=y
# XFS support
CONFIG_XFS_FS=y
CONFIG_XFS_EXPORT=y
CONFIG_XFS_RT=y
CONFIG_XFS_QUOTA=y
CONFIG_XFS_SECURITY=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_MINIX_FS=y
CONFIG_ROMFS_FS=y
CONFIG_QUOTA=y
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
CONFIG_DNOTIFY=y
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_ZISOFS_FS=y
CONFIG_UDF_FS=y
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=y
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_SYSFS=y
# CONFIG_DEVFS_FS is not set
CONFIG_DEVPTS_FS_XATTR=y
CONFIG_DEVPTS_FS_SECURITY=y
CONFIG_TMPFS=y
CONFIG_TMPFS_XATTR=y
CONFIG_TMPFS_SECURITY=y
CONFIG_HUGETLBFS=y
CONFIG_HUGETLB_PAGE=y
CONFIG_RAMFS=y
# Miscellaneous filesystems
CONFIG_ADFS_FS=m
# CONFIG_ADFS_FS_RW is not set
CONFIG_AFFS_FS=m
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_BEFS_FS=m
# CONFIG_BEFS_DEBUG is not set
CONFIG_BFS_FS=m
CONFIG_EFS_FS=m
CONFIG_JFFS_FS=y
CONFIG_JFFS_FS_VERBOSE=0
CONFIG_JFFS_PROC_FS=y
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_NAND=y
# CONFIG_JFFS2_FS_NOR_ECC is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_CRAMFS=y
CONFIG_VXFS_FS=m
CONFIG_HPFS_FS=m
CONFIG_QNX4FS_FS=m
CONFIG_SYSV_FS=m
CONFIG_UFS_FS=m
# CONFIG_UFS_FS_WRITE is not set
# Network File Systems
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
CONFIG_NFS_V4=y
# CONFIG_NFS_DIRECTIO is not set
CONFIG_NFSD=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_TCP=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
CONFIG_RPCSEC_GSS_KRB5=y
CONFIG_RPCSEC_GSS_SPKM3=y
CONFIG_SMB_FS=y
# CONFIG_SMB_NLS_DEFAULT is not set
CONFIG_CIFS=y
CONFIG_CIFS_STATS=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_EXPERIMENTAL=y
CONFIG_NCP_FS=y
CONFIG_NCPFS_PACKET_SIGNING=y
CONFIG_NCPFS_IOCTL_LOCKING=y
CONFIG_NCPFS_STRONG=y
CONFIG_NCPFS_NFS_NS=y
CONFIG_NCPFS_OS2_NS=y
CONFIG_NCPFS_SMALLDOS=y
CONFIG_NCPFS_NLS=y
CONFIG_NCPFS_EXTRAS=y
CONFIG_CODA_FS=y
CONFIG_CODA_FS_OLD_API=y
CONFIG_AFS_FS=y
CONFIG_RXRPC=y
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
CONFIG_NLS_CODEPAGE_932=y
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Profiling support
CONFIG_PROFILING=y
CONFIG_OPROFILE=y
# Kernel hacking
# CONFIG_DEBUG_KERNEL is not set
CONFIG_DEBUG_PREEMPT=y
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_FRAME_POINTER is not set
CONFIG_EARLY_PRINTK=y
CONFIG_4KSTACKS=y
CONFIG_X86_FIND_SMP_CONFIG=y
CONFIG_X86_MPPARSE=y
# Security options
# Grsecurity
CONFIG_GRKERNSEC=y
# CONFIG_GRKERNSEC_LOW is not set
# CONFIG_GRKERNSEC_MEDIUM is not set
CONFIG_GRKERNSEC_HIGH=y
# CONFIG_GRKERNSEC_CUSTOM is not set
# Address Space Protection
CONFIG_GRKERNSEC_KMEM=y
# CONFIG_GRKERNSEC_IO is not set
CONFIG_GRKERNSEC_PROC_MEMMAP=y
CONFIG_GRKERNSEC_BRUTE=y
CONFIG_GRKERNSEC_HIDESYM=y
# Role Based Access Control Options
# CONFIG_GRKERNSEC_ACL_HIDEKERN is not set
CONFIG_GRKERNSEC_ACL_MAXTRIES=3
CONFIG_GRKERNSEC_ACL_TIMEOUT=30
# Filesystem Protections
CONFIG_GRKERNSEC_PROC=y
# CONFIG_GRKERNSEC_PROC_USER is not set
CONFIG_GRKERNSEC_PROC_USERGROUP=y
CONFIG_GRKERNSEC_PROC_GID=1001
CONFIG_GRKERNSEC_PROC_ADD=y
CONFIG_GRKERNSEC_LINK=y
CONFIG_GRKERNSEC_FIFO=y
CONFIG_GRKERNSEC_CHROOT=y
CONFIG_GRKERNSEC_CHROOT_MOUNT=y
CONFIG_GRKERNSEC_CHROOT_DOUBLE=y
CONFIG_GRKERNSEC_CHROOT_PIVOT=y
CONFIG_GRKERNSEC_CHROOT_CHDIR=y
CONFIG_GRKERNSEC_CHROOT_CHMOD=y
CONFIG_GRKERNSEC_CHROOT_FCHDIR=y
CONFIG_GRKERNSEC_CHROOT_MKNOD=y
CONFIG_GRKERNSEC_CHROOT_SHMAT=y
CONFIG_GRKERNSEC_CHROOT_UNIX=y
CONFIG_GRKERNSEC_CHROOT_FINDTASK=y
CONFIG_GRKERNSEC_CHROOT_NICE=y
CONFIG_GRKERNSEC_CHROOT_SYSCTL=y
CONFIG_GRKERNSEC_CHROOT_CAPS=y
# Kernel Auditing
# CONFIG_GRKERNSEC_AUDIT_GROUP is not set
# CONFIG_GRKERNSEC_EXECLOG is not set
CONFIG_GRKERNSEC_RESLOG=y
# CONFIG_GRKERNSEC_CHROOT_EXECLOG is not set
# CONFIG_GRKERNSEC_AUDIT_CHDIR is not set
CONFIG_GRKERNSEC_AUDIT_MOUNT=y
# CONFIG_GRKERNSEC_AUDIT_IPC is not set
CONFIG_GRKERNSEC_SIGNAL=y
CONFIG_GRKERNSEC_FORKFAIL=y
CONFIG_GRKERNSEC_TIME=y
# CONFIG_GRKERNSEC_PROC_IPADDR is not set
# CONFIG_GRKERNSEC_AUDIT_TEXTREL is not set
# Executable Protections
CONFIG_GRKERNSEC_EXECVE=y
CONFIG_GRKERNSEC_SHM=y
CONFIG_GRKERNSEC_DMESG=y
CONFIG_GRKERNSEC_RANDPID=y
# CONFIG_GRKERNSEC_TPE is not set
# Network Protections
CONFIG_GRKERNSEC_RANDNET=y
CONFIG_GRKERNSEC_RANDSRC=y
# CONFIG_GRKERNSEC_SOCKET is not set
# Sysctl support
# CONFIG_GRKERNSEC_SYSCTL is not set
# Logging Options
CONFIG_GRKERNSEC_FLOODTIME=10
CONFIG_GRKERNSEC_FLOODBURST=4
# PaX
CONFIG_PAX=y
# PaX Control
# CONFIG_PAX_SOFTMODE is not set
CONFIG_PAX_EI_PAX=y
CONFIG_PAX_PT_PAX_FLAGS=y
# CONFIG_PAX_NO_ACL_FLAGS is not set
CONFIG_PAX_HAVE_ACL_FLAGS=y
# CONFIG_PAX_HOOK_ACL_FLAGS is not set
# Non-executable pages
CONFIG_PAX_NOEXEC=y
# CONFIG_PAX_PAGEEXEC is not set
CONFIG_PAX_SEGMEXEC=y
# CONFIG_PAX_EMUTRAMP is not set
CONFIG_PAX_MPROTECT=y
# CONFIG_PAX_NOELFRELOCS is not set
# Address Space Layout Randomization
CONFIG_PAX_ASLR=y
CONFIG_PAX_RANDKSTACK=y
CONFIG_PAX_RANDUSTACK=y
CONFIG_PAX_RANDMMAP=y
CONFIG_PAX_NOVSYSCALL=y
CONFIG_KEYS=y
CONFIG_KEYS_DEBUG_PROC_KEYS=y
CONFIG_SECURITY=y
CONFIG_SECURITY_NETWORK=y
CONFIG_SECURITY_CAPABILITIES=y
CONFIG_SECURITY_ROOTPLUG=y
CONFIG_SECURITY_SECLVL=y
CONFIG_SECURITY_SELINUX=y
# CONFIG_SECURITY_SELINUX_BOOTPARAM is not set
CONFIG_SECURITY_SELINUX_DISABLE=y
CONFIG_SECURITY_SELINUX_DEVELOP=y
CONFIG_SECURITY_SELINUX_AVC_STATS=y
CONFIG_SECURITY_SELINUX_MLS=y
# Cryptographic options
CONFIG_CRYPTO=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_MD4=y
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_WP512=y
CONFIG_CRYPTO_DES=y
CONFIG_CRYPTO_BLOWFISH=y
CONFIG_CRYPTO_TWOFISH=y
CONFIG_CRYPTO_SERPENT=y
CONFIG_CRYPTO_AES_586=y
CONFIG_CRYPTO_CAST5=y
CONFIG_CRYPTO_CAST6=y
CONFIG_CRYPTO_TEA=y
CONFIG_CRYPTO_ARC4=y
CONFIG_CRYPTO_KHAZAD=y
CONFIG_CRYPTO_ANUBIS=y
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_MICHAEL_MIC=y
CONFIG_CRYPTO_CRC32C=y
CONFIG_CRYPTO_TEST=y
# Hardware crypto devices
# CONFIG_CRYPTO_DEV_PADLOCK is not set
# Library routines
CONFIG_CRC_CCITT=y
CONFIG_CRC32=y
CONFIG_LIBCRC32C=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_REED_SOLOMON=y
CONFIG_REED_SOLOMON_DEC16=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_X86_BIOS_REBOOT=y
CONFIG_PC=y
How should I fix this ?
complication
Postby complication » Sun Apr 24, 2005 12:47 am
The answer was to remove the i2c support.
This kernel is bloated, tell me what can I remove do you think ?
Its a Thinkpad T40p
complication
Postby Guest » Mon Apr 25, 2005 1:34 pm
If you really want to compile the kernel with gcc-4.0, you are on your own sunshine!
As for what you can remove from the kernel config: it's difficult to say without knowing (a) what hardware you have, or (b) what features you want.
Anyway, at least I know I shouldn't bother compiling the kernel with gcc-4.0 just yet: I need i2c support for my TV tuner...
Postby Guest » Tue Apr 26, 2005 2:28 am
Well im running my kernel compiled with it right now, so I guess my sunshines in a bag.
My hardware is a ThinkPad t40p,
Postby Guest » Wed May 04, 2005 9:22 pm
<abuse removed>
Postby Guest » Fri May 06, 2005 10:21 am
In file include/linux/i2c.h at line 58, change the string array from somevalue[] to *somevalue.
vcbcvbcv
Postby bvcbcv » Sun May 15, 2005 3:43 pm
bvcbcv
ghgh
Postby hgfghg » Sun May 15, 2005 4:04 pm
zzzzzzzzzz
hgfghg
