How do install the propriety drivers please?
Postby Alex01UK » Mon Dec 16, 2013 11:49 pm
64 bit Ubuntu Studio 13.1o Need a cli command;got root shell.
13.3'' Apple MacBook Pro: OS X Yosemite, 64bit Unicorn Studio 15.o4, 32bit Mint 17.1 MATE
Alex01UK
Postby johnhudson » Tue Dec 17, 2013 9:17 pm
Why would you want proprietory drivers?
Say which of the ones you have are unsatisfactory and then those who have similar hardware can advise on whether it is worth trying to install a proprietory driver.
Postby Alex01UK » Wed Dec 18, 2013 12:56 pm
johnhudson wrote:Why would you want proprietory drivers?
I have a vga monitor plugged into my laptop. On Windows 7 I get 1280 x 1024 but on Ubuntu only 1024 x 768. I was thinking, that the ATI propriety drivers might give a higher resolution screen. ATI Mobility Radeon HD 4250 Graphics using 256 Gb of memory.
tia, from Alex.
Alex01UK
Postby johnhudson » Fri Dec 20, 2013 10:04 pm
According to https://en.wikipedia.org/wiki/Radeon you are right to consider installing the proprietary drivers as the open source driver has limitations.
Look for fglrx in the Ubuntu repositories.
Postby Alex01UK » Tue Dec 31, 2013 4:07 pm
johnhudson wrote:According to https://en.wikipedia.org/wiki/Radeon you are right to consider installing the proprietary drivers as the open source driver has limitations.
Installing Gnome 3.8 ATI Raeden drivers with 21 propriety drivers munged my install. now can only login as guest with no access ctrl 2 alt is working password is fine. need tosort ubuntu 13.1o The Saucy Salamander with Lowatency Kernel. 64 bit AMD. acn get rootshell just want to resole the propriety fdrivers.
cli command to remover all ATI please. can get rootshell creeate a knew user/ Mobility Radeon TM 425o Graphic with 256 gig memory.
Alex01UK
