architecture mismatch
Postby bobthebob1234 » Sat Nov 02, 2013 10:19 pm
hello. I've got a vps that was originally 32bit but I had to switch to a 64bit kernel for various reasons.
now when I do
$ uname -m
x86_64
but when I do
$ dpkg --print-architecture
i386
I'm trying to install a gem which I believe is installing a 64bit version of a dependency and then use the 32bit version of it...
I've tried to install build-essentials:amd64, however dpkg-dev:amd64 keeps switching to dpkg-dev for some reason
Is there a way to change what architecture dpkg thinks it is? I've tried a couple of ways from the internets but none have worked. I'm using Ubuntu 12.04
Just for info I'm trying to install 'therubyracer' gem which doesn't seem to be particularly reliable at installing, but I have tried many things suggested on the intertubes, and it installs without a hitch on my 64bit desktop...
bobthebob1234
Re: architecture mismatch
Postby Nuke » Sun Nov 03, 2013 4:33 pm
bobthebob1234 wrote:now when I do
$ uname -m
x86_64
but when I do
i386
Funny, I've just tried it and I get :-
amd64
$ uname -m
x86_64
In fact I have an amd64 ; maybe uname (of which I had never heard) has itself never heard of amd64 :wink:
Like I have just been doing some ext4 disk formatting, and find I must use the mke2fs utility, the "e2" meaning ext2.
Nuke
Postby nelz » Sun Nov 03, 2013 5:38 pm
When Intel adopted the amd64 architecture, it was given the generic name of x86_64, so the two things mean exactly the same.
Users browsing this forum: guy and 3 guests
