I am pleasantly surprised...
Postby Bazza » Sun Oct 20, 2013 8:19 pm
Hi guys...
I uploaded this ultra simple piece of Python code to here, about a month ago:-
http://code.activestate.com/recipes/578 ... -python-t/
It has been at No1 from day 1 of upload and has now been voted up yet again to 7 today.
How can something so simple get rated so high?
73...
Team AMIGA...
Bazza
Postby lok1950 » Sun Oct 20, 2013 11:44 pm
Perhaps it's the simple things that are the hardest to understand completely :wink: That and you may have made that little snippet generalized enough that it falls into that category of code of wheels not to reinvent 8)
Enjoy the Choice :)
lok1950
Postby Ram » Mon Oct 21, 2013 10:48 am
Hi Bazza,
Works on LXDE 13.10, handy when having multi tabs open.
Postby Bazza » Mon Oct 21, 2013 4:53 pm
Hi guys...
Thanks for the replies...
And Ram, can I quote you on that and put it in the comments section of the pointer?
73...
Team AMIGA...
Bazza
Postby Ram » Mon Oct 21, 2013 7:14 pm
You can Bazza,
An to be more precise, multi tabs in LXTerminal
Python version " Python 2.7.5+ (default, Sep 19 2013, 13:48:49)
[GCC 4.8.1] on linux2 "
Postby Bazza » Mon Oct 21, 2013 9:16 pm
Thanks Ram...
Done!
That has pleased me even more...
I have almost dumped Python in preference to shell scripting ATM.
I am really enjoying doing unusual shell stuff especially in text mode...
Here is summat I am working on ATM:-
#!/bin/bash --posix
clear
echo ""
echo "Graphics characters and Logic Analyser display DEMO."
# Enable _extended_ graphics characters.
echo -e "\x1B(0"
echo -e "abcdefghijklmnopqrstuvwxyz\n"
echo "lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq"
echo "j                                                               "
echo "lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk                               "
echo "j                               mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq"
echo "lqqqqqqqqqqqqqqqk               lqqqqqqqqqqqqqqqk               "
echo "j               mqqqqqqqqqqqqqqqj               mqqqqqqqqqqqqqqq"
echo "lqqqqqqqk       lqqqqqqqk       lqqqqqqqk       lqqqqqqqk       "
echo "j       mqqqqqqqj       mqqqqqqqj       mqqqqqqqj       mqqqqqqq"
echo "lqqqk   lqqqk   lqqqk   lqqqk   lqqqk   lqqqk   lqqqk   lqqqk   "
echo "j   mqqqj   mqqqj   mqqqj   mqqqj   mqqqj   mqqqj   mqqqj   mqqq"
echo "lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk lqk "
echo "j mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mqj mq"
echo "x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x "
echo "vqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvq"
echo "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
echo "vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv"
# Disable _extended_ graphics characters.
echo -e "\x1B(B\x1B[0m"
echo "Graphics characters DEMO end."
echo ""
Results on Macbook Pro, OSX 10.7.5, default bash terminal.
(Note I have a Python version too...)
Last login: Mon Oct 21 17:42:23 on console
AMIGA:barrywalker~> ./Logic_Analyser.sh
AMIGA:barrywalker~> _
I am thinking of using this idea as an 8 channel Logic_Analyser project using purely text mode shell scripting...
Enjoy...
73...
Team AMIGA...
Bazza
Postby nelz » Mon Oct 21, 2013 10:20 pm
Bazza wrote:
#!/bin/bash --posix
Use /bin/sh to run bash in posix compatible mode, since this works for other shells too. Doing it the bash --posix way means you still require bash to be installed even though you are not using any of its features.
Postby Bazza » Tue Oct 22, 2013 1:42 pm
just tested the pointer from the OP inside a default CygWin terminal install and it works a treat.
Way cool...
73...
Team AMIGA...
Bazza
