can not log into Ubuntu Default desktop
Postby Narendra » Sat Oct 19, 2013 10:13 am
Hello,
I installed Cinnamon but did not like it so removed it but can not log in to Ubuntu Default desktop with my password. Have upgraded to 13.10.
Please advise.
Narendra
Narendra
Postby duff » Sat Oct 19, 2013 12:27 pm
I had the same problem with 13.04 and had to reset Unity.
See: http://ubuntuhandbook.org/index.php/2013/08/reset-unity-and-compiz-in-ubuntu-13-10/
for 13.10
Basically just do:
dconf reset -f /org/compiz/
setsid unity
unity --reset-icons
in a terminal, log out and log back in.
Hopefully that will work for you as well.
EDIT: You'll need to do the following first
sudo apt-get install dconf-tools
And see also here (if the above fails):
http://askubuntu.com/questions/360472/ubuntu-13-10-unity-doesnt-load-after-upgrade
Best
duff
duff
Postby Narendra » Sat Oct 19, 2013 2:38 pm
Thank you very much for your reply!
Its done!
Regards.
Narendra
Narendra
