No network configuration on starting computer.
Postby guinpen » Fri Oct 18, 2013 1:28 pm
Hi After using the terminal to do a system update using the following commands.sudo apt-get update & sudo apt-getdist-upgrade I have no network configuration when starting the computer. I can get the network back by shutting down rebooting in safe mode and enable networking from the list. then click on resume normal re boot.
the error message reads: waiting for network config
waiting 60 more seconds for network config.
boot system without full configuration.
Any help would be much appreciated, Thank you in advance.
guinpen
Postby purplepenguin » Sun Oct 20, 2013 12:25 pm
purplepenguin
Postby guinpen » Sun Oct 20, 2013 3:24 pm
SOLVED: Hi purple penguin. Thanks for your help much appreciated.
I clicked on your first link & did what it said & hey presto it worked .I have been scratching my head over this one for a week.
Guinpen.
guinpen
