Satellite PCI card - Kworld
Postby FranBlakes » Fri Oct 11, 2013 8:45 am
The other day I saw a PCI DVB-S 100 (Kworld) satellite card for less than £20.
I was wondering does this work "straight out of the box" with Ubuntu 12.04 64bit?
If so which tuner program is recommended?
Thanks in advance!
Ubuntu 10.04.4 LTS!
FranBlakes
Postby nelz » Fri Oct 11, 2013 9:59 am
It's not listed at http://linuxtv.org/wiki/index.php/Hardw ... nformation but KWorld stuff is pretty generic in my experience. I use one of their DVB-T cards with MythTV and have used a DVB-T USB stick of their in the past.
If you can get the full model number, a web search should show the chipset it uses.
Postby FranBlakes » Sat Oct 12, 2013 9:14 am
If they still have it (It was in “clearance”):
I might buy it, if it doesn't work:-
might try and install using WINE
and if that fails I could install in Windows XP in VirtualBox.
Ubuntu 10.04.4 LTS!
FranBlakes
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
