C inline functions
C inline functions
Postby Crispy » Thu Oct 03, 2013 11:56 am
Hi all,
I am hoping to use inline functions in a piece of C code that I have, but I am a bit confused about their proper use and was hoping someone would be able to help me. As an example, assume that I have a header file foo.h containing the prototype of the function int func_foo() and a source file foo.c containing the declaration of the function func_foo(), e.g.
foo.h
int func_foo( void );
foo.c
#include "foo.h"
Then I have another file, bar.c, which includes foo.h so it can use the function func_foo(), e.g.
bar.c
#include "bar.h"
#include "foo.h"
int func_bar( void )
  x = func_foo();
Assuming that func_foo() is a good candidate for inlining, I am a bit confused as to the proper way to define the inline function func_foo. Should I place the inline keyword in the function prototype in the header file, foo.h, or in the function declaration in foo.c or both? Also, i've had a look around and some people suggest using the extern keyword in the header file as well as the inline keyword?
Also, if we assume that func_bar() is also suitable for inlining and is called often, is it better for me to inline both func_foo() and func_bar() or just func_bar or func_foo by themselves?
Finally, if we consider an additional file, foobar.c which contains the function func_foobar, e.g.
foobar.c
#include "foobar.h"
int func_foobar( int (*func)( void ) )
  x = (*func)();
And we assume that (*func) points to an inline function, will the inlining optimisation still hold within the function func_foobar? Or will it simply be treated as a normal function?
Many thanks in advance,
Chris
Crispy
