Screen keeps flickering with the case fan
Postby Narendra » Wed Oct 02, 2013 3:32 pm
Hello,
Recently I installed a Akasa case fan that has its speed control with the capacitor. but the monitor keeps flickering and if I remove the speed control from the fan the computer switches off.
Do I need the case fan?
I wish to remove it or please advise.
Thank You.
Narendra
Narendra
Postby guy » Thu Oct 03, 2013 9:22 am
Sounds like you are overloading the power supply.
Fans usually use the +12V connection, but a few use a lower voltage. First, check it is the correct spec.
Next, check whether you are running the graphics card and fan from the same PSU output. Sometimes a PSU will have more than one output circuit and changing to a different output connector can ease things.
Otherwise, for now just disconnect the case fan and controller and run without it.
Whether you really need the case fan or not depends on how hot things like the CPU and graphics card get without it. Even if it kinda runs OK, these things will last longer if you can cool them that bit more. Your system may well have some temperature sensors and software to monitor them and set upper limits. The old rule of thumb used to be 100 deg C max but it's worth googling around to find out more. If necessary, the short-term remedy is to leave the case open (I have one old PC permanently in this sorry state).
For a proper fix I would consider upgrading to a more powerful PSU. Even if you get things kinda running OK it is probably too close to its limits for comfort. It's worth digging through the small print on both old and new, to make sure that the overloaded output gets a larger Amp (A) rating.
Postby Narendra » Thu Oct 03, 2013 11:13 am
The power supply is only a 300w, a bare minimum,and just ordered a one with 550W!
Disconnected the fan from the motherboard and set the bios to fail-safe defaults.
Thank you again.
Narendra
Narendra
