Convert ods to image
Postby heiowge » Sat Sep 28, 2013 4:01 pm
I've created a document (Spreadsheet, to be precise). It was never intended to be a spreadsheet though. I want to convert it to an image that I can edit.
It will export to pdf, but spreads it over 6 pages! I can print screen, but I have to make it so small that I lose 90% of what I want to keep.
Any ideas?
Postby Fat_Tuesday » Sat Sep 28, 2013 6:13 pm
Can you paste it into a really big powerpoint slide or similar? You can then use the inbuilt tools to customise. Or certainly with ppt you can save the slide as an image (never tried with libre office et al).
Fat_Tuesday
Postby guy » Sat Sep 28, 2013 7:32 pm
If you import the pdfs one by one into an Inkscape drawing, you can then edit them and rebuild your desired output.
Postby johnhudson » Sat Sep 28, 2013 9:13 pm
It depends on what you mean by edit but, if you save the spreadsheet as CSV and then import it into LyX, you can adjust the columns and rows and manipulate the contents in a variety of ways, export the result as a PDF and use ImageMagick to create whatever image format you want.
Postby heiowge » Sat Sep 28, 2013 9:46 pm
Thanks guys. Here are the results so far...
I've tried to copy to LO Impress, and LO Drawing. Impress crashed. Drawing froze for an eternity before copying over. I managed to save as a png, but lost so much quality it was unworkable.
I have converted to pdf, but it's on 3 pages. I've not lost quality, but am struggling to do much with it.
I am doing all this on the low powered netbook mentioned in my signature. My main PC with all the power and screen space is out of action atm. I need to try inkscape but haven't played with it in years.
Any help with any of it would be appreciated. :(
Postby guy » Sun Sep 29, 2013 9:29 am
Another way to get your spreadsheet into a graphic editor is to use copy-paste, at least it works in "a well-known office suite" (ISTR I had to take an intermediate paste-recopy step via the presentation app well known in large organizations for its use as a murder weapon). If you have lots of graphic-y bits, each is attached to a cell. Copy the cell and you copy the associated graphics.
But be warned this can give pretty haphazard results. For example the clipboard may not hold much more than a pdf page's worth of stuff so you may gain little, where a line crosses many cells you can find different segments attached to different cells and it all needs realigning, or if you have carefully set different cell sizes the may get mangled, shifting bits of graphic around.
Postby Fat_Tuesday » Sun Sep 29, 2013 9:51 am
Alternatively is it not possible to redo the spreadsheet in a graphics package?
Fat_Tuesday
Postby guy » Sun Sep 29, 2013 10:17 am
heiowge wrote:Thanks guys. Here are the results so far...
Yes, do try Inkscape. You can import each pdf in turn into the same drawing and position them all, then "ungroup" each pdf (select it then CTRL-U) to edit the individual objects.
Resize the drawing page using the File > Document Properties dialog. If you select all objects (CTRL-A) before opening the dialog, then in the dialog you can just click "Fit to selection".
Drop me a line if you need more help with Inkscape.
Postby heiowge » Sun Sep 29, 2013 4:17 pm
A mate of mine did it with Gimp. My little netbook wasn't powerful enough. :oops: I'll up a copy in a mo,....
Postby heiowge » Sun Sep 29, 2013 4:19 pm
