What does the $ mean
Postby pk_fox » Mon Sep 16, 2013 8:12 am
Hi all, just been googling for some help on generating a large binary file for use in testing a programme I'm writing and came across this
dd if=/dev/zero of=10g.img bs=1000 count=0 seek=$[1000*1000*10]
I know what the DD command does but what is the $ in the seek parameter ( also I ran this and it produced zilch ) how can the count = 0 ?
pk_fox
Postby nelz » Mon Sep 16, 2013 8:57 am
If substitutes the result of the calculation in the brackets, try
echo $[1000*1000*10]
although it's more common to use double parentheses for this
echo $(( 1000*1000*10 ))
which is why you couldn't find it in the bash man page.
You can use variables in here too
X=10
echo $(( X * 10 ))
This command produces a sparse file, it is more common to see it used with count=1 but 0 works. The seek option tells dd to start that far into the file, so all the preceding space has to be created.
A sparse file uses only the space needed by the data it holds, so while ls -l 10g.img will show a large file, du -h 10g.img will show the disk space it actually occupies. This is often used when creating is a disk image for a virtual machine, the size shown by ls will remain constant while the space it uses increases as you use it. This provides a faster virtual disk than allowing the disk file to grow as it is used, which often leads to substantial fragmentation.
I'm not sure how it will suit your needs as the file contains no data until you add it.
Postby pk_fox » Mon Sep 16, 2013 9:25 am
Thanks Nelz, any ideas as to how I can populate said file ?
pk_fox
Postby nelz » Mon Sep 16, 2013 10:06 am
That ll depends on what you want in it. The file is there as a 10G file right now, just not using 10G of disk space. If your programs needs a 10G file with 10G of data already in it, you don't want a sparse file.
dd if=/dev/urandom of=10g.img bs=1G count=10
Postby pk_fox » Mon Sep 16, 2013 2:19 pm
nelz wrote:That ll depends on what you want in it. The file is there as a 10G file right now, just not using 10G of disk space. If your programs needs a 10G file with 10G of data already in it, you don't want a sparse file.
Thanks that will do nicely.
pk_fox
Postby ferrari » Mon Sep 16, 2013 10:14 pm
Nice explanation of a sparse file Nelz. :)
ferrari
