Scripted spreadsheet update
Postby Nox » Tue Sep 10, 2013 12:37 pm
Any known way to append to a spreadsheet from a shell script?
Even if I have to use the script to run something else to do this, I just need it to happen on its own.
Ideally I'd like to take a comma deliminated file and tack it onto a shiny Libre Office Calc file.
Nox
Postby johnhudson » Tue Sep 10, 2013 9:26 pm
If you mean add it to an existing file, possibly
loffice -o [filename] [script]
I guess the [script] bit because that is how I routinely opened Supercalc files in order to add data in the 80s.
If you mean a new file
loffice -o [filename] --infilter="CSV"
I guess "CSV" by analogy with other examples because I cannot find a list of all the command line filters.
Postby Nox » Wed Sep 11, 2013 5:30 am
Thank you!
Your info got me around to this:
https://help.libreoffice.org/Common/Sta ... Parameters
Which looks like it should get me where I want to be if its possible. It's currently tossing a Fontconfig warning, but it doesnt seem to be a fatal error.
If I get the whole thing to play nice I'll post it here.
Nox
