Mint 15 GUI Errors
Mint 15 GUI Errors
Postby DavidMcCrossan » Tue Sep 03, 2013 9:21 am
I post the contents of Home/Docs/.xsession-errors in the hope that someone can find out what is wrong with my system.
/etc/mdm/Xsession: Beginning session setup...
localuser:david being added to access control list
Script for cjkv started at run_im.
Script for default started at run_im.
Failed to connect to the VirtualBox kernel service
access control disabled, clients can connect from any host
/opt/Samsung/SmartPanel/bin/smartpanel: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
** Message: applet now removed from the notification area
** Message: using fallback from indicator to GtkStatusIcon
      JS LOG: About to start Cinnamon
** (nemo:2654): WARNING **: Can not calculate _NET_NUMBER_OF_DESKTOPS
** (nemo:2654): WARNING **: Can not get _NET_WORKAREA
** (nemo:2654): WARNING **: Can not determine workarea, guessing at layout
Window manager warning: Log level 16: Unable to register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject
Window manager warning: Log level 16: Error registering polkit authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: An authentication agent already exists for the given subject (polkit-error-quark 0)
      JS LOG: Cinnamon started at Mon Sep 02 2013 18:36:37 GMT+0200 (CEST)
      JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
** Message: applet now embedded in the notification area
/usr/lib/linuxmint/mintUpdate/mintUpdate.py:1734: GtkWarning: IA__gdk_window_thaw_toplevel_updates_libgtk_only: assertion `private->update_and_descendants_freeze_count > 0' failed
  gtk.main()
      JS LOG: network applet: Found connection for active
Window manager warning: Log level 16: value "-95,000031" of type `gfloat' is invalid or out of range for property `width' of type `gfloat'
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x1c00003 (Authentica)
Window manager warning: meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
(polkit-gnome-authentication-agent-1:2655): GLib-WARNING **: GChildWatchSource: Exit status of a child process was requested but ECHILD was received by waitpid(). Most likely the process is ignoring SIGCHLD, or some other thread is invoking waitpid() with a nonpositive first argument; either behavior can break applications that use g_child_watch_add()/g_spawn_sync() either directly or indirectly.
Window manager warning: Log level 16: value "-23,000031" of type `gfloat' is invalid or out of range for property `width' of type `gfloat'
Terminated
(cinnamon:2637): Clutter-CRITICAL **: clutter_actor_queue_relayout: assertion `CLUTTER_IS_ACTOR (self)' failed
Window manager warning: Log level 16: value "-31,000031" of type `gfloat' is invalid or out of range for property `width' of type `gfloat'
Window manager warning: Log level 16: value "-15,000031" of type `gfloat' is invalid or out of range for property `width' of type `gfloat'
(evolution-alarm-notify:2813): evolution-alarm-notify-WARNING **: alarm.c:255: Requested removal of nonexistent alarm!
(nemo:2654): GLib-GObject-WARNING **: instance of invalid non-instantiatable type `(null)'
(nemo:2654): GLib-GObject-CRITICAL **: g_signal_handler_disconnect: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
Quite a mouthfull, I think, and all over my head.
Best regards
David
DavidMcCrossan
Mint 15 GUI errors
Postby DavidMcCrossan » Mon Sep 09, 2013 4:57 pm
For completeness I give the following info.
I did a clean install (3rd time) and found some slight confusion (to me at least!) in that I was able to select Cinnamon for the session but the greeter shows that I am in Mate.
I think the greeter lies like a hairy leg.
I did have Cinnamon but it now defaults to SAFE mode, which is usable if very slow.
Thank you all for help and guidance.
David
DavidMcCrossan
