Failing Hard Disk1
Failing Hard Disk1
Postby Narendra » Thu Aug 22, 2013 7:31 pm
Hello,
Please advise how do I check whether my computer hard disk is ok or its failing!
I use Ubuntu 13.04.
Thank you!
Narendra
Narendra
Postby ajgreeny » Mon Sep 02, 2013 7:44 pm
Start by using disk-utility and if that does not help find anything go to the disk maker site to see if they have a diagnostic tool available for download.
ajgreeny
Postby Narendra » Thu Sep 05, 2013 12:24 pm
Narendra
Narendra
Re: Failing Hard Disk1
Postby catgate » Thu Sep 05, 2013 7:19 pm
Narendra wrote:Hello,
I use Ubuntu 13.04.
Thank you!
The best advice I can give you is to first of all ensure that you have everything copied onto a new HD before you go any further.
I didn't quite make it !!!!!
Oh, sod it.
catgate
