Icon only taskmanager gnome fallback/classic?
Postby FranBlakes » Wed Aug 21, 2013 3:14 pm
It's been a while since I last posted.
Anyway:
I just installed/moved upto Ubuntu 12.04 LTS (previously 10.04).
I'm using Gnome Classic/Fallback and want an icon only task manager/window list.
the Window Selector applet - I've tried and not liked.
I installed DockBarX which in 10.04 worked in the panel, now it works as a dock :-(
Any recommendations?
Ubuntu 10.04.4 LTS!
FranBlakes
Postby RichAustin » Sun Oct 06, 2013 11:15 am
Hi
I use Cairo Dock https://help.ubuntu.com/community/CairoDock
I used to always use Docky, which I think is in the standard Ubuntu repositories. It kept breaking though and I started using Cairo instead. I've also used Avant Window Manager (AWN) in the past.
Overall I like Cairo the best and it works really well with Gnome3.
Richard
RichAustin
