User friendly?
User friendly?
Postby debut » Wed Nov 09, 2005 11:06 pm
It means easy to use.
debut
RE: User friendly?
Postby Nigel » Wed Nov 09, 2005 11:28 pm
OK, let me rephrase the question...
what is it about the output of ls -l (or any other form of ls) that you don't find user friendly ?
Give us an example of what you would like to see.
If you're looking for a Windows Exploder clone, you shouldn't be using the command line - try using Konquerer (if you use KDE) or Nautilus (if you use Gnome) instead.
(and it helps if you post a reply rather than starting a new topic ;) )
