Hugin panoramas suddenly gone wonky
Postby GeordieJedi » Wed Jul 17, 2013 9:08 pm
Hi all.
I've been using Hugin for a while now, without any problems at all.
However a couple of days ago it started to misbehave.
When I try and create a panorama I load the images.
Then I then align the images.
Now when I click the final stage to create the panorama I get the two error messages listed below.
The strange thing is, if I click OK on the errors and let the Hugin finish its process.
It will actually complete the panorama.
Before any of this happened I can only think of two instances of me (possibly) changing things, that might have contributed to this.
1. I took a look at some of the preferences and I'm almost certain that I didn't change or apply an changes to these settings.
2. I was trying to create a panorama with different settings without having to re-align
(re-create) the entire panorama all over again.
So I loaded up a previously created panorama "project file"
and tried to work on that.
I don't think that worked (but it didn't create any glaring error messaged or dialogue boxes
telling me that I shouldn't be doing that).
Here's the main error messages that I'm seeing =
Error 01
Program enblend not found in preferences, reverting to default value
Error 02
Program enfuse not found in preferences, reverting to default value
Useful info =
Hugin version = 2011.4.0. - cf9be9344356
OS = Ubuntu 12.04 LTS
DE = KDE 4.8.5
Any help or advice would be greatly appreciated.
TIA
GeordieJedi
Postby PCNetSpec » Sat Jul 20, 2013 11:05 am
Is enblend installed ?
Sounds like the hugin preferences are pointing to it, but not finding it.
in Hugiin, go to:-
Edit>Preferences>Programs (tab)
Does it read:-
Enblend executable: enblend
if enblend IS installed, maybe you should try giving the full path to it .. as in:-
Enblend executable: /usr/bin/enblend
Linux in the UK
The Linux Community Forum
PCNetSpec
Postby GeordieJedi » Fri Jul 26, 2013 10:35 pm
Enblend and Enfuse were installed.
However I've done as you've suggested and pointed them directly at their respective bin files.
And it's worked. Outstanding !
Thank you very much indeed PCNetSpec !!
I can now continue with my obsession with panoramas.
Cheers
GeordieJedi
Users browsing this forum: Google [Bot], Yahoo [Bot] and 3 guests
