How do I get the Gnome System Monitor to display in bps?
Postby Alex01UK » Fri Jun 14, 2013 12:54 pm
Hi folks, I'm running the 64bit Ubuntu Studio 13.o4 distribution, with the Gnome 3 desktop, and since the upgrade to 13.o4, there doesn't seem to be anyway to change the settings for the Gnome Sytem Monitor tool. Specifically, I'd like to display The Network History in bits per second, instead of bytes per second. How would I go about achieving this?
aha, tia from Alex.
VampirOS 4:2o
xx.tB
Alex01UK
