Hauppauge WinTV-HVR-1100 (Green/Grey image on Composite Inpu
Postby jbullock » Thu Jun 13, 2013 4:31 pm
I'm having a problem getting a decent image on my WinTV-HVR-1100. I've tried most of what I've found Googling (full summary below).
This is the type of image I have been getting:
Usually the first time I open the input...
http://s18.postimg.org/lrc0yxe6x/1371128356.jpg
Then it's mostly like this...
http://s23.postimg.org/y64mudgx7/1371128361.jpg
I'm trying to grab the composite input which I have a CCTV camera plugged in to.
I have confirmed that the camera works fine when plugged in to any other device (TV/Monitor).
I've tried this on Kubuntu 12.04 (using mplayer) and Ubuntu Server 12.04.2 (using Zoneminder).
The following output is from my Kubuntu install (using the same hardware as Ubuntu Server install)...
jbullock@buddha:~$ uname -a
Linux buddha 3.2.0-40-generic #64-Ubuntu SMP Mon Mar 25 21:22:26 UTC 2013 i686 i686 i386 GNU/Linux
Check which input the card is using...
jbullock@buddha:~$ v4l2-ctl -I
Video input : 0 (Television: ok)
I want to use composite, so...
jbullock@buddha:~$ v4l2-ctl -i 1
Video input set to 1 (Composite1: ok)
And I'm in the UK, so I'll assume PAL should work...
jbullock@buddha:~$ v4l2-ctl --set-standard pal
Standard set to 000000ff
I read somewhere that NTSC-M works well... Doesn't make a difference...
jbullock@buddha:~$ v4l2-ctl --set-standard ntsc-M
Standard set to 00001000
...I've tried other PAL and NTSC settings, too.
I'm really struggling with this. I'm really hoping there's someone on here that can help :) Any suggestions would be MUCH appreciated!
Here's as much info as I can think *may* be relevant...
This is what happens when I open the composite input on mplayer, it gives me a good frame rate but an image similar to http://s23.postimg.org/y64mudgx7/1371128361.jpg ...
jbullock@buddha:~$ mplayer tv:///1
MPlayer svn r34540 (Ubuntu), built with gcc-4.6 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing tv:///1.
TV file format detected.
Selected driver: v4l2
 name: Video 4 Linux 2 input
 author: Martin Olschewski <olschewski@zpr.uni-koeln.de>
 comment: first try, more to come ;-)
Selected device: Hauppauge WinTV-HVR1100 DVB-T/H
 Tuner cap: STEREO LANG1 LANG2
 Tuner rxs: MONO
 Capabilities:  video capture  VBI capture device  tuner  read/write  streaming
 supported norms: 0 = NTSC-M; 1 = NTSC-M-JP; 2 = NTSC-443; 3 = PAL-BG; 4 = PAL-I; 5 = PAL-DK; 6 = PAL-M; 7 = PAL-N; 8 = PAL-Nc; 9 = PAL-60; 10 = SECAM-B; 11 = SECAM-G; 12 = SECAM-H; 13 = SECAM-DK; 14 = SECAM-L;
 inputs: 0 = Television; 1 = Composite1; 2 = S-Video;
 Current input: 1
 Current format: BGR24
v4l2: current audio mode is : MONO
v4l2: ioctl set format failed: Invalid argument
tv.c: norm_from_string(pal): Bogus norm parameter, setting default.
Failed to open VDPAU backend libvdpau_r300.so: cannot open shared object file: No such file or directory
[vdpau] Error when calling vdp_device_create_x11: 1
Opening video decoder: [raw] RAW Uncompressed Video
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 640x480 => 640x480 Packed UYVY
Selected video codec: [rawuyvy] vfm: raw (RAW UYVY)
Audio: no sound
Starting playback...
V:   0.0 140/140 ??% ??% ??,?% 0 0
MPlayer interrupted by signal 2 in module: video_read_frame
V:   0.0 141/141 ??% ??% ??,?% 0 0
v4l2: 143 frames successfully processed, 28 frames dropped.
Exiting... (Quit)
jbullock@buddha:~$ v4l-info
### v4l2 device info [/dev/video0] ###
general info
    VIDIOC_QUERYCAP
        driver                  : "cx8800"
        card                    : "Hauppauge WinTV-HVR1100 DVB-T/H"
        bus_info                : "PCI:0000:02:01.0"
        version                 : 3.2.40
        capabilities            : 0x5010011 [VIDEO_CAPTURE,VBI_CAPTURE,TUNER,READWRITE,STREAMING]
standards
    VIDIOC_ENUMSTD(0)
        index                   : 0
        frameperiod.numerator   : 1001
        frameperiod.denominator : 30000
        framelines              : 525
    VIDIOC_ENUMSTD(1)
        index                   : 1
        id                      : 0x2000 [NTSC_M_JP]
        framelines              : 525
    VIDIOC_ENUMSTD(2)
        index                   : 2
        framelines              : 525
    VIDIOC_ENUMSTD(3)
        index                   : 3
        id                      : 0x7 [PAL_B,PAL_B1,PAL_G]
        frameperiod.denominator : 25
        framelines              : 625
    VIDIOC_ENUMSTD(4)
        index                   : 4
        framelines              : 625
    VIDIOC_ENUMSTD(5)
        index                   : 5
        id                      : 0xe0 [PAL_D,PAL_D1,PAL_K]
        framelines              : 625
    VIDIOC_ENUMSTD(6)
        index                   : 6
        framelines              : 525
    VIDIOC_ENUMSTD(7)
        index                   : 7
        framelines              : 625
    VIDIOC_ENUMSTD(8)
        index                   : 8
        framelines              : 625
    VIDIOC_ENUMSTD(9)
        index                   : 9
        framelines              : 525
    VIDIOC_ENUMSTD(10)
        index                   : 10
        id                      : 0x10000 [SECAM_B]
        framelines              : 625
    VIDIOC_ENUMSTD(11)
        index                   : 11
        id                      : 0x40000 [SECAM_G]
        framelines              : 625
    VIDIOC_ENUMSTD(12)
        index                   : 12
        id                      : 0x80000 [SECAM_H]
        framelines              : 625
    VIDIOC_ENUMSTD(13)
        index                   : 13
        id                      : 0x320000 [SECAM_D,SECAM_K,SECAM_K1]
        framelines              : 625
    VIDIOC_ENUMSTD(14)
        index                   : 14
        id                      : 0x400000 [SECAM_L]
        framelines              : 625
inputs
    VIDIOC_ENUMINPUT(0)
        index                   : 0
        type                    : TUNER
        audioset                : 0
        tuner                   : 0
        std                     : 0x7f7ff7 [PAL_B,PAL_B1,PAL_G,PAL_I,PAL_D,PAL_D1,PAL_K,PAL_M,PAL_N,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,?,SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L]
        status                  : 0x0 []
    VIDIOC_ENUMINPUT(1)
        index                   : 1
        type                    : CAMERA
        audioset                : 0
        tuner                   : 0
        std                     : 0x0 []
        status                  : 0x0 []
    VIDIOC_ENUMINPUT(2)
        index                   : 2
        type                    : CAMERA
        audioset                : 0
        tuner                   : 0
        std                     : 0x0 []
        status                  : 0x0 []
tuners
    VIDIOC_G_TUNER(0)
        index                   : 0
        type                    : ANALOG_TV
        capability              : 0x70 [STEREO,LANG2,LANG1]
        rangelow                : 0
        rangehigh               : 4294967295
        rxsubchans              : 0x1 [MONO]
        audmode                 : MONO
        signal                  : 0
        afc                     : 0
video capture
    VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
        index                   : 0
        type                    : VIDEO_CAPTURE
        flags                   : 0
        description             : "8 bpp, gray"
        pixelformat             : 0x59455247 [GREY]
    VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
        index                   : 1
        flags                   : 0
        description             : "15 bpp RGB, le"
        pixelformat             : 0x4f424752 [RGBO]
    VIDIOC_ENUM_FMT(2,VIDEO_CAPTURE)
        index                   : 2
        flags                   : 0
        description             : "15 bpp RGB, be"
        pixelformat             : 0x51424752 [RGBQ]
    VIDIOC_ENUM_FMT(3,VIDEO_CAPTURE)
        index                   : 3
        flags                   : 0
        description             : "16 bpp RGB, le"
        pixelformat             : 0x50424752 [RGBP]
    VIDIOC_ENUM_FMT(4,VIDEO_CAPTURE)
        index                   : 4
        flags                   : 0
        description             : "16 bpp RGB, be"
        pixelformat             : 0x52424752 [RGBR]
    VIDIOC_ENUM_FMT(5,VIDEO_CAPTURE)
        index                   : 5
        flags                   : 0
        description             : "24 bpp RGB, le"
        pixelformat             : 0x33524742 [BGR3]
    VIDIOC_ENUM_FMT(6,VIDEO_CAPTURE)
        index                   : 6
        flags                   : 0
        description             : "32 bpp RGB, le"
        pixelformat             : 0x34524742 [BGR4]
    VIDIOC_ENUM_FMT(7,VIDEO_CAPTURE)
        index                   : 7
        flags                   : 0
        description             : "32 bpp RGB, be"
        pixelformat             : 0x34424752 [RGB4]
    VIDIOC_ENUM_FMT(8,VIDEO_CAPTURE)
        index                   : 8
        flags                   : 0
        description             : "4:2:2, packed, YUYV"
        pixelformat             : 0x56595559 [YUYV]
    VIDIOC_ENUM_FMT(9,VIDEO_CAPTURE)
        index                   : 9
        flags                   : 0
        description             : "4:2:2, packed, UYVY"
        pixelformat             : 0x59565955 [UYVY]
    VIDIOC_G_FMT(VIDEO_CAPTURE)
        fmt.pix.width           : 320
        fmt.pix.height          : 240
        fmt.pix.pixelformat     : 0x33524742 [BGR3]
        fmt.pix.field           : INTERLACED
        fmt.pix.bytesperline    : 960
        fmt.pix.sizeimage       : 230400
        fmt.pix.colorspace      : unknown
        fmt.pix.priv            : 0
vbi capture
    VIDIOC_G_FMT(VBI_CAPTURE)
        type                    : VBI_CAPTURE
        fmt.vbi.sampling_rate   : 35468950
        fmt.vbi.offset          : 244
        fmt.vbi.samples_per_line: 2048
        fmt.vbi.sample_format   : 0x59455247 [GREY]
        fmt.vbi.start[0]        : 6
        fmt.vbi.start[1]        : 318
        fmt.vbi.count[0]        : 17
        fmt.vbi.count[1]        : 17
        fmt.vbi.flags           : 0
controls
    VIDIOC_QUERYCTRL(BASE+0)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 127
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+1)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 63
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+2)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 127
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+3)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 255
        step                    : 1
        default_value           : 127
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+5)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 63
        step                    : 1
        default_value           : 63
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+6)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 127
        step                    : 1
        default_value           : 64
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+9)
        type                    : BOOLEAN
        minimum                 : 0
        maximum                 : 1
        step                    : 0
        default_value           : 1
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+27)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 4
        step                    : 1
        default_value           : 0
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+29)
        type                    : BOOLEAN
        minimum                 : 0
        maximum                 : 1
        step                    : 0
        default_value           : 1
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+30)
        type                    : BOOLEAN
        minimum                 : 0
        maximum                 : 1
        step                    : 0
        default_value           : 1
        flags                   : 0
    VIDIOC_QUERYCTRL(BASE+33)
        type                    : INTEGER
        minimum                 : 0
        maximum                 : 1
        step                    : 1
        default_value           : 0
        flags                   : 0
jbullock@buddha:~$ v4l2-ctl --all
Driver Info (not using libv4l2):
        Driver name   : cx8800
        Card type     : Hauppauge WinTV-HVR1100 DVB-T/H
        Bus info      : PCI:0000:02:01.0
        Driver version: 3.2.40
        Capabilities  : 0x05010011
                Video Capture
                VBI Capture
                Tuner
                Read/Write
                Streaming
Format Video Capture:
        Width/Height  : 320/240
        Pixel Format  : 'BGR3'
        Field         : Interlaced
        Bytes per Line: 960
        Size Image    : 230400
        Colorspace    : Unknown (00000000)
Format VBI Capture:
        Sampling Rate   : 35468950 Hz
        Offset          : 244 samples (6.87926e-06 secs after leading edge)
        Samples per Line: 2048
        Sample Format   : GREY
        Start 1st Field : 6
        Count 1st Field : 17
        Start 2nd Field : 318
        Count 2nd Field : 17
Frequency: 6400 (400.000000 MHz)
Video Standard = 0x000000f7
        PAL-B/B1/G/I/D/D1/K
Streaming Parameters Video Capture:
        Frames per second: 25.000 (25/1)
        Read buffers     : 0
Tuner:
        Capabilities         : 62.5 kHz stereo lang1 lang2
        Frequency range      : 0.0 MHz - 268435455.9 MHz
        Signal strength/AFC  : 0%/0
        Current audio mode   : mono
        Available subchannels: mono
jbullock@buddha:~$ lsmod
Module                  Size  Used by
pci_stub               12550  1
vboxpci                22911  0
vboxnetadp             13328  0
vboxnetflt             27240  0
vboxdrv               252189  3 vboxpci,vboxnetadp,vboxnetflt
rfcomm                 38139  0
bnep                   17830  2
bluetooth             158479  10 rfcomm,bnep
binfmt_misc            17292  1
dm_crypt               22528  0
ppdev                  12849  0
cx22702                13289  1
cx88_dvb               33347  0
cx88_vp3054_i2c        12840  1 cx88_dvb
videobuf_dvb           13867  1 cx88_dvb
dvb_core               94814  2 cx88_dvb,videobuf_dvb
rc_hauppauge           12484  0
tuner_simple           18151  2
tuner_types            18998  1 tuner_simple
tda9887                17874  1
snd_hda_codec_realtek   174313  1
tda8290                22216  0
tuner                  26836  2
snd_hda_intel          32719  3
snd_hda_codec         109562  2 snd_hda_codec_realtek,snd_hda_intel
jbullock@buddha:~$ lspci
00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI Radeon Xpress 200 Host Bridge (rev 01)
00:01.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RS480 PCI Bridge
00:11.0 IDE interface: Advanced Micro Devices [AMD] nee ATI IXP SB400 Serial ATA Controller (rev 80)
00:12.0 IDE interface: Advanced Micro Devices [AMD] nee ATI IXP SB400 Serial ATA Controller (rev 80)
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB Host Controller (rev 80)
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI IXP SB400 USB2 Host Controller (rev 80)
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI IXP SB400 SMBus Controller (rev 82)
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI IXP SB400 IDE Controller (rev 80)
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI IXP SB4x0 High Definition Audio Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-ISA Bridge (rev 80)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI IXP SB400 PCI-PCI Bridge (rev 80)
01:05.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RS400 [Radeon Xpress 200]
02:01.0 Multimedia video controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder (rev 05)
02:01.1 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [Audio Port] (rev 05)
02:01.2 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] (rev 05)
02:01.4 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [IR Port] (rev 05)
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
[code]
jbullock@buddha:~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-40-generic (buildd@roseapple) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #64-Ubuntu SMP Mon Mar 25 21:22:26 UTC 2013 (Ubuntu 3.2.0-40.64-generic 3.2.40)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000077fd0000 (usable)
[ 0.000000] BIOS-e820: 0000000077fd0000 - 0000000077fde000 (ACPI data)
[ 0.000000] BIOS-e820: 0000000077fde000 - 0000000078000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff780000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled in hardware: non-PAE kernel!
[ 0.000000] NX (Execute Disable) protection: approximated by x86 segment limits
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Gateway E4210/RC410-M, BIOS 080012 12/28/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x77fd0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FE0000000 write-back
[ 0.000000] 2 base 060000000 mask FF0000000 write-back
[ 0.000000] 3 base 070000000 mask FF8000000 write-back
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01c00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 1bfa000-1c00000
[ 0.000000] RAMDISK: 358b4000 - 36c52000
[ 0.000000] ACPI: RSDP 000f89b0 00014 (v00 GATEWA)
[ 0.000000] ACPI: RSDT 77fd0000 00038 (v01 GATEWA SYSTEM 12000628 MSFT 00000097)
[ 0.000000] ACPI: FACP 77fd0200 00084 (v02 GATEWA OEMFACP 12000628 MSFT 00000097)
[ 0.000000] ACPI: DSDT 77fd05c0 047CC (v01 GATEWA RC410-M 00000000 INTL 02002026)
[ 0.000000] ACPI: FACS 77fde000 00040
[ 0.000000] ACPI: APIC 77fd0390 0006C (v01 GATEWA OEMAPIC 12000628 MSFT 00000097)
[ 0.000000] ACPI: MCFG 77fd0400 0003C (v01 GATEWA OEMMCFG 12000628 MSFT 00000097)
[ 0.000000] ACPI: SLIC 77fd0440 00176 (v01 GATEWA SYSTEM 12000628 MSFT 00000097)
[ 0.000000] ACPI: OEMB 77fde040 00056 (v01 GATEWA AMI_OEM 12000628 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1031MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x00077fd0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x00077fd0
[ 0.000000] On node 0 totalpages: 491359
[ 0.000000] free_area_init_node: node 0, pgdat c1829700, node_mem_map f49b4200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2064 pages used for memmap
[ 0.000000] HighMem zone: 262082 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] SB4X0 revision 0x82
[ 0.000000] Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 21 low level)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 78000000 (gap: 78000000:86e00000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 13 pages/cpu @f77bd000 s31616 r0 d21632 u53248
[ 0.000000] pcpu-alloc: s31616 r0 d21632 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 487519
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-40-generic root=UUID=e9fb5911-53df-4f23-9275-b0c8f01b632a ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 7863296 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:00077fd0)
[ 0.000000] Memory: 1911212k/1965888k available (5628k kernel code, 54224k reserved, 2778k data, 712k init, 1056584k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff16000 - 0xfffff000 ( 932 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc1836000 - 0xc18e8000 ( 712 kB)
[ 0.000000] .data : 0xc157f384 - 0xc1835e40 (2778 kB)
[ 0.000000] .text : 0xc1000000 - 0xc157f384 (5628 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=15, HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f440a000 soft=f440c000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3396.486 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6792.97 BogoMIPS (lpj=13585944)
[ 0.004009] pid_max: default: 32768 minimum: 301
[ 0.004044] Security Framework initialized
[ 0.004078] AppArmor: AppArmor initialized
[ 0.004080] Yama: becoming mindful.
[ 0.004173] Mount-cache hash table entries: 512
[ 0.004417] Initializing cgroup subsys cpuacct
[ 0.004426] Initializing cgroup subsys memory
[ 0.004439] Initializing cgroup subsys devices
[ 0.004442] Initializing cgroup subsys freezer
[ 0.004445] Initializing cgroup subsys blkio
[ 0.004458] Initializing cgroup subsys perf_event
[ 0.004503] CPU: Physical Processor ID: 0
[ 0.004506] CPU: Processor Core ID: 0
[ 0.004510] mce: CPU supports 4 MCE banks
[ 0.004526] CPU0: Thermal monitoring enabled (TM1)
[ 0.004532] using mwait in idle threads.
[ 0.010337] ACPI: Core revision 20110623
[ 0.014084] ftrace: allocating 25501 entries in 50 pages
[ 0.016095] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.016528] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.058803] CPU0: Intel(R) Pentium(R) 4 CPU 3.40GHz stepping 03
[ 0.060003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.060003] ... version: 0
[ 0.060003] ... bit width: 40
[ 0.060003] ... generic registers: 18
[ 0.060003] ... value mask: 000000ffffffffff
[ 0.060003] ... max period: 0000007fffffffff
[ 0.060003] ... fixed-purpose events: 0
[ 0.060003] ... event mask: 000000000003ffff
[ 0.060003] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.060003] CPU 1 irqstacks, hard=f44b2000 soft=f44b4000
[ 0.060003] Booting Node 0, Processors #1
[ 0.060003] smpboot cpu 1: start_ip = 9b000
[ 0.008000] Initializing CPU#1
[ 0.148008] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.148008] Measured 1134790222 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.148008] Marking TSC unstable due to check_tsc_sync_source failed
[ 0.148053] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.148114] Brought up 2 CPUs
[ 0.148119] Total of 2 processors activated (13585.95 BogoMIPS).
[ 0.149668] devtmpfs: initialized
[ 0.149668] EVM: security.selinux
[ 0.149668] EVM: security.SMACK64
[ 0.149668] EVM: security.capability
[ 0.149668] PM: Registering ACPI NVS region at 77fde000 (139264 bytes)
[ 0.149668] print_constraints: dummy:
[ 0.149703] RTC time: 10:11:20, date: 06/13/13
[ 0.152057] NET: Registered protocol family 16
[ 0.152100] Trying to unpack rootfs image as initramfs...
[ 0.152323] EISA bus registered
[ 0.152383] ACPI: bus type pci registered
[ 0.152513] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.152519] PCI: not using MMCONFIG
[ 0.152659] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=2
[ 0.152663] PCI: Using configuration type 1 for base access
[ 0.155337] bio: create slab <bio-0> at 0
[ 0.155506] ACPI: Added _OSI(Module Device)
[ 0.155511] ACPI: Added _OSI(Processor Device)
[ 0.155516] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.155520] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.157493] ACPI: EC: Look up EC in DSDT
[ 0.161321] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.165108] ACPI Warning: Incorrect checksum in table [SSDT] - 0xCE, should be 0xD5 (20110623/tbutils-314)
[ 0.165121] ACPI: SSDT 77fd4d90 002E3 (v01 AMI CPU1PM 00000001 INTL 02002026)
[ 0.165674] ACPI: Dynamic OEM Table Load:
[ 0.165681] ACPI: SSDT (null) 002E3 (v01 AMI CPU1PM 00000001 INTL 02002026)
[ 0.165827] ACPI: SSDT 77fd5080 002DA (v01 AMI CPU2PM 00000001 INTL 02002026)
[ 0.166385] ACPI: Dynamic OEM Table Load:
[ 0.166392] ACPI: SSDT (null) 002DA (v01 AMI CPU2PM 00000001 INTL 02002026)
[ 0.168337] ACPI: Interpreter enabled
[ 0.168352] ACPI: (supports S0 S3 S4 S5)
[ 0.168392] ACPI: Using IOAPIC for interrupt routing
[ 0.168523] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.173083] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.173090] PCI: Using MMCONFIG for extended config space
[ 0.188039] ACPI: No dock devices found.
[ 0.188046] HEST: Table not found.
[ 0.188056] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.188203] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.188560] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.188567] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.188573] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.188579] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[ 0.188585] pci_root PNP0A03:00: host bridge window [mem 0x78000000-0xffffffff] (ignored)
[ 0.188607] pci 0000:00:00.0: [1002:5a33] type 0 class 0x000600
[ 0.188638] pci 0000:00:00.0: reg 1c: [mem 0xe0000000-0xffffffff 64bit]
[ 0.188678] pci 0000:00:01.0: [1002:5a3f] type 1 class 0x000604
[ 0.188791] pci 0000:00:11.0: [1002:437a] type 0 class 0x000101
[ 0.188828] pci 0000:00:11.0: reg 10: [io 0x6000-0x6007]
[ 0.188847] pci 0000:00:11.0: reg 14: [io 0x5000-0x5003]
[ 0.188866] pci 0000:00:11.0: reg 18: [io 0x4000-0x4007]
[ 0.188884] pci 0000:00:11.0: reg 1c: [io 0x3000-0x3003]
[ 0.188903] pci 0000:00:11.0: reg 20: [io 0x2000-0x200f]
[ 0.188928] pci 0000:00:11.0: reg 24: [mem 0xf9eff000-0xf9eff1ff]
[ 0.188950] pci 0000:00:11.0: reg 30: [mem 0xf9d80000-0xf9dfffff pref]
[ 0.189031] pci 0000:00:11.0: supports D1 D2
[ 0.189073] pci 0000:00:12.0: [1002:4379] type 0 class 0x000101
[ 0.189110] pci 0000:00:12.0: reg 10: [io 0xb000-0xb007]
[ 0.189129] pci 0000:00:12.0: reg 14: [io 0xa000-0xa003]
[ 0.189148] pci 0000:00:12.0: reg 18: [io 0x9000-0x9007]
[ 0.189167] pci 0000:00:12.0: reg 1c: [io 0x8000-0x8003]
[ 0.189186] pci 0000:00:12.0: reg 20: [io 0x7000-0x700f]
[ 0.189205] pci 0000:00:12.0: reg 24: [mem 0xf9eff800-0xf9eff9ff]
[ 0.189225] pci 0000:00:12.0: reg 30: [mem 0xf9e00000-0xf9e7ffff pref]
[ 0.189298] pci 0000:00:12.0: supports D1 D2
[ 0.189328] pci 0000:00:13.0: [1002:4374] type 0 class 0x000c03
[ 0.189355] pci 0000:00:13.0: reg 10: [mem 0xf9efe000-0xf9efefff]
[ 0.189488] pci 0000:00:13.1: [1002:4375] type 0 class 0x000c03
[ 0.189524] pci 0000:00:13.1: reg 10: [mem 0xf9efd000-0xf9efdfff]
[ 0.189653] pci 0000:00:13.2: [1002:4373] type 0 class 0x000c03
[ 0.189686] pci 0000:00:13.2: reg 10: [mem 0xf9efc000-0xf9efcfff]
[ 0.189845] pci 0000:00:13.2: supports D1 D2
[ 0.189850] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.189859] pci 0000:00:13.2: PME# disabled
[ 0.189897] pci 0000:00:14.0: [1002:4372] type 0 class 0x000c05
[ 0.189921] pci 0000:00:14.0: reg 10: [io 0x0b00-0x0b0f]
[ 0.189943] pci 0000:00:14.0: reg 14: [mem 0x00000000-0x000003ff]
[ 0.190040] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.190079] pci 0000:00:14.1: [1002:4376] type 0 class 0x000101
[ 0.190112] pci 0000:00:14.1: reg 10: [io 0x01f0-0x01f7]
[ 0.190131] pci 0000:00:14.1: reg 14: [io 0x03f4-0x03f7]
[ 0.190150] pci 0000:00:14.1: reg 18: [io 0x0170-0x0177]
[ 0.190169] pci 0000:00:14.1: reg 1c: [io 0x0374-0x0377]
[ 0.190189] pci 0000:00:14.1: reg 20: [io 0xff00-0xff0f]
[ 0.190306] pci 0000:00:14.2: [1002:437b] type 0 class 0x000403
[ 0.190352] pci 0000:00:14.2: reg 10: [mem 0xf9ef8000-0xf9efbfff 64bit]
[ 0.190523] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.190532] pci 0000:00:14.2: PME# disabled
[ 0.190563] pci 0000:00:14.3: [1002:4377] type 0 class 0x000601
[ 0.190704] pci 0000:00:14.4: [1002:4371] type 1 class 0x000604
[ 0.190844] pci 0000:01:05.0: [1002:5a41] type 0 class 0x000300
[ 0.190865] pci 0000:01:05.0: reg 10: [mem 0xd0000000-0xdfffffff pref]
[ 0.190876] pci 0000:01:05.0: reg 14: [io 0xd000-0xd0ff]
[ 0.190888] pci 0000:01:05.0: reg 18: [mem 0xf9ff0000-0xf9ffffff]
[ 0.190918] pci 0000:01:05.0: reg 30: [mem 0xf9fc0000-0xf9fdffff pref]
[ 0.190953] pci 0000:01:05.0: supports D1 D2
[ 0.190996] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.191005] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.191013] pci 0000:00:01.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.191024] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff pref]
[ 0.191088] pci 0000:02:01.0: [14f1:8800] type 0 class 0x000400
[ 0.191131] pci 0000:02:01.0: reg 10: [mem 0xfd000000-0xfdffffff]
[ 0.191351] pci 0000:02:01.1: [14f1:8811] type 0 class 0x000480
[ 0.191389] pci 0000:02:01.1: reg 10: [mem 0xfc000000-0xfcffffff]
[ 0.191596] pci 0000:02:01.2: [14f1:8802] type 0 class 0x000480
[ 0.191633] pci 0000:02:01.2: reg 10: [mem 0xfb000000-0xfbffffff]
[ 0.191827] pci 0000:02:01.4: [14f1:8804] type 0 class 0x000480
[ 0.191865] pci 0000:02:01.4: reg 10: [mem 0xfa000000-0xfaffffff]
[ 0.192104] pci 0000:02:05.0: [10ec:8139] type 0 class 0x000200
[ 0.192143] pci 0000:02:05.0: reg 10: [io 0xe800-0xe8ff]
[ 0.192166] pci 0000:02:05.0: reg 14: [mem 0xfebffc00-0xfebffcff]
[ 0.192312] pci 0000:02:05.0: supports D1 D2
[ 0.192317] pci 0000:02:05.0: PME# supported from D1 D2 D3hot D3cold
[ 0.192326] pci 0000:02:05.0: PME# disabled
[ 0.192411] pci 0000:00:14.4: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.192430] pci 0000:00:14.4: bridge window [io 0xe000-0xefff]
[ 0.192441] pci 0000:00:14.4: bridge window [mem 0xfa000000-0xfebfffff]
[ 0.192451] pci 0000:00:14.4: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.192456] pci 0000:00:14.4: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.192477] pci_bus 0000:00: on NUMA node 0
[ 0.192484] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.192613] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.192718] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.192949] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.192958] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.192962] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.201839] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.201949] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202073] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202184] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202283] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202386] ACPI: PCI Interrupt Link [LNKF] (IRQs 9) *0, disabled.
[ 0.202491] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202606] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.202834] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.202845] vgaarb: loaded
[ 0.202849] vgaarb: bridge control possible 0000:01:05.0
[ 0.203170] i2c-core: driver [aat2870] using legacy suspend method
[ 0.203174] i2c-core: driver [aat2870] using legacy resume method
[ 0.203359] SCSI subsystem initialized
[ 0.203507] libata version 3.00 loaded.
[ 0.203612] usbcore: registered new interface driver usbfs
[ 0.203643] usbcore: registered new interface driver hub
[ 0.203698] usbcore: registered new device driver usb
[ 0.203901] PCI: Using ACPI for IRQ routing
[ 0.203909] PCI: pci_cache_line_size set to 64 bytes
[ 0.203928] pci 0000:00:00.0: address space collision: [mem 0xe0000000-0xffffffff 64bit] conflicts with PCI Bus 0000:01 [mem 0xf9f00000-0xf9ffffff]
[ 0.204089] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.204094] reserve RAM buffer: 0000000077fd0000 - 0000000077ffffff
[ 0.204311] NetLabel: Initializing
[ 0.204315] NetLabel: domain hash size = 128
[ 0.204318] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.204344] NetLabel: unlabeled traffic allowed by default
[ 0.222347] AppArmor: AppArmor Filesystem Enabled
[ 0.222425] pnp: PnP ACPI init
[ 0.222464] ACPI: bus type pnp registered
[ 0.222675] pnp 00:00: [bus 00-ff]
[ 0.222681] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.222687] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.222692] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.222697] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.222702] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.222707] pnp 00:00: [mem 0x78000000-0xffffffff window]
[ 0.222816] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.222881] pnp 00:01: [dma 4]
[ 0.222886] pnp 00:01: [io 0x0000-0x000f]
[ 0.222891] pnp 00:01: [io 0x0081-0x0083]
[ 0.222895] pnp 00:01: [io 0x0087]
[ 0.222900] pnp 00:01: [io 0x0089-0x008b]
[ 0.222906] pnp 00:01: [io 0x008f]
[ 0.222910] pnp 00:01: [io 0x00c0-0x00df]
[ 0.222977] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.223010] pnp 00:02: [io 0x0070-0x0071]
[ 0.223035] pnp 00:02: [irq 8]
[ 0.223095] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.223114] pnp 00:03: [io 0x0061]
[ 0.223179] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.223199] pnp 00:04: [io 0x00f0-0x00ff]
[ 0.223209] pnp 00:04: [irq 13]
[ 0.223275] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.226866] pnp 00:05: [io 0x0378-0x037f]
[ 0.226872] pnp 00:05: [io 0x0778-0x077f]
[ 0.226883] pnp 00:05: [irq 7]
[ 0.226888] pnp 00:05: [dma 3]
[ 0.227549] pnp 00:05: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.228934] pnp 00:06: [io 0x0010-0x001f]
[ 0.228939] pnp 00:06: [io 0x0022-0x003f]
[ 0.228944] pnp 00:06: [io 0x0062-0x0063]
[ 0.228948] pnp 00:06: [io 0x0065-0x006f]
[ 0.228953] pnp 00:06: [io 0x0072-0x007f]
[ 0.228957] pnp 00:06: [io 0x0080]
[ 0.228961] pnp 00:06: [io 0x0084-0x0086]
[ 0.228965] pnp 00:06: [io 0x0088]
[ 0.228970] pnp 00:06: [io 0x008c-0x008e]
[ 0.228974] pnp 00:06: [io 0x0090-0x009f]
[ 0.228978] pnp 00:06: [io 0x00a2-0x00bf]
[ 0.228983] pnp 00:06: [io 0x00b1]
[ 0.228987] pnp 00:06: [io 0x00e0-0x00ef]
[ 0.228991] pnp 00:06: [io 0x04d0-0x04d1]
[ 0.228996] pnp 00:06: [io 0x040b]
[ 0.229000] pnp 00:06: [io 0x04d6]
[ 0.229004] pnp 00:06: [io 0x0c00-0x0c01]
[ 0.229008] pnp 00:06: [io 0x0c14]
[ 0.229013] pnp 00:06: [io 0x0c50-0x0c51]
[ 0.229027] pnp 00:06: [io 0x0c52]
[ 0.229032] pnp 00:06: [io 0x0c6c]
[ 0.229036] pnp 00:06: [io 0x0c6f]
[ 0.229040] pnp 00:06: [io 0x0cd4-0x0cd5]
[ 0.229045] pnp 00:06: [io 0x0cd6-0x0cd7]
[ 0.229049] pnp 00:06: [io 0x0cd8-0x0cdf]
[ 0.229058] pnp 00:06: [io 0x0800-0x089f]
[ 0.229069] pnp 00:06: [io 0x0000-0xffffffff disabled]
[ 0.229078] pnp 00:06: [io 0x0900-0x090f]
[ 0.229084] pnp 00:06: [io 0x0910-0x091f]
[ 0.229089] pnp 00:06: [io 0xfe00-0xfefe]
[ 0.229094] pnp 00:06: [mem 0xffb80000-0xffbfffff]
[ 0.229098] pnp 00:06: [mem 0xfff80000-0xffffffff]
[ 0.229268] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.229275] system 00:06: [io 0x040b] has been reserved
[ 0.229280] system 00:06: [io 0x04d6] has been reserved
[ 0.229286] system 00:06: [io 0x0c00-0x0c01] has been reserved
[ 0.229291] system 00:06: [io 0x0c14] has been reserved
[ 0.229296] system 00:06: [io 0x0c50-0x0c51] has been reserved
[ 0.229302] system 00:06: [io 0x0c52] has been reserved
[ 0.229307] system 00:06: [io 0x0c6c] has been reserved
[ 0.229312] system 00:06: [io 0x0c6f] has been reserved
[ 0.229318] system 00:06: [io 0x0cd4-0x0cd5] has been reserved
[ 0.229323] system 00:06: [io 0x0cd6-0x0cd7] has been reserved
[ 0.229329] system 00:06: [io 0x0cd8-0x0cdf] has been reserved
[ 0.229334] system 00:06: [io 0x0800-0x089f] has been reserved
[ 0.229340] system 00:06: [io 0x0900-0x090f] has been reserved
[ 0.229346] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.229352] system 00:06: [io 0xfe00-0xfefe] has been reserved
[ 0.229359] system 00:06: [mem 0xffb80000-0xffbfffff] has been reserved
[ 0.229365] system 00:06: [mem 0xfff80000-0xffffffff] has been reserved
[ 0.229372] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.229432] pnp 00:07: [io 0x0060]
[ 0.229437] pnp 00:07: [io 0x0064]
[ 0.229448] pnp 00:07: [irq 1]
[ 0.229527] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.229875] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.229881] pnp 00:08: [io 0x0a00-0x0a0f]
[ 0.229886] pnp 00:08: [io 0x0a10-0x0a1f]
[ 0.229890] pnp 00:08: [io 0x0a20-0x0a2f]
[ 0.229894] pnp 00:08: [io 0x0a30-0x0a3f]
[ 0.229998] system 00:08: [io 0x0a00-0x0a0f] has been reserved
[ 0.230004] system 00:08: [io 0x0a10-0x0a1f] has been reserved
[ 0.230010] system 00:08: [io 0x0a20-0x0a2f] has been reserved
[ 0.230015] system 00:08: [io 0x0a30-0x0a3f] has been reserved
[ 0.230022] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.230135] pnp 00:09: [mem 0xfec00000-0xfec00fff]
[ 0.230141] pnp 00:09: [mem 0xfee00000-0xfee00fff]
[ 0.230237] system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.230244] system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.230251] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.230893] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.231018] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.231026] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.231332] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 0.231337] pnp 00:0b: [mem 0x00000000-0xffffffff disabled]
[ 0.231343] pnp 00:0b: [mem 0x000e0000-0x000fffff]
[ 0.231347] pnp 00:0b: [mem 0x00100000-0x77ffffff]
[ 0.231352] pnp 00:0b: [mem 0x00000000-0xffffffff disabled]
[ 0.231363] pnp 00:0b: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.231371] pnp 00:0b: disabling [mem 0x000e0000-0x000fffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.231379] pnp 00:0b: disabling [mem 0x00100000-0x77ffffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
[ 0.231496] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.231737] pnp: PnP ACPI: found 12 devices
[ 0.231741] ACPI: ACPI bus type pnp unregistered
[ 0.231749] PnPBIOS: Disabled by ACPI PNP
[ 0.270396] Switching to clocksource acpi_pm
[ 0.270758] PCI: max bus depth: 1 pci_try_num: 2
[ 0.270811] pci 0000:00:14.0: BAR 1: assigned [mem 0x78000000-0x780003ff]
[ 0.270824] pci 0000:00:14.0: BAR 1: set to [mem 0x78000000-0x780003ff] (PCI address [0x78000000-0x780003ff])
[ 0.270832] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.270838] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.270846] pci 0000:00:01.0: bridge window [mem 0xf9f00000-0xf9ffffff]
[ 0.270853] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff pref]
[ 0.270862] pci 0000:00:14.4: PCI bridge to [bus 02-02]
[ 0.270869] pci 0000:00:14.4: bridge window [io 0xe000-0xefff]
[ 0.270880] pci 0000:00:14.4: bridge window [mem 0xfa000000-0xfebfffff]
[ 0.270918] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.270924] pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
[ 0.270929] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.270934] pci_bus 0000:01: resource 1 [mem 0xf9f00000-0xf9ffffff]
[ 0.270939] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff pref]
[ 0.270944] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.270949] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfebfffff]
[ 0.270954] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.270959] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.271041] NET: Registered protocol family 2
[ 0.271187] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.271728] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.271728] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.271728] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.271728] TCP reno registered
[ 0.271728] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271728] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.271728] NET: Registered protocol family 1
[ 0.271728] pci 0000:00:00.0: MSI quirk detected; MSI disabled
[ 0.271728] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[ 0.271728] pci 0000:00:13.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.352107] pci 0000:00:13.0: PCI INT A disabled
[ 0.352143] pci 0000:00:13.1: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.432087] pci 0000:00:13.1: PCI INT A dis
jbullock
WinTV-HVR-1100
Postby peternsomerset » Sat Jun 07, 2014 8:41 pm
Did you ever get this resolved, if so how and where did you find the answer as I have had exactly the same problem!?
Thanks
Peter H
peternsomerset
